Old 09-21-2010, 02:09 PM   #1
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
rwhp Verse Crank HP
Has anyone definitively come up with a drivetrain loss % for the 2010 Camaro LS3? Thanks for your help!!
T
BoostedX2 is offline   Reply With Quote
Old 09-21-2010, 02:30 PM   #2
GeorgeM
Drives: 2016 2SS, Yellowjacket, A8
T
Drivetrain loss is about 10% on the LS3 and close to 15% on the L99. Automatics always experienced a higher loss due to the torque converter and transmission internals.
GeorgeM
GeorgeM is offline   Reply With Quote
Old 09-21-2010, 02:32 PM   #3
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
I think it is more than 10% on manuals, at least on mine it was.
2010 2-Tone is offline   Reply With Quote
Old 09-21-2010, 02:32 PM   #4
BackinBlackSS/RS
Go Blue!!!!!
BackinBlackSS/RS's Avatar
Drives: 2012 Cruze LT
From what I have see the LS3 is about 13 to 15% and the L99 is 20%
Old 09-21-2010, 02:37 PM   #5
Dave Coyle
Dave Coyle's Avatar
Drives: 2010 SS , 1970 Z-28, 2002 Avalanche
Yes, the 15% on sticks and 20% on autos is more close.
IF IT'S WORTH HAVING, IT'S WORTH WAITING FOR!!!! (AND IT WAS)
434RWHP/403RWTQ
Livernois Motorsports 2C Cam kit
Kooks 1 7/8 LT Headers/Hi-Flo Cats/Corsa Exhaust
Roto-Fab CAI / Port Intake
Precission 2400/2800 Converter/3.73 AAM gears
Livernois Motorsports Tune
Best time: 11.97 @ 117 MPH
Dave Coyle is offline   Reply With Quote
Old 09-21-2010, 02:52 PM   #6
VTXrider
VTXrider's Avatar
Drives: 2010 RY 2SS/RS
This number is not really possible to arrive at unless you dyno the same engine at the crank and at the wheels. Even then the number would change for each car slightly.
426 bhp is not the actual horsepower for any LS3 except by coincidence, this is something of an average of what the engine is expected to produce. This is evidenced by the change in bhp of the v6 from 2010 (304 bhp?) to 2011 (312 bhp?) where gm stated that there was no difference in the actual power only that they used the SAE formula to arrive at the 2011 bhp and a different formula for 2010.
There for if your car dynos at 380 rwhp this may look like a 10.8% loss to the drive train but in fact you do not know the actual crank hp. I would not be surprised if LS3s ranged from 410-440 horsepower at the crank. This may look like a large difference but keep in mind it is only a 3.5% variation from stated.
VTXrider is offline   Reply With Quote
Old 09-21-2010, 03:46 PM   #7
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Could be right, look at the ranges on l99's 310-330 or so and V6 anywhere from 230-250 for a6.But also is different dynos and temps account for alot of it I would think. Also engine fully broken in usually makes more but is that above the factory # or to make the factory #?
Anyway I have always heard about 15% on M6 and 20% on the auto, on a Dynojet.
VR Baron is offline   Reply With Quote
Old 09-22-2010, 01:50 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Its been a while since I looked but the LS3 Camaros seem to have approximately 14% driveline loss (+/- 1%). The L99 cars are around 17% loss.
Its not that hard to figure out. Look at as many stock dyno runs as you can. You should get an idea about whats normal, sure there will be a few runs that are low and a couple that are high but most should read about the same, to within about a 10 hp range. To figure out the loss, use the following formula:
(1-rwhp/crank hp) x 100%
So, lets say an LS3 car dyno'd 368 at the wheel. (1-368/426) x 100% = 13.6% loss. Now, this isn't perfect because it assumes that the engine is making what it is advertised as. But most SAE rated engines should deliver as promised while a lucky few will probably give a bit more. They won't deliver less than advertised unless there is something wrong (like reading from the wrong fuel table)
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 09-22-2010, 02:27 PM   #9
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
most shops will say aruond 15% loss on the LS3 (manual).
Crowley
Crowley is offline   Reply With Quote
Old 09-22-2010, 02:29 PM   #10
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
The reason for the change was not due to a formula. It was because the engine had been certified in the CTS so they used it's numbers to save time/money. When they certified it officially in the Camaro it performed better due to the Camaros better flowing intake and exhaust.
9/26/09 Took delivery!
Old 09-22-2010, 02:31 PM   #11
JonMan503
Drives: 300zx for now ss very soon!!
id say around 14 on the LS3 from what I've seen
JonMan503 is offline   Reply With Quote
Old 09-22-2010, 02:37 PM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Correct. They didn't change anything in the engine between 2010 and 2011 model years, they knew it made more than 304 hp but didn't see a need to certify it for 2010. Looks like their bet payed off because Ford and Dodge used that as a mark for their new V6's, and GM then certifies their 3.6L for the Camaro for 2011.
Review: 473 rwhp Mike Norris Motorsports cam ducatisl Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 30 10-26-2010 06:12 PM
My goal of 650-700 rwhp Dreamer2430 5th Gen Camaro SS LS LT General Discussions 2 03-09-2010 09:17 PM
Over 500 RWHP Automatic MTI Racing Forced Induction - V8 6 10-30-2009 11:51 AM
