Old 09-19-2010, 07:55 AM   #1
ULTRAZLS1
ULTRAZLS1's Avatar
Drives: 14 Silverado LTZ Z71, 16 Camaro SS
LS3 and L99 engine dyno test
http://www.**************************-...l#post13882913
Stock on engine dyno with headers and no accessories.
Nearly 500hp for the LS3...must take a lot of hp to get this pig moving lol.
ULTRAZLS1 is offline   Reply With Quote
Old 09-19-2010, 08:07 AM   #2
Napper
Napper's Avatar
Drives: 2SS RS A6/ CTS-V A6 LSA
don't add to the fuel.
the SS is a great car. GM did leave some things for us to do.
everyone is thinking power...we need to address the suspenion.
Once thats done....even minimal power gains will result in et's worthy of the SS name.
I know this . i went down in hp and tq ( lowered my psi by 1.5) and added key suspension peices.
Since i've done that. My SS (L99) has been good to me.
the SS is not a pig.....it needs to be finalized. GM was in the mist of going down when realeased.
take a bone stock SS powertrain and add the proper suspension piece and watch the et drop.
10 2SS(7Psi)/10 CTS-V(9Psi)
L99, ADM RACE CAI, TVS 2300,LG- Headers and X pipe ,catless 3 inch back w/Magnaflows , Ngk plugs,Msd wires,180 stat,Springs ( lowered 1"- looks solidly correct)Sways and endlinks,BMR trailing arms, Slotted rotors and Hawk HPS ,tuned ,Black out bowtie and custom (black)"SS" on sides /midnight rims (8psi)
2010 Raven (triple black.)CTS-v , crank pulley, Bubb CAI , AR Headers, custom catlessback. magnaflows. tune ( 9psi)
former LS7, LS2 and LS1 owner.(Zo6, GTO's, WS6)
Napper is offline   Reply With Quote
Old 09-19-2010, 11:12 AM   #3
Jefe's SS
Drives: 2010 2SS/RS IOM L99
So according to the graph the L99 and the LS3 are underrated from the factory? Way underated!
Don't many tuners get lower base numbers? Numbers that confirm Chevy's factory ratings?
Jefe's SS is offline   Reply With Quote
Old 09-19-2010, 11:24 AM   #4
flyby
Drives: 2010 Silver SS
What napper said. Suspension upgrades yield great driving increases. A good tuner will be able to pick up some added HP, usually more than any bolt on, GM did leave some on the table but not as much as in the past. The Camaro is an awesome car, if you plan on modifying the car I would start with the foundation (suspension) then you have a good starting platform to build upon. Just my .02
flyby is offline   Reply With Quote
Old 09-19-2010, 11:50 AM   #5
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
I agree. On my 98 z28 suspension, even though setup more for handling addressed alot of the slop left in the system and can reduce times and help launches. Some basic setups got up to 2-3 tenths off just because the car hooked up better.Need to get the power to the ground as good as possible.
As far as being underated I know the LS1's were by about 35hp,didn't want to piss off the corvette guys. And as the car breaks in we would get 10-15 more rwhp and .2+ 2 mph faster. I am wondering if my v6 didn't get more hp after breaking in also as I see alot of new and seasoned dyno numbers and must be getting more broken in which would make sense.
VR Baron is offline   Reply With Quote
Old 09-19-2010, 11:54 AM   #6
usmc8411
Drives: 2010 camaro
Those were engine dynos with no accessories I believe. Thats not how they are rated from the factory.
So you have 500 minus 30ish for the headers and cai and you have about 470....minus spinning stock accessories such as power steering, water pump, a/c, alternator, belt tensioner and you are probably only a few hp off that 426 rating.
usmc8411 is offline   Reply With Quote
Old 09-19-2010, 01:26 PM   #7
ackeight
ackeight's Avatar
Drives: 10' 2SS/RS
Dito
ackeight is offline   Reply With Quote
Old 09-19-2010, 05:40 PM   #8
ULTRAZLS1
ULTRAZLS1's Avatar
Dude...I am just passing along information of an engine dyno test. I know what the car is capable of etc etc
As far as the car being a pig...I meant this as the car is heavy...nothing more. I love the car obviously...I bought one. But 3800+ pounds for a sports car is a bit portly.
For those talking about under rating.....no it is not. This was with no accessories, a cold air intake and dyno headers. It is interesting that it is showing a 30hp difference form the L99. Due to the + or - 1% variance allowed by SAE I am sure the LS3 is making 430hp just like it is in the vette...thus a 30hp difference from the L99.
Old 09-19-2010, 06:01 PM   #9
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Up to 4500 rpms, the LS3 and L99 make basically the same HP. The LS3 shines from 4500 - 6500 rpms.
Old 09-19-2010, 06:34 PM   #10
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
The basic HP difference is the automatic engine L99 have the feature of turning off 4 cylinders when the crruise control is on, this changes the valve system, that's were the 26hp differece comes in.
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 09-19-2010, 07:02 PM   #11
ULTRAZLS1
ULTRAZLS1's Avatar
A couple different independent dynos (as well as this one) have shown a 30hp + difference.
And its not just that...the L99 is lower compression, has a smaller cam and has a lower RPM fuel cut off (because of the smaller cam)
Old 09-19-2010, 07:07 PM   #12
usmc8411
Drives: 2010 camaro
Why do people continually make things up on this site without fact checking what they are about to tell thousands of people...that will in turn read false information and spread it themselves?
The HP difference comes from the l99 having a lower compression ratio due to uisng notched pistons, and running a different cam.
It has zero to due with AFM...which has nothing to due with cruise control.
Old 09-19-2010, 07:21 PM   #13
383ss
Drives: 1985 IROC, 2011 Camaro
the smartest person on Camaro5! Thanks for enlightening us!
Originally Posted by hsdguru View Post
31000 for ss1 no options and who in the hell would buy a SS1 V6 for kids SS1 for girls LS3 the only way to go G8 Gxp 200lbs more my bad so lets think here 200lb more 27 less hp so 5 tenths slower now 373 gear now mabe 3tenths slower 4 door car sad so so sad
383ss is offline   Reply With Quote
Old 09-20-2010, 12:45 AM   #14
ffrcobra_65
Unofficial 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 250 04-01-2014 11:40 AM
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
