Raised by Wolves
I got the idea for this thread in the "gf can't see" thread. How about driving? How do you like your seat set? When I'm driving, the seat is set as low as it can go, and almost all the way back. I'm 5'10". This is the most comfortable car to drive!
Dennis is 5'9", and he drives with the seat as high as it can go, and forward marginally more than would work for me. Surprising to me how 2 people so close in height would set the seat in such different positions. |
![]() Drives: 2011 RJT 2SS/RS M6- Rogue Join Date: Feb 2010
It depends on if you have long legs or a long body. I have long legs, so at 5'10" I have it almost all the way back and the seat is about in the middle of the height adjustment.
Power without control is useless.
![]() ![]() ![]() ![]() Drives: 04 Ram 2500 & 2010 Camaro 2SS/RS Join Date: Feb 2010
At 6'9" I have my seat all the way back and as low as it can go. I also have it reclined a good amount. It's nice to know there's a car out there an ogre like me can fit in.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 IOM Camaro Join Date: Jul 2010
Mine is set as low as it will go. I drove a 4th gen as my first car (that didn't have up/down adjustments), so I got used to and liked driving low. I'm 5'2" by the way.
![]() Drives: 2010 SS Camaro Aqua Blue Metallic Join Date: Jan 2010
I'm 5'10 and averagely proportioned. Seat is all the way down and about 3/4 of the way back. I like to relax when cruising to and from work 70 miles roundtrip 5-6 days a week!
#6 |
love. my. car.
I have my seat all the way back and about 75-85% as low as it can go. I raised it up a bit because I realized the sun visor works exponentially better if you sit higher, but my legs get too close to the wheel and start rubbing if I go to 50% or more, so I compromised a tiny bit of room for a usable sun visor. I found out I drive during dusk quite a bit and I need that tiny little thing. I'm 6'4" with long legs and a shorter torso.
#7 |
5'11" here. My seat settings are pants on the ground and a little less than all the way back.
It's one of the most comfortable vehicles to ride in; just getting in or out is the hard part really.
#8 |
"Silver Street"
Drives: 2010 2SS/RS L99 Join Date: Oct 2009
I am 5' 10" and prefer it up high and sitting forward, but since I got tired of hitting my head everytime I got into the car, I have been getting used to sitting back further and lower with some recline.
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing |
#9 |
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro Join Date: Jul 2010
@ Nearly 6'6" ................No problems entering or exiting. No problems finding a comfortable position for driving. Head doesn't touch the head liner and Casper is sunroof equiped. No seat belt issues. The seat is generally set near the bottom of its travel, with a slight seat back incline rearwards. The forward portion of the seat is adjusted tilted slightly upwards. The telescopic adjustment is generally set forwards and in the middle setting. Its easy to see the dash cluster. My forward viewing area is in the center of the windshield. My view isn't obsured. The sunvisor and upper portions of the windshield area are atleast 8" above that forward viewing area.
#10 |
6'5 195 lbs. got the front of the seat high as it will go, and the rear as low as it will go so it has a nice incline to it. then the back has a nice lean to it. sits close to the rear seat.. not all the way back though.. dont like my arms being all stretched out for everything.. dont mind having my legs a little closer
| Where we are coming from (check inside) | ljustin293 | 2010 Camaro5 Fest (I) | 106 | 05-13-2010 12:31 AM |
| Camaro 5 Fest Drivers or Spectators | garcmol | 2010 Camaro5 Fest (I) | 427 | 04-23-2010 03:32 PM |
| CLOSED - Driver Signup for the 1st Annual Official Camaro5Fest (April 16-18, 2010) | GTAHVIT | 2010 Camaro5 Fest (I) | 923 | 03-20-2010 12:56 AM |
| New Camo shots of a Camaro | bballr4567 | Camaro ZL1 Forum - ZL1 Specific Topics | 150 | 02-18-2010 01:13 PM |
