Old 10-18-2010, 01:08 PM   #1
OPP
OPP's Avatar
Drives: 2018 MBM ZL1 Auto
Approach angle stock vs dropped
Does anybody know or has anybody measured the SS approach angle stock vs dropped 1 inch?
I want to drop my SS (when I get it) but I want to know if I'll be scrapping my bumper everywhere I go.
Just in case; The approach angle is the angle between the ground and a line running from the tire to the front bumper (as viewed from the side).
Thanks.
OPP is offline   Reply With Quote
Old 10-18-2010, 01:10 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
I have Hotchkis springs (about 1" drop) and I've only scrapped ever so slightly on a big speed bump. Other than that there's been no issues.
Build Journal
Old 10-18-2010, 01:11 PM   #3
2010SSRSM6
2010SSRSM6's Avatar
I have the GFX kit and dropped it 1.2" with the Eibach kit (springs and sways) and haven't had an issue with dragging on anything.
I haven't measured the height, but it will still pass over a standard parking stop without scraping. The little flap that sticks straight down doesn't much care for that though.
Old 10-18-2010, 07:03 PM   #4
sfgiantsfan9
Drives: Camaro 2SS/RS and 2001 Ford F250
Im curious to this as well as I am looking to drop the car 1.4" (H&R) and want to know if I will still be able to drive onto ramps and lifts to do exhaust work etc. Any input?
sfgiantsfan9 is offline   Reply With Quote
Old 10-18-2010, 07:13 PM   #5
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Red face Parking block abrasions
Thanks.
Even leaving it all stock, if ya' drive right up to touch your front wheel to a parking space block, low as it is, it'll scratch the bottom edge of the front lower bumper. I got the marks on mine. The good thing is that you never notice 'em until you put the car up on a lift.
Ivas is offline   Reply With Quote
Old 10-18-2010, 07:15 PM   #6
68vert
68vert's Avatar
Drives: 2010 SIM SS/RS, 1968 RS convertible
I have Eibach drop springs and long tube ARH headers. I no longer pull up to curbs of any kind. Header flange will scrap on the higher speed bumps, parking lot entrance/exits, if I do not go across at a angle. I have the standard stock 20" rims/tires.
2010 SIM SS/RS see garage for mods
68vert is offline   Reply With Quote
Old 10-19-2010, 08:22 AM   #7
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
Lowered rear 1 1/4" - normal driving ok - stay out of the 'dealers free car wash' - got hung up ever soooo slightly on the front exhaust clamp.
ADIO SS is offline   Reply With Quote
Old 10-19-2010, 08:35 AM   #8
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Anytime you lower your car, you need to relearn how to go over bumps and park. It isn't car specific, just common sense stuff. Take ALL bumps at an angle and NEVER pull all the way up in parking spaces that have a curb or bump stop. Any uneven driveways should also be taken at an angle. Even at stock height, my car would rub the lowest edge when going straight into my driveway. At an angle, it was no problem. Now that i'm dropped ~1.25in, I can still angle it in without rubbing. Straight in would be disasterous though.
With the amount of cars that are "slammed" from the factory, any decent alignment shop, muffler shop, or shop with lift will have a way to raise the car up to go onto their lifts. It may be professional ramps or 2x6's, haha.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 10-19-2010, 10:11 AM   #9
Dion_1969
Dion_1969's Avatar
Drives: ABM 2SS/RS LS3
Send a message via Yahoo to Dion_1969
I have BC racing coilovers and went 1 1/2" front and 1 3/4" back. My quarter flares have not appreciated the drop. I think I have scraped all 4 now on speed bumps. They hang a bit lower than my catalytic converters. I worry about what will happen when I put long tubes on. I also scrape the front on steep drives unless I take a pretty severe angle. People on here have posted instructions on building an approach ramp for your ramp to allow you to pull a lowered car on car ramps.
Those who fail to learn from history are condemned to repeat it- George Santayana
Dion_1969 is offline   Reply With Quote
Old 10-19-2010, 11:09 AM   #10
2010SSRSM6
2010SSRSM6's Avatar
At 1.2" of drop my small floor jack still fits under my car. I have to go through the wheel well, then slide it to the lift points, but it still fits. If you take the same aproach with a post lift you will be ok.
Old 10-19-2010, 06:36 PM   #11
OPP
OPP's Avatar
I know all these tricks with my lowered 328 but there's always a steep entrance somewhere that you just can't drive in at an angle and that's what worries me. Also the wife factor.....
DIY Noweeds exhaust diverter installation CanadianCamaro Camaro DIY & HOW-TO instructions & discussions 42 08-15-2016 12:11 PM
FS: Stock parts from 1SS M6 (LS3) Cataula15 V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 0 09-10-2010 07:46 AM
(Stock Camaro ss m6 vs Stock 04 Cobra mustang m6) dshep214 Chevy Camaro vs... 28 08-23-2010 10:47 PM
Kirk Kerkorian KILLER74Z28 General Automotive + Other Cars Discussion 10 12-01-2006 05:11 PM
