![]() Drives: 2010 Camaro 1SS/RS Join Date: Feb 2010
Max HP for Motor and Crank????
Hello everybody,
I have some big plans on my 2010 Camaro SS (Manuel). I was just wondering if anybody knew what the max power that the motor could take,and the max power that the crank? The final numbers that I'm looking at when its all said and done for horsepower is bout 600-700 HP. If anybody could offer any advice please let me. Thank Camaro Owners.... ![]() |
#2 | |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
^ well put
Welll I thinking about twin turbo with STS Turbos. Then have the intake manifold from LSX, Kooks headers 17/8, Bigger injectors, Cam unsure of just depends on othe factors, and Trinity tuner. Their are more mods that I will be doing, but those are the main ones that are coming up. Yes this will rwhp.
The use that I will have for it is probably high rolls on the highway and I will take it to the track possibly once or twice once its all done. I will have this car for almost an everday driver until I can get something else that will do for the time being. |
if you are gonna do all that you are also gonna wanna step up the rest of the drive train
my youtube
my facebook www.myspace.com/1djchampagne www.twitter.com/1djchampagne mods: borla long tube headers, borla atak catback, lingenfelter gt-9 cam, ported heads, ecs base kit running 11 psi on top end, 1" bmr drop spring, aam 3.70 gears, ported throttle body, 160* thermorstat, lethal racing tune 750/641 rwhp/rwtq |
#6 |
Yes, I will beef up the drive train. I was curious of the max power that both can hold. That's all, it seems that it just depends on the route that I go. I just don't want to put these turbos on and the tranny can't hold the power or the rear end.
#7 |
Search Ninja
I've never been a fan of STS turbo systems. It is a terribly wasteful system. Unless the price is drastically cheaper, there are MUCH better systems out there. There are several TT and single systems for the Camaro that are bolt-on and have been shown to be very efficient. They run low boost (6-8lbs) to reach 600+whp. You can subtract the price of LT's as they bolt directly to the OEM manifolds. They will also grow with you as they are capable of close to 1000whp by just increasing the boost level. Of course you'd have to build your engine for that but you wouldn't have to buy anything for the turbo system for that increase. Buy what you want but just know what you're getting into.
As far as the tranny and rearend, I think you'd be ok. You will need a much better clutch though. For what you're wanting to do, upgraded axles, trailing arms. toe arms, sways, and some of the bushings will be paramount. I'd also drop the car for better aero and handling. These will not only eliminate wheel hop but also make the car feel planted and stuck to the road. These are things that will be GREATLY appreciated while you're driving around that test track in Germany. ![]()
#8 |
Thank you for the input "axis", and everybody else that has added their comments. Pricing on the twin turbo set up from the website was about 7k. I would love to go with Hennessey's set up but I not making that Hennessey money. Im around turbos everyday and unfortunatly they are STI's and EVO's. Im some what familiar with them. If I dont like the system then on to the next one. I have been also looking at Precision Turbos. I know that they have been in the game for a long time now. I have heard they are the ones to go to for turbos.
#9 |
BAMF SS
The crank is known to be good for over 1000 rwhp. People usually just go with aftermarket ones for the added displacement, not the strength.... or just for overkill.
Kind of depends on the motor if the ringlands, pistons, rods, or rod bearings will go first.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
#10 | |
Search Ninja
As Danhr stated, it's the rods and possibly rings that will go first. I'm thinking someone is making over 700whp on the stock motor but he isn't abusing it at all.
#11 |
Thank you guys for the info. I will keep those parts in mind. Im still talking to my mechanic about this set up.
Now I just need to know how much the motor can take. |
#12 |
I would go with hellion for turbos and Hennessey for blowers personally. GM Performance guys say the stock engine should have its cast pistons removed and replaced with forged ones if you plan on running more than 550ish crank hp. Drivetrain wise the auto can handle around 800 ft of torque and the manual around 600ft lb any more and all you will need is a ZR1 clutch then it can handle anything you can throw at it just about.
#13 |
I was thinking bout it but hennessey is a lot of money but I might try and save up for it but we will see. I just needed to know what the max for both of them were. I have the zr1 clutch coming soon. I might just try these turbos and them see if I like them. I will let u guys know how it all works out.
Texas Speed LT Headers (no cats), LS3 Monster blower cam, Muffler Delete, Stage 3 Spec 3 Clutch,102mm F.A.S.T Intake Manifold, Comp Cam Push Rods, Comp Cam Dual Springs, D1-SC Procharger, ID850cc Injectors, Stealth Fuel Pump, F.A.S.T Fuel Rails, Tune by Brett Seaburg, Nitto Street Radials, Amber Halos and Fog Lights, Window Tint (5%) Nightshade Tail Lights, Interior Amber Dome Light and Trunk.
Hotchkis 4-Point Chassis Max Front Strut Brace | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 57 | 11-13-2010 03:29 PM |
Hotchkis Chassis Max Brace in stock and ships FREE w/promo @ PFYC.com | PFYC | Suspension / Chassis / Brakes | 0 | 09-09-2010 10:04 AM |
2010 Camaro Chassis Max Strut Brace | SupremacyCustoms | Suspension / Chassis / Brakes | 25 | 03-10-2010 10:54 AM |
LMPerformance, Hotchkis 2010 Camaro Chassis Max Brace | LMPerformance | V8 Bolt-Ons & Tunes | 0 | 01-05-2010 11:17 AM |
