![]() Drives: the wife crazy talking Camaros Join Date: Aug 2010
Installation tips and measured sound levels for Lt Headers w/ cats
First I want to thank Maryland Speed, for great service, prices, and fast shipping. My Kooks headers shipped within an hour of the order being placed. I was emailed UPS tracking info promptly.
Install tips. Tools needed: 3/8” air ratchet ½” impact driver with ½” to 3/8” socket adaptor 13mm, 15mm, 9/16 sockets (short and deep all sizes) 9/16”, 7/8” combination wrench Oxygen sensor socket (Oxygen sensor socket is cheaper than a replacement oxygen sensor) 10”, 6”, 3”, 1” 3/8 drive socket extensions 18ft lbs. torque wrench Tin snips (to trim corners of the header gaskets) Anti seize compound (For header bolts and oxygen sensors) Heat gun 4 good jack stands and floor jack. Tips: 1) Remove rear oxygen sensors with 7/8 wrench or oxygen sensor socket when the car is hot. I was unable to remove one rear sensor and had to replace. ($70 from dealer) 2) Remove cat assemblies, then use heat gun to heat up pipes before removal of front oxygen sensors 3) Use OEM manifold bolts to get things started, then switch out to Kooks supplied bolts 4) You will need two people to reinstall oil dip stick. (One up top and one from underneath) 5) If you buy Kooks you do not need to disconnect steering shaft. 6) You do not need to remove spark plugs. 7) Reuse stock manifold gaskets. 8) Re-torque header bolts after 1000 miles. Sound levels: Note: I already had GMPP axle back installed Before/after Idling open hood 74 dB/83 dB 1 meter from exhaust tip idle 85 dB/ 89 dB Driver’s seat idle with windows down 76 dB/80 dB 3000 RPM 1 meter from ext tip. 90 dB/93 dB 3000 RPM decelerating to idle 96 dB/98 dB WOT not measured but it does sound great. My other car for comparison Chrysler 300C Driver’s seat idle with windows down 65 db 1 meter from exhaust tip idle 68 dB 3000 RPM 1 meter from ext tip. 76 dB |
One other tip, blow out the header pipes with compressed air before installation.
![]() Drives: 2010 CGM 2LT / RS, Blk 1SS/RS Join Date: Sep 2009
Thanks for the tips. Im Installing the LG pro headers and exhaust Friday.
Two more tips, spray WD-40 on cat assy to manifold studs. Use 1/2" impact driver to remove nuts.
Place a temporary shim between mid muffler/resonator and cross support during cat installation to keep resonator from touching cross support after installation. I just used a handle from a pair of pliers. |
What did you torque the headers bolts to. Thanks
#6 | |
Drives: '15 Z06, '01 NBM SS, '97 SS Join Date: May 2009
WD40 on all the joints is a blessing on ANY catback/exhaust install. It allows for some really good lubrication and corrosion prevention. Good luck with everyones installs! ![]() Ivan @ Southwest Speed |
#7 |
#8 |
Thanks
#9 |
Your tips are quite informative.
I always wanted to upgrade my Camaro, but was not getting proper tips. So thanks for helping me.
#10 | ||
I do not have one, I would say less than 18 ft lbs. I just tightened down the cat to header bolts about half way down the threads, then tightened down the band clamps. Then I used a soapy water spray bottle and sprayed down the connections looking for bubbles to indicate leaks. I did not find any leaks on my install. |
#11 |
Joey
Drives: 2011 Camaro 2SS/RS L99 Cyber Grey Join Date: Feb 2017
So I dug up this old post, I just bought a 2011ss l99. Is anyone having problems removing exaust manifold bolts? Should the heads be hot or cold when removing bolts? My silverado was a nightmare!
Sent from my VS985 4G using Tapatalk
2011 Cyber Grey L99 SS/RS- 3.91 Gear
MRR 228 Wheels-Hurst shifter/base plate LT Headers no CATS-Magnaflow 16582 Axle Back RoboFab intake-Dyno Steve tune ZL1 Rocker Panels-SLP Splitter Lowered on Phastek springs Pray Performance ported TB |
| Tags |
| lt header tips sound levels |
