Old 10-04-2010, 04:37 PM   #1
pennor
pennor's Avatar
Drives: 2011 2LT - 73 Corvette 454
Question Remote Start doesn't seem to work
I know I have remote start on my Camaro. It's a 2011 2LR/RS that should have all those goodies. After reading the manual it appears that the proceedure should go like this:
  1. Press the remote's lock button once.
  2. Press and hold the remote start button on the remote for two seconds and the car should start.
But, here's what happens... After step #2, pressing the remote start button and holding it for two seconds, the parking lights flash and that's all that happens. Am I missing something? Am I doing something worng?
I can live without the remote start feature actually because the Camaro is always in a garage and you don't want to start it in an enclosed space. But I bought it and it should work. I'd like to know how to make it work should the unforseen ever happen and I want/need to use sometime in the future.
pennor is offline   Reply With Quote
Old 10-04-2010, 04:38 PM   #2
zirotti
zirotti's Avatar
Drives: 2013 ZL1
You have to press the lock button twice for the car to beep, then you can remote start.
zirotti is offline   Reply With Quote
Old 10-04-2010, 04:39 PM   #3
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Sounds like it may be "disabled" in your preferences/personalization menu.?
Tallboy is offline   Reply With Quote
Old 10-04-2010, 04:39 PM   #4
ketel0ne
Drives: Used to have 2010 SGM
Is the hood, trunk and doors closed? I know if the hood is open it doesn't start.
ketel0ne is offline   Reply With Quote
Old 10-04-2010, 04:39 PM   #5
Tallboy
Say "when"...
Tallboy's Avatar
Drives: 11 2LT
Not on mine...
Old 10-04-2010, 04:43 PM   #6
pennor
pennor's Avatar
I didn't know about the 2-push on the lock button, so I just went out in the garage and tried pressing lock twice then start. I got the horn beep, pushed the start button but after 2 seconds the lights flashed and I could hear a selenoid or something under the hood click and that was it. The car didn't attempt to start.
Oh yea, and all the doors, hood and truck are securely closed.
Old 10-04-2010, 04:43 PM   #7
Meltdownaverted
I sell Camaro's
Drives: traded 11 2SS RS SGM for 13 SS 1LE
is your check engine light on? Remote start won't work if it's on
Meltdownaverted is offline   Reply With Quote
Old 10-04-2010, 04:46 PM   #8
pennor
pennor's Avatar
Well yes as a matter of fact it is. Since the car had only 80 miles on it the dealer and I have been fighting a bogus "tighten gas cap" message that then sets the check engine light on. This is something I've posted on in one of the other forum subjects. It goes back in Wednesday for another round of testing, but they can't seem to find it.
Old 10-04-2010, 05:15 PM   #9
ron10
Drives: 2010 2SS IOM L99
i start mine everyday with the remote.
push the lock button one time,then hold down on the remote start until it starts.i know i hold the start button for more than two seconds.
Old 10-04-2010, 05:43 PM   #10
rydahog
rydahog's Avatar
Drives: camaro ss
if the alarm is on..(beep) the remote start is disabled....only one click is required
rydahog is offline   Reply With Quote
Old 10-04-2010, 05:46 PM   #11
GUNIT
RKFDGEO- chicago5thgen
GUNIT's Avatar
Drives: 2010 2LT/RS SIM Auto
Send a message via AIM to GUNIT Send a message via Yahoo to GUNIT Send a message via Skype™ to GUNIT
This is true. It happen with mine. As soon as you clear that code, it will start.
GUNIT is offline   Reply With Quote
Old 10-04-2010, 05:51 PM   #12
mcotton
mcotton's Avatar
Drives: 2010 Camaro
Mine works the same as Ron10. Make sure you have the setup the remote start on your radio in the preferences/personalization menu. I use mine almost daily. Good luck.
mcotton is offline   Reply With Quote
Old 10-04-2010, 06:02 PM   #13
JAB
C_H_E_V_Y
JAB's Avatar
Drives: Velocity Yellow C6 Z06
Happened to my Tahoe ( same basic set up ) Basically in your car on the Miles/Trip menu thingy I cant thin of what to call it right now. Tap through the menu and in options one should be remote start make sure its selected on. ( my tahoe did the exact same thing your describeing ) If thats not it go to the dealer because one of your leads may not be connected right. Also make sure the Parking brake is up idk if that matters but it might just like in the manuals
JAB is offline   Reply With Quote
Old 10-04-2010, 06:03 PM   #14
aet08
Drives: c
is your check engine engine light on?
if it is, remote start will not work.
aet08 is offline   Reply With Quote
Remote Start System Installation – Need Assistance Railcar Camaro DIY & HOW-TO instructions & discussions 27 12-09-2013 05:51 PM
DEI RELEASED C5 Remote Start Bypass strauchpete Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 4 12-08-2011 08:34 PM
New OnStar iPhone app coming soon - Remote Start, Door lock/unlock all included nashstat 5th Gen Camaro SS LS LT General Discussions 210 03-09-2011 12:41 AM
Remote start Problem GUNIT Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 2 04-18-2010 12:08 PM
Remote Starter won't work wvan655614 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 11-26-2009 07:39 PM
