Old 10-10-2010, 09:16 PM   #1
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Whipple Install Questions
I'm getting ready to purchase but I have a few install questions, I'm hoping someone can answer, these involve pinning the crank.
Q1:
Install both .251 dowels into the holes. NOTE: Make sure that when the dowel is installed it is LOWER than the HARMONIC BALANCER. The dowel should NOT touch the harmonic balancer when INSTALLED.
I'm not sure what they mean by this, do I push the dowels all the way through? Aren't they there to hold the crank pulley in place? Will this be more obvious to me when I install?
Q2:
Installed ARP bolt. Torque to 240 foot pounds. NOTE: On the 6 speed car apply parking brake, shift car into 1st gear and have a assistant apply the brakes to torque the bolt. On the automatic trans car unbolt the starter and install GM KENT MOORE J45059 tool to torque bolt.
I have no idea what this means or what this tool is, is this something I can rent, will it be self explanatory? This seems optional to installing the OEM bolt if so is there a benefit to using the ARP bolt?
bigsquirrel is offline   Reply With Quote
Old 10-10-2010, 11:27 PM   #2
rtkjadams
Drives: Red Jewel SS
Q1:
Q2:
Q1: Just push the dowel pins all the way in until they bottom out..... make sure you have the drill on low speed and stop and oil the bit often...
Q2: If you have an auto, you need a way to stop the flex plate from turning... No you can not rent the "J" tool... On Lightnings we would make up our own tool using flat steel with some slight bends, that would bolt up to converter using one of the exiting bolts and the other end to the bell housing, using an exiting bolt. BTW, if you have a 6 speed car, it works better if you put the car in 4th gear. When I had the car in 1st gear, the brakes couldn't hold the tires from turning, but 4th gear would.....
Ray
rtkjadams is offline   Reply With Quote
Old 10-11-2010, 12:04 AM   #3
bigsquirrel
Thanks, If I use the OEM blot can I avoid using the J tool? The instructions made it sound like this was optional.
Old 10-11-2010, 02:22 PM   #4
bigsquirrel
Got some answers from Whipple, the tool # was wrong it's J42386-A a flywheel holding tool like rtkjadams referenced. That makes much more sense, and it's only $80.
Old 10-11-2010, 10:43 PM   #5
tandtperformance
tandtperformance's Avatar
Drives: 2010 Camaro 2011 PACE CAR 2012 ZL1
Send a message via Yahoo to tandtperformance
use the arp bolt with some red lock tite and a 1/2inch impact thats all you need
tandtperformance is offline   Reply With Quote
Old 10-11-2010, 10:44 PM   #6
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
Old 10-12-2010, 12:28 AM   #7
bigsquirrel
Originally Posted by GEEo View Post
I haven't bought it yet, working through the details before I buy. I'd hate to buy it and then figure out I don't have the right tool etc.
Old 10-12-2010, 12:33 AM   #8
bigsquirrel
I have a battery powered hitachi impact it's rated for 1240 inch pounds, is that enough?
Old 10-12-2010, 01:53 PM   #9
rtkjadams
NO WAY!!!!!
Old 10-12-2010, 05:02 PM   #10
bigsquirrel
I ordered the whipple, thanks tim!
Old 10-12-2010, 05:04 PM   #11
bigsquirrel
Originally Posted by rtkjadams View Post
NO WAY!!!!!
That's over 100 foot lbs. More than the instructions call for.
Old 10-12-2010, 05:06 PM   #12
GMRULZ
GMRULZ's Avatar
Drives: 2010 SS & 2008 C6
Damn good choice! Nice guy you are getting it from as well.
2010 SS L99, 536rwhp 10.843@126.72. Whipple Supercharger stock pulley, ARH 1 7/8 longtubes w/ catted xpipe, magnaflow 3" mufflers, ADM Race CAI, 3:70 gears, lightweight wheels and nitto drag radials. Stock internal L99, stock converter.
Bolt on best before blower 12.22@113.29 w/ nothing but ARH headers, catted x-pipe, ADM CAI and a tune on stock Pzero`s!
Other car 2008 C6 Ls3, z51, A6, Npp Exhaust, best bonestock pass 11.80@118.82, Number 2 on the Corvette Forums Bonestock fastest list..
GMRULZ is offline   Reply With Quote
Old 10-12-2010, 07:13 PM   #13
McBeevee
220/221 whatever it takes
McBeevee's Avatar
Drives: See sig....
You stated in your first post that the instructions call for 240 foot lbs. That is a lot more than what you claim your cordless gun to be (1240 inch lbs). I'm confused.
Brent
2022 BMW X5 M50i
2022 Ram TRX
2021 GT500 CFHP
2016 Challenger Hellcat A8 1058whp/898wtq
1970 Chevelle SS396 4spd
McBeevee is offline   Reply With Quote
Old 10-12-2010, 07:35 PM   #14
bigsquirrel
oh you are right. I'll be doing that by hand then
DIY Hurst Short Throw Shifter Install - Pix and Video TAG UR IT Camaro DIY & HOW-TO instructions & discussions 121 02-26-2015 11:08 AM
To Sound deadener and Install questions. Dmundz Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 8 06-02-2010 09:43 PM
Do you have 2010 Camaro Mod Newbie Questions? Step inside MoranoRacing 5th Gen Camaro SS LS LT General Discussions 32 06-02-2010 12:22 PM
Afterburner kit install questions chrislhardin 5th Gen Camaro SS LS LT General Discussions 18 04-26-2010 02:30 PM
