10-14-2010, 11:53 PM | #1 |
Drives: 2010 Chevy Camaro, IBM/LT1/RS Join Date: Sep 2010
Peeling out
I'm not stupid, I know how to peel out, however, this car just won't do it.
Traction control is off, brake on, gas on, slowly let off brake, slight fishtale, let off brake and... nothing. No squeal, no nothing. Lame. I don't try to do it very often, but you know, there are times that call for it. Tonight called for it and I ended up looking like a chick that doesn't know how to drive. What am I doing wrong? I've never had a problem doing this before. |
10-14-2010, 11:56 PM | #2 |
Drives: 2LT/RS Black Join Date: Aug 2010
I can peel out alot in mine. Try using the sport mode and pedal all the way down. Then let off brake and watch the magic. Wouldnt try it too much tho bad on brakes and tires
10-15-2010, 12:04 AM | #3 |
Drives: Wagon Queen Family Truckster Join Date: Oct 2009
call me, then slap one of these babies on... you will have no problems after that (I know, it probably won't bolt up to a sixer)
Seriously though, I have seen many threads where people have this trouble. For example, this one or this one, or this one (2 pages) |
10-15-2010, 12:55 AM | #4 |
Drives: 1SS Camaro Join Date: Sep 2010
That supercharger looks sick Paul.... Dammmnnnn
10-15-2010, 01:04 AM | #5 |
Drives: 2006 White Corvette Convertible Join Date: Feb 2010
Are you in an automatic? I didn't know there was a trick to it. In my Formula 350 I just stomped the pedal and shit hit the fan.
The lack of torque in our cars probably means that you can't do that in an automatic. Right?
The Corvette is an animal.
10-15-2010, 05:56 AM | #6 |
AwesomeBillDawesonville
Drives: CGM 2SS/RS =) Join Date: May 2009
Not His, it's your large rims and summer tires. They stick like crazy it's a good thing but I hear ya.
Order placed on 1/13/11 - Purchased 2/22/11 2SS/RS CGM |
10-15-2010, 07:46 AM | #7 | |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
But addressing the OP, why would you want to spin the tires? The goal for quick acceleration is to NOT spin. Get the power to the ground with little or no spinning is the goal we spend thousands on.... |
10-15-2010, 07:52 AM | #8 |
Drives: 2010 2SS/RS IBM Black Polished Join Date: Feb 2009
Install some line locks. Depress the brake, turn em on release the brake and press the gas. Or you will need to do some wieght shift by rolling out a bit then tap the brake to shift the wieght forward off the rear end. Must admit I have never tried a v6 Camaro but have done it with far less powerful cars.
418 Stroker, 621RWHP 648 lbs TORQUE Built by Laramie GM Auto Center Tuned by Nick at Mac Autosport. EForce SC, 2 3/4pulley,LPE dual fuel pump, JRE Twin fuel rail upgrade, posi clutch kit, RX oilcatch can and breather, Callies Compstar crankshaft and rods, Racing bearings, CP -13.8 race pistons, steel rings, Comp Cams X6 blower cam, Springs, HD timing chain and tensioner, Doug Thorley Tri Y LT headers, 89.7lb injectors, RPM rollbar, DSS1400 shafts, Simpson 5 pt harness, BMR Toe rods and trailing arms, led lights, RPM input and output shafts
10-15-2010, 08:05 AM | #9 |
Drives: 2013 AGM 1SS/RS 1LE Join Date: Jul 2010
Just beautiful!!!! If I only have the money.
Can you share any specs and info on integrating this to the l99?
2013 Ashen Grey Metallic 1SS/1LE, NPP, Camera
(1 of 43 produced) |
10-15-2010, 08:27 AM | #10 |
Drives: 2012 ZL1 - #670 Join Date: Jun 2009
Another one you may want to consider is the Edelbrock E-Force ... It's looks and performance is basically the same as the OEM LS9 setup. And I've seen them listed as low as $5500.00 ...
10-15-2010, 08:35 AM | #11 |
The Milano
Drives: 2017 Firefly ShipWorks Join Date: Jun 2010
The 19 wi thall season tires spin like crazy. No hookup at all. If you like that sort of thing switch out youR rs tires for the 19ers.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter. |
10-15-2010, 08:36 AM | #12 | |
Who the heck doesn't like a good 'ol roasting of the tires. Especially when the tires aren't yours. Haha
10-15-2010, 08:55 AM | #13 |
Commits weekly crime
V6?
2017 Camaro 1LT - Blue Barchetta IV
I fire up the willing engine, responding with a roar. Tires spitting gravel I commit my weekly crime. |
10-15-2010, 09:04 AM | #14 |
Emerald Coast Camaros
Drives: 2010 Camaro 2LT/RS M6 Join Date: Nov 2009
Similar Threads | ||||
GM not honoring my Camaro paint warranty; paint cracking and peeling all over the car | jackr67 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 132 | 08-03-2010 09:50 AM |
paint peeling? | Amn_Bly | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 07-29-2010 05:14 PM |
Request for Copy of TSB 09-08-51-005? (Peeling Paint) | Hicompression | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 15 | 07-14-2010 11:04 PM |
Paint peeling at corners of bumpers | FirstCamaro2k10 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 26 | 06-22-2010 04:26 PM |
Peeling paint | Mrhavasu | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 3 | 09-28-2009 05:54 PM |
