Old 09-26-2010, 01:14 PM   #1
BWProductions
StormTrooper
BWProductions's Avatar
Drives: SW 2SS/RS Vert with Beige top soon
How to install RKSport Spoiler?
Does anyone know how to install the RKSport spoiler or any aftermarket spoiler? instructions and pictures would be great, Thanks.
BWProductions is offline   Reply With Quote
Old 09-26-2010, 01:28 PM   #2
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
most of them will mount using the factory holes......If you already have a spoiler, you need to open the trunk and you will find that there are some black plastic covers that are on the underside of the deck lid. You need to carefully remove those.........then take off the trunk lid liner.....the glowing escape handle will need to be removed to accomplish this. Now you have to get your head around the thought that if you are going to remove the nuts holding on the spoiler and you drop it into the trunk lid, you will be fishing it out for a while. When I did mine, i used a socket set and just prior to letting the nut come off, i tilted the trunk lid down so if it fell, it would fall out of the hole. There are some variations in the way the factory spoiler is held on. some have a 3m tape adding some spacing under the spoiler to avoid contact with the body. To install the new one, just reverse the steps using some blue loctite on the new nuts/bolts to avoid them falling into the trunk lid. When you remove the factory spoiler, you will notice that there is an extra hole that was used for an alignment pin. Be sure to put some sort of plug in this hole to avoid water from getting into the deck lid.
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
2010 Camaro Pre-Painted CDC Rear Spoiler! All Camaro Colors Available! RPI Designs Exterior Parts & Accessories 42 12-09-2017 11:47 AM
DIY : Install underdrive pulley on 2010 Camaro SS Nine Ball Camaro DIY & HOW-TO instructions & discussions 34 09-30-2013 08:25 PM
To the Admin RE: Factory Spoiler Instructions DYI 10_SS Site Related Announcements / Suggestions / Feedback / Questions 0 08-17-2010 10:49 PM
spoilers? diffusers? AdnanHfuda General Automotive + Other Cars Discussion 6 06-05-2010 12:10 PM
RKSport Camaro - Aftermarket Hood, Ground F/x and Spoiler on it's way! RetroDude 5th Gen Camaro SS LS LT General Discussions 4 07-15-2009 12:49 PM
