Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
For people that have reverse light surrounds
Today i installed the reverse light surrounds from defenderworx and i was wondering when you guys installed them did you put the Bowtie on them on the bottom or on top? I put it on bottom but im not a 100% sure if i did it right.
Thanks for your help |
That appears to be the only way they will work properly.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
45th Anniversary Edition
Drives: 2012 Carbon Flash Metallic 2SS/RS Join Date: Jun 2009
yep the bow def works better on the bottom, looks the best too. good job
| New! ABS Hard Plastic Side Marker, Reverse Light and Tail Light Kits! Not cheap vinyl | RPI Designs | Exterior Parts & Accessories | 132 | 12-31-2020 07:43 AM |
| DIY Raptor Dual Stage Shift Light. | ThunderSS | Camaro DIY & HOW-TO instructions & discussions | 47 | 05-27-2019 08:48 AM |
| DIY - ABL using EL wire, and 3/16" tube | camarorick | Camaro DIY & HOW-TO instructions & discussions | 502 | 02-25-2014 01:29 PM |
| Source for black tail light surrounds? | Kwik | Cosmetics and Lighting Modification Discussions | 6 | 06-18-2010 07:44 PM |
| Reverse Light Bulbs - Help! | BryanB | Cosmetics and Lighting Modification Discussions | 12 | 11-12-2009 01:13 AM |
