Old 09-22-2010, 03:17 PM   #1
speeD3m0n2010
Drives: 2010 Camaro 2SS/RS
Anyone notice oil residue everyone oil change?
Anyone with oil residue underneath and around the vicinity of oil pan when you change your oil? Been noticing that the last two oil changes. I didn't have any pictures of it, sorry. 1st oil change 550 miles, 2nd 3500 miles and 3rd 9200 miles. I cleaned the oil at all the affected area's that had the oil "overspray/underspray". May have to take it to the dealership later get a more difinitive answer.
speeD3m0n2010 is offline   Reply With Quote
Old 09-22-2010, 04:34 PM   #2
Russell James
Russell James's Avatar
My guess would be pan gasket. When I was a tech, changed more LS pan gaskets than I care to remember. On most the pan bolts hardly had any tq. Knock wood, so far my Camaro is dry and tight.
I bought 2 Z06's in a row, an 03 and 04. Both of those LS6's had leaky pans within a year.
Old 09-22-2010, 06:30 PM   #3
speeD3m0n2010
Most of it looks like coming from right side of the oil pan. I wish I had my cell phone or any type of camera. It had that ripple look from the wind. It took about 30min and a few rags to clean.
Old 09-22-2010, 07:56 PM   #4
jagan323
I have no life
jagan323's Avatar
Drives: 06' Subaru STI, ex-Camaro V6 LLT
torque things properly! THats the only explaination I can think of!
jagan323 is offline   Reply With Quote
Old 09-22-2010, 09:08 PM   #5
Oldrocker
Oldrocker's Avatar
Drives: 2010 SS2/RS Victory Red
I would look closely at the rear of the oil pan where the engine meets up with the transmission. Also if you have an auto, pull the plug out of the bottom of the bell housing. If there is oil in there, you probably have the problem addressed in the bulletin below....
Bulletin No.: 05-06-01-034K
Date: April 08, 2010
Subject: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure)
Models:
2004-2007 Buick Rainier
2008-2009 Buick LaCrosse Super, Allure Super (Canada Only)
2005-2010 Cadillac CTS-V
2007-2010 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2009 Chevrolet TrailBlazer
2003-2010 Chevrolet Corvette
2004-2006 Chevrolet SSR
2005-2010 Chevrolet Silverado, Silverado SS
2006-2007 Chevrolet Monte Carlo SS
2006-2009 Chevrolet TrailBlazer SS, Impala SS
2007-2010 Chevrolet Avalanche, Suburban, Tahoe
2009-2010 Chevrolet Colorado Pickup
2010 Chevrolet Camaro
2003-2009 GMC Envoy
2003-2010 GMC Sierra
2004-2005 GMC Envoy XUV
2007-2010 GMC Yukon XL, Yukon Denali, Yukon XL Denali
2009-2010 GMC Canyon
2004-2006 Pontiac GTO
2005-2008 Pontiac Grand Prix GXP
2008-2009 Pontiac G8 GT
2009 Pontiac G8 GXP
2005-2009 Saab 9-7X 5.3i
2008-2009 Saab 9-7X Aero
2003-2010 HUMMER H2
2006-2010 HUMMER H3
with 5.3L, 5.7L, 6.0L, 6.2L, 7.0L VORTEC(TM) GEN III or GEN IV V8 Engine (All Aluminum Block) (RPOs L33, LC9, LH6, LH8, LH9, LM4, LS4, LS1, LS6, L76, L77, LFA, LZ1, LS2, L92, L94, L99, L9H, LS3, LS9, LSA, LS7)
Supercede:
This bulletin is being revised to add labor time information for the Colorado and Canyon. Please discard Corporate Bulletin Number 05-06-01-034J (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on an engine oil leak.
Cause
Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only.
Correction
Follow the steps for Oil Leak Diagnosis in SI to determine the source of the leak. If the leak has been diagnosed as coming from the engine rear cover assembly, refer to Engine Rear Cover Replacement in SI and remove the engine rear cover assembly. Inspect the engine block and engine rear cover for porosity on the mating surfaces.
- If porosity is found on the engine rear cover (see illustration below), replace the engine rear cover assembly, GM P/N 12633579.
- If porosity is found on the engine block, use the following procedure to apply RTV to repair the engine block porosity.
The porosity issue is in the gasket sealing surface at the top of the cover, near the high pressure oil crossover port. Refer to the picture below. The oil leaks by the gasket and runs down the side of the cover, and may appear to be a leak at the t-joint area of the cover. The fix is to replace the cover with GM P/N 12633579. Also, if porosity is found anywhere on the sealing surface of the engine block, use the following procedure to apply RTV to repair the engine block porosity.
Important
Clean any residual oil from the block and cover before applying the sealant in the next step.
1. Wipe a small amount of RTV, P/N 12378521 (in Canada, use P/N 88901148), onto the surface using a plastic scraper to fill the porosity.
2. Remove any excess RTV material, especially from inside the high pressure oil passage. Refer to #1 in the above illustration.
3. The joint may be closed immediately after applying the RTV. Total joint time after the RTV has been applied must be under 20 minutes.
Important
Refer to Engine Rear Cover Replacement in SI and follow the tightening specifications and sequence.
4. Reinstall the engine rear cover using a new gasket and a new crankshaft rear main seal. Refer to Engine Rear Cover Replacement in SI.
Parts Information
Important
For Saab (U.S.) only, use P/N 88861206 - Engine Oil Dye (U.S.) or equivalent
My car has this leak. It doesn't ever leak a drop on the ground, it just leaves a thin film all over the bottom of the oil pan. Take it to the dealer for warranty.
Oldrocker is offline   Reply With Quote
Old 09-23-2010, 02:47 PM   #6
camaro52010
Camaro4ever
camaro52010's Avatar
Drives: 2010 Camaro SS/RS, 1978 Z28 Camaro
Torque your oil pan bolts, some are loose from the factory.
camaro52010 is offline   Reply With Quote
Old 09-23-2010, 08:22 PM   #7
speeD3m0n2010
Thanks guys, taking it to the dealership in the morning to make sure. Those dumbass's better not dump the new oil, thats about $90 of AmSoil. By the way, it a M6 tranny.
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
3,000 Miles - No "Metal Shavings" - Anyone Else? FNKNSTN 5th Gen Camaro SS LS LT General Discussions 48 10-06-2009 12:46 AM
