Old 09-14-2010, 03:45 PM   #1
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
Amazing result for Torq and Pfadt at the 2010 LS Fest! Full report inside with pics!
Well after arriving home yesterday from Bowling Green, KY (1100miles one-way) and the first annual LS Fest I put together a short report to share with you all.
First I would like to thank the whole crew at Holly LS Fest for putting on an amazing event! It was the first one so nobody really knew what to expect, plus the weather forecast wasn't the best but they definitely pulled it off with flying colors! We look forward to next year!
So getting ready for the event, we teamed up with Pfadt Racing once again and went with a complete suspension package for our shop car. We have been running their Springs and Sway bars previously and actually won quite a few races with just those mods, but to be able to competitive against some of the best built cars in The US some upgrades were necessary.
First we went with a set of Nitto NT-05's, 315's in the rear and 275's in the front on our light-weight rims. Even though I was very pleased with them, I would probably go with a different tire for an AutoX only set-up. Reason being is that they don't heat up as quickly as I would have liked. This is very important in Auto X racing since you only have about 1min for a full lap, then head back to to staging lane. My fastest times were all set when I was able to get 2 laps in relatively quickly after each other. But again, I am still very happy with the way they performed and they are a good compromise for a street tire that sees a lot of track duty.
For the suspension we put together the following package together with the guys at Pfadt. The sway bars were already installed previously so for a complete package I would make sure to have them in their as well.
  • Pfadt Racing fully adjustable Coil-overs
  • Pfadt Racing Rear Trailing Arms
  • Pfadt Toe-Link Assembly
  • Pfadt Solid Subframe Mounts
  • Pfadt Poly C-Arm Street Spherical Bushings
  • Pfadt Street Polyurethane Differential Bushings
Here are a few shots of the parts themselves, the finish and quality of the Pfadt parts are just outstanding. I know I am a suspension geek, but these are simply a work of art!
Pfadt Racing vs. OEM
Rear Trailing arms + Toe Link Assembly
Close-up of front and rear coil-over assembly
We managed to get everything installed on time for the long haul up to Bowling Green, and 10 min after the car was corner weighted and aligned I set off for the long drive.
When aligning the car we were quite conservative on the negative camber , mostly due to us actually driving the car the whole way there. The 5th Gen Camaro LOVES a lot of negative camber and needs it to really steer in nicely but we set it up so the tires would last the whole way there and back. Remember, absolutely nothing was changed from the cars daily driving specs when arriving at Bowling Green and tearing up the Auto X. We could have had a new set of tires with us, we could have knocked more camber in it, we could have even trailered it but we wanted to show what a full weight 5th Gen Camaro in full street trim could actually do competing against the best of the best.
I was extremely pleased with the ride quality of the Pfadt Coil-overs, even on the poor roads we have here in South Florida. Riding on the stiff track setting the car was in no way uncomfortable, and was very pleasant to drive. The "shudder" that you can sometimes get with an aftermarket spring was nowhere to be felt, and when trying out the softer settings she drove almost like a Cadillac!
After arriving at the track, it came clear to me what we were up against I and I knew it wasn't going to be easy in any way to finish top 5. Some of the finest, fastest, and most extreme Pro-Touring cars from Detroit Speed and Ridetech were on site to compete in the Auto-x.
Both Friday and Saturday called for rain, and boy were they right. It wasn't until Saturday afternoon when the track started to dry up (but was still quite greasy) that times started to drop for everybody. Although we did manage to set the fastest time in rain and held that for quite a while!
This is a shot to show just how wet it actually was, at times there were puddles so big you could park Queen Mary in one
So after all was said and done, my fastest time was set early Saturday morning after being able to almost hot-lap the tires and get them up to temperature. That time ended up giving us 3rd place overall in the Street Tire class! Seeing the competition I never thought it would have been possible, and many other contestants were extremely surprised with what we managed to achieve with Project Cammedmaro. A 4000lb full weight street car on street tires should not be able to run around a tight Auto X cross the way she did.
Here is a photo of the final time-sheet, car # 129 would be yours truly driving our Shop Car Cammedmaro in 3rd Place!
Notice the lap-times as well!
So as an end result, we beat every other 5th Gen Camaro, 4th Gen Camaro, Corvette etc (50+ cars entered), and only came after 2 of the most awesome Pro-Touring builds I've seen. All this and ours was the only car driven from a distance this far away, both to and from the event, and we still managed to end up in 3rd. To me Project Cammedmaro really sets the standard for a true Street Car!
In no way is 2200miles and 3 days of serious beating easy on any car, but with the right parts and built the right way anything can be achieved. I contribute this "win" to two things, Pfadt Race Engineering and and their superior suspension parts, and to our own team here at TORQ for putting together an amazing package, and spending hours and hours at the track and on the dyno testing every single part.
Stay tuned as Project Cammedmaro will be attending many more Road Course and Auto X events in the near future! Or mission to build the best handling Street Driven 5th Gen Camaro is proving to be fully achievable, and soon to be a reality. We learned that with a few minor things we could have taken the win, but we are extremely pleased with the outcome and will be back even stronger for the next event.
Here are a few more shots of The Camaro on the track!
Braking HARD from high speeds to zero with a very aggressive pad and slotted rotors = lots of sparks
How something so big can look so much at home on track is unbelievable
I will be posting some videos as well as soon as I get them uploaded. If anybody has any questions at all regarding the suspension set-up or anything else, just post them here and either a representative from Pfadt or myself will answer them.
/Erik@Torq
Erik@Torq is offline   Reply With Quote
Old 09-14-2010, 06:42 PM   #2
TCao
Drives: 2010 2SS RS, 2007 FJC
Outstanding report! Please post the alignment specs and shock damping settings used for this track when you have a chance. Kudos to the driver as well for finishing 3rd.
TCao is offline   Reply With Quote
Old 09-14-2010, 06:51 PM   #3
Erik@Torq
Erik@Torq's Avatar
The Driver would be me, so thank you for that
I will post up the specs shortly!
/Erik@Torq
Old 09-14-2010, 07:07 PM   #4
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Way to represent. You guys are a horrible influence on me. I just ordered the pfadt coilovers, lol.
1977and2010 is offline   Reply With Quote
Old 09-14-2010, 07:55 PM   #5
TCao
Congratulations! You should consider getting your car corner-balanced after the PFADT coilovers installation to get the most out of this suspension system. Back to the regularly-scheduled program...
Old 09-14-2010, 09:09 PM   #6
CamaroFTW
CamaroFTW's Avatar
Drives: 2010 Camaro 2SS/RS-Rally Yellow
Send a message via MSN to CamaroFTW
Erik..Congrats to you and your beautiful Camaro! WOW 3rd place...awesome!
I love my Pfadt too
Talk to you soon! Glad you had a safe trip back!
CamaroFTW is offline   Reply With Quote
Old 09-14-2010, 10:08 PM   #7
sunsfan
sunsfan's Avatar
Drives: 1970 Camaro, 2010 Camaro
grats on 3rd you guys put together a nice car!
2010 Camaro & 1970 Camaro
sunsfan is offline   Reply With Quote
Old 09-15-2010, 01:16 PM   #8
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Doing work! I still cant get over how you guys were racing through the monsoon. Only in auto cross !
Good seeing you again.
Regards
IPS Brandon is offline   Reply With Quote
Old 09-15-2010, 02:56 PM   #9
Erik@Torq
Erik@Torq's Avatar
Very nice! You will be very pleased, let me know if you have any questions about them!
Thanks! The car was actually corner balanced when we aligned it, so that is all taken care of. We are going to have it re-aligned once we get the camber plates i though, need some more camber for the track.
I love my Pfadt too
Thanks Hank! I appreciate it! I will get back to you shortly regarding your email btw
Regards
That is true, but that's what makes auto-x fun! Rain just makes it a little bit more interesting
Old 09-17-2010, 10:32 AM   #10
Matt'sSS
From 2 door to 5 door
Matt'sSS's Avatar
Drives: C5 Vert->CGM SS RS M6->SRT8 Magnum
Amazing job Eric! Congratulations to you and your team at Torq! Keep the podium finishes coming!
Matt'sSS is offline   Reply With Quote
Old 09-21-2010, 02:05 PM   #11
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Erik, what is the next event planned?
Old 09-21-2010, 06:11 PM   #12
YancyJohns
YancyJohns's Avatar
Drives: Camaro Performers Magazine
Erik, Thanks for the ride. Keep a lookout in your rear view mirror......hehe
Camaro Performers Magazine SS/RS- 416 stroker, MagnaCharger TVS2300, DSE Sway, Baer 6S Brakes, Forgeline Wheels, BFG Rival, JBA Long tube/Exhaust, Center-Force Clutch, BMR-sfc,ta,tr, Energy Suspension poly kit, ADM CAI & Fuel pump, Norris PCV/Tune, Lingenfelter GT-9 cam, DSS 9" rear ind rear, Innov. West pulleys/8 rib, Pedders Super cloil-overs, MGW shifter,/Seibon/ Anvil carbon Fiber. Owner-American Street Car Series and as seen on R U Faster than a Redneck?...lol
YancyJohns is offline   Reply With Quote
Old 09-22-2010, 07:19 AM   #13
Erik@Torq
Erik@Torq's Avatar
I'll be posting up some info about our next big event shortly! This weekend we have a PCA event here in Miami. I plan to show these Porsche Owners what the rear end of Camaro looks like.
No problem, it was nice meeting you!
I will keep a look out, we might be seeing each-other sooner then later my friend
/Erik
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Motorsports Suspension / Chassis / Brakes 75 12-13-2010 09:29 AM
Pfadt Coils/Sway Bars/ Trail arms/ Subframe bush installed - pics inside CamaroSS8491 Suspension / Brakes / Chassis 4 08-22-2010 09:27 AM
PFADT - Drop springs & Balance bars (Pics inside) CRUSHER2SS Suspension / Brakes / Chassis 12 01-05-2010 09:12 AM
