Old 10-12-2010, 08:52 PM   #1
bigwayne3000
Drives: 2011 Camaro LS
******** dual sub box question
Ok I'm looking to purchase the ******** dual enclosure box for a LS camaro. I have never bought subs etc before so I have no idea what Im looking for. How do I know if the subs I want/get will work positively with the enclosure? Also, is it adviseable to hook up subs to the factory LS set up? Will I need to get any wiring harnesses or anything?
bigwayne3000 is offline   Reply With Quote
Old 10-13-2010, 03:39 AM   #2
2010SSRSM6
2010SSRSM6's Avatar
You will need an amp wiring kit and a Line out converter.
Each sub has a specific volume of airspace it requires for the type of enclosure you are using. ******** boxes are "sealed" so find a sub that will work in the airspace provided by that box. Each sub maker should list the airspace requirements on their website.
From ********s website: Mounting Depth: 8.75" Volume: 1.1 cu.ft per sub
Make sure your subs fit both specs. No deeper than 7.25" (allowing for 1.5" of box depth due to the wood used to make it) and can work with 1.1 cu.ft of airspace in a sealed box.
If I am incorrect in any info, I'm sure there are those way smarter than I who will get you back on track. Good luck with the build.
Old 10-13-2010, 10:05 AM   #3
bigwayne3000
Awesome, thank you. Now it doesnt have to be exactly 1.1 cf just so long as the subs dont exceed that correct? Like I can get a sub thats 1.0 cf and be fine?
Old 10-13-2010, 01:10 PM   #4
mrray13
Drives: 2010 1LT RS Rally Yellow
Actually, looking for a sub that's suitable for 1ft^3 net would be excellent, as the ******** will be 1.1ft^3 before sub displacement. Of course, .2 tenths isn't really going to matter in a daily driver.
I'd look for a sub no deeper then 7-7.125" as well, give it some breathing room. Don't really want the sub's motor resting on the wall. It will affect the cooling.
mrray13 is offline   Reply With Quote
ported subwoofer box that fits in the trunk? 1badtie Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 24 10-16-2011 09:09 PM
Another engine/fuse box/air box paint project Bumble_Bee Camaro DIY & HOW-TO instructions & discussions 21 06-13-2010 09:09 PM
Bloom energy box enables off-grid living 2ndgenz28 Off-topic Discussions 13 02-24-2010 06:25 PM
Dual exhaust on third gen. Dartht33bagger 3rd Generation Camaros 3 02-07-2010 04:30 AM
Home theater in a box question Dave McFly Off-topic Discussions 31 01-26-2010 07:08 PM
