![]() Drives: 2011 2SS RS LS3 RJT Join Date: Sep 2009
Ideal Shift RPM
I did a search and didn't find anything on this, but what are the ideal rpm to shift at in a 1/4 mile? This would be for a stock setup.
Thanks, and kick me if I missed another thread about this... |
![]() Drives: corvette Join Date: Apr 2009
6400RPM for your LS3.
![]() ![]() ![]() ![]() ![]() Drives: 2023 ZLE Join Date: Jun 2009
I would say 5900 without any power drop off.
![]() Drives: 2010 Vette Join Date: Jun 2010
There is no single, "ideal" shift rpm. The idea is to maximize the average HP in each gear. This means (among other things) that the optimum 1/2 shift point will be a bit different than the optimum 2/3 shift point, which is also somewhat different than the 3/4 shift point. Also, two people shifting the exact same car will have different shifting styles and different reaction times (as it relates to the coordinated shifting of the transmission) and thus will start the shifting process at a somewhat different rpm.
So, how is the "optimum" shift point determined? Easiest way is with a dyno sheet from your car and a shift point calculator (do a net search for one), and then with practice. VERY GENERAL rule of thumb? 500-700 rpm above peak, HP. |
#6 | |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
5900 rpm. I would shift about 6400-6500.
#8 |
![]() ![]() ![]() Drives: 2017 ZL1 Join Date: Dec 2009
Doesn't the LS3 start to redline at 6200 rpm?
I usually shift at 6k just not to take the motor into red line. Am I wrong for doing this? |
#9 |
Moderator.ca
moved to driving techniques forum
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#10 |
ls3 redlines at 6600
| Super Sale on Raptor Shift Lights @ KY SPEED | FRCBobby | Audio / Visual / Electronics/ Gauges / Nav | 44 | 11-25-2011 10:34 AM |
| what rpm do you guys (m6) shift at? | Gunsmoke | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 26 | 04-10-2010 01:36 PM |
| High Performance Exhaust | AntmanZ28 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 94 | 08-22-2009 02:16 PM |
| Most effiecient rpm to shift at? | francone13 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 9 | 07-21-2009 11:19 AM |
