![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS, 2010 Mustang GT Join Date: May 2010
Injen CAI Issue and Resolution
I recently purchased the Injen Cold Air intake system through Jannety Racing. Great company by the way. So after installing everything and going for a drive I get on the highway to try it out get off on an exit and I get a check engine light. The Car starts to vibrate unusually almost stalling out. I head back home and call onstar to get the codes. P0304=Mis-Fire on cylinder 4 and P069E=Fuel Pump Control Module. After about 10 key cycles the CEL go's away and the car runs normal. Me and a friend did some further research and found some info on oiled air filters being to oiled can cause the MAF to get oil residue on it and cause the car to ping. So for anyone who is getting a check engine light or problem similar to this after installing an oiled CAI filter check the MAF Sensor to ensure it is connected tight and secure. And also check the filter to ensure it does not have excessive oil. My buddy told me when he would clean and oil his filters he would let the filter sit in the sun oiled up for 2-3 hours to allow any excess oil to leak off. Hopefully this helps you guys and have a great weekend.
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
Wait, the Injen is a dry filter isn't it?
![]() Drives: 2011 2SS, 2008 MB E50, 2004 RAM Join Date: Sep 2010
i thought it was a dry filter as well. looking at the cleaning instructions for it...it does not mention anything about re oiling it.
13.453 @ 101.90
Drives: 2010 Camaro 2LT Rally Yellow Join Date: May 2009
My Injen long tube came with a dry filter.
GMPP exhaust/JBA shorties/Vararam CAI/VMax TB/SLP Pulley/VMax IM isolator/MACE Ported IM +Plenum Spacer/IPF Tuned |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 1997 30th Ann. Z28 & 2010 2LT RS Join Date: Jan 2010
Long tube here as well and it came dry !
#6 |
![]() ![]() Drives: 2006 White Corvette Convertible Join Date: Feb 2010
The dry filter was the reason I bought it.
The Corvette is an animal.
#7 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
dry... lol.
Someone dipped your filter in some oil OP =D
#8 |
no way man thats impossible when i took it out it was oily as ****
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 RJT 2LT/RS Convertible Join Date: Nov 2009
Yes, the web site even says it's a dry filter. I thought the instructions said to disconnect the negative side of the battery during installation. Isn't this similar to a fuse pull ? This would allow the system to re-learn and eliminate the problem with a CEL I believe.
1st IPF Supercharged 2011 2LT/RS RJT Convertible
#10 |
off injen website
2 STAGE AIR FILTER Constructed of surgical cotton gauze, the filter element comes precisely oiled to maintain consistent airflow and prevent obstructions to the intake system. Each filter is specifically chosen for every application, as the dimensions, pleat and flow rate are highly crucial to optimal performance gains. |
#11 |
Here is what I got from the www.injen.com ? Don't understand it but mine was a dry filter.
Features
#12 | |
13.453 @ 101.90
http://www.amazon.com/gp/product/B00...EBQ6NJWE5W5675 Perhaps yours came with this one? 1021 BR oiled http://www.amazon.com/Injen-Technolo.../dp/B001CO1AH0
#13 |
Trust me I'm a Scientist.
It is oily LOL mine came in tightly wrapped and yes it is oily as F*CK!
"From ZERO to a Tire-Burning HERO!"
Mods: RotoFab CAI, SW Headers, HiFlo Cats, Borla Atak Catback, Nightfury Cam, Ported Heads,Intake,TB, melling pump, Morosso Oil Separator. |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
Did they change them from dry to oil? Mine was dry as well!!
| Will upgrading audio system void warranty? | Recce | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 17 | 08-14-2010 01:18 PM |
| Transmission output shaft | hiller72 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 267 | 12-02-2009 09:39 PM |
| Will the V6 have DBW or a good old fashioned cable throttle? | theholycow | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 41 | 08-02-2009 09:25 PM |
