![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 Procharged SS Join Date: Oct 2009
Has anyone tried this yet?
Can anyone explain how this works exactly?
![]() Drives: Orange SS/RS W/ White Stripes Join Date: Feb 2010
Dont know that specific piece but we had an MSD 2 step module on our car race before switching to an MSD 7-AL3. It allows for a rev limiter setting for max RPMs while going down track in case you miss a shift or hold a gear to long (should get a shift light) and allows you to set and hold a lower rev limit while at the starting line, usually triggered by holding the trany brake button but you could hook it to a line lock/roll control as well. If your not drag racing you really dont need it. If you want to be menacing lined up next to a Mustang at a red light you could come up against the rev limiter, he would think twice about wanting to try you! JK
![]() Drives: Black RS/SS M6 Join Date: Jun 2009
This sound kinda like the competion mode that the car came with.
![]() Drives: 2009 Cobalt SS/TC Join Date: Sep 2009
But the aftermarket ones have the ability to be adjusted. Say your on dr's, you dont need to launch at 4500rpms. You are able to set it at 22-2500 to get a better smoother launch.
2009 Cobalt SS/TC: 10.89 at 133mph
#6 |
Go Blue!!!!!
Drives: 2012 Cruze LT Join Date: Mar 2009
#7 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Sounds just what I need to get consistent launch rpm. $219 at jegs. i will have that installed for September Street Legals when the cherry DA returns.
#8 |
In The Circle
#9 |
In The Circle
Called MSD tech. Upper limit is 9900.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
He didn't say it was the upper limit. What he was saying was that you could set it there, 2500, for a smoother launch. The factory rev limiter is 4500.
This device is all about consistant launches and that means lower 60ft times, if set right. Grab some DRs, go play at a tree. Find the sweet spot, set the limiter. Next time at the tree, stage, foot on brake/clutch, gas pedal to floor...green light(well, last yellow, depending upon tree), remove left foot! |
#11 |
In The Circle
Got DR's and all the BMR stuff already. 2 step makes life easier. Already ran 12.35 @ 113. On the fast list. 2 step already ordered. Way cool.
#12 |
Will this work on both an M6 and A6?
#13 |
There is something you can get for a stalled auto. Won't work well if at all on a regular stall the car comes with.
#14 |
Drives: 2010 1SS Join Date: Jan 2010
We have one on our Project TriloG test car and it works great. Spend the money, you won't regret it!
| Hurst BFGoodrich Redline Series Turbo Camaro V6 Announced | Tran | 5th Gen Camaro SS LS LT General Discussions | 112 | 05-29-2011 11:33 AM |
| Cant wait Granatelli Racing Parts | BATOUTOFHELL | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 39 | 08-23-2010 09:14 PM |
| P0300 Misfire Code Help | black-knight | 4th Generation Camaros | 4 | 02-08-2010 02:45 PM |
| Holley LS Fest, September 10-12, 2010 | Pro Stock John | USA - Great Lakes | 1 | 01-28-2010 09:18 AM |
