Old 10-20-2010, 02:52 PM   #1
Zakath
Nefarious
Zakath's Avatar
Drives: 2010 CGM 2SS/RS
Borla S-type catback turning gold at tips
Anyone have an issue with exhaust tips starting to blue from heat? I asked Borla about it and got:
"Thanks for the photo. Stainless steel will change color due to heat. This change in color turns to a gold tint is most notable inside the tip.
Most of our tips are double-walled to insulate the outer wall from heat. I suggest using our Borla polish once a month to keep it looking great.
I do this on my 3-year old exhaust and while the color is only slightly golden, keeping it shiny makes it look new.
Enjoy your Camaro!"
My camaro is stock under the hood except for the Borla Catback system. No tune, stock airbox, stock everything. I have had my exhaust since January of 2010 AND I only have 13,000 miles on the car total since October of last year, and maybe 7,500 of that is since January when I got the exhaust, so I don't feel like I am driving nearly enough for this to happen if it were going to happen at all over the life of the exhaust.
I'm just curious in seeing if this is an issue for anyone else?
Forgive the fact that my car needs a wash in this picture, but if you compare the exhaust tip to the color of the tail light bezels you get a sense of the gold discoloration. I noticed it a few months ago and it has grown steadily worse, although the picture looks pretty mild (I just don't want it to get worse). I understand the concept of heat discoloration, it just seems like tips that are so far back in the exhaust system and the idea that they are double walled specifically to resist heat discoloration should be keeping them from turning gold like that. Not even getting into how little and conservatively I drive my car.
Thanks for any replies I get
Zakath is offline   Reply With Quote
Old 10-20-2010, 03:03 PM   #2
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
Most stainless tips will look like that (or worse) inside.
MarylandSpeed is offline   Reply With Quote
Old 10-20-2010, 03:09 PM   #3
Zakath
Nefarious
Zakath's Avatar
I agree, but the outside of mine is starting to discolor too. Is that normal given my circumstances?
Old 10-20-2010, 04:33 PM   #4
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Mine was turning really bad. I have a MBRP system. They sent replacement tips ASAP! I don't care about the inside. They are black from carbon anyways.
http://www.camaro5.com/forums/showthread.php?t=101372
HeavyD is offline   Reply With Quote
Old 10-20-2010, 05:27 PM   #5
Zakath
Nefarious
Zakath's Avatar
Thanks for linking that. Did they suggest anything to you to prevent it from happening again?
Old 10-20-2010, 06:22 PM   #6
bkscott
bkscott's Avatar
Drives: 2010 Camaro 2SS/RS
Well I ran a Borla on my 4th gen but it had the Intercooled tips, and while they were black on the inside they stayed stayed clear on the out side.
I have the Borla Type S axel back and noticed the same thing. I used some metal polish on them, and while it helped they are still not clean.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10.
ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller.
bkscott is offline   Reply With Quote
Old 10-20-2010, 06:45 PM   #7
ron10
Drives: 2010 2SS IOM L99
i have no problem with my stock tips.they look like new and the car is 14 months old.i wipe out the inside of my tips,so they also shine.
Old 10-20-2010, 08:19 PM   #8
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Stainless exhaust will discolor but it isn't permanent like with chrome. Just hit it with some Blue Away and polish, they will be like new.
Old 10-20-2010, 08:32 PM   #9
mrvenicess
mrvenicess's Avatar
Drives: 2013 CRT ZL1 auto
Autosol, a German metal polish works great. Rub it on and work it in with a toothbrush then polish with a soft cloth. You can buy Autosol in some stores or from antique dealers. Just Google it.
mrvenicess is offline   Reply With Quote
Old 10-20-2010, 08:48 PM   #10
Zakath
Nefarious
Zakath's Avatar
Perfect! Thanks guys, I really appreciate the info.
Old 10-21-2010, 09:13 AM   #11
ITGuy11
Burning up tires
Drives: 2023 ZL1 Vert
Yup, Autosol and Blue Away will make those tips look new again.
ITGuy11 is offline   Reply With Quote
Old 10-21-2010, 09:55 AM   #12
Duke
Duke's Avatar
Drives: 2010 Red SS/RS
I use Mother's Metal Polish on mine about once every 2 months. In between I give them a good wipe every other day to remove the carbon and water spots. I love good looking tips.
Duke is offline   Reply With Quote
Borla S type catback video Ltdodge Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 23 03-20-2023 08:44 PM
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
Borla S type axle back pics Ltdodge Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 08-03-2009 12:09 PM
Borla Headers + Borla S Type Exhaust DON GIOVANNI Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 05-05-2009 11:56 AM
