Old 10-22-2010, 10:41 AM   #1
Dangeruss
Bayoucitymusclecars.com
Dangeruss's Avatar
Drives: Camaro LSX
Powering my lights for car shows...need help
Hey guys. I have an AAC lighting package, but want the ability to keep the lights on for car shows and street meets. I've heard I can use an RV inverter, (or is it converter?) but I'm not sure which one to get. I'm assuming I won't need too much power since I'm only dealing with LEDs. Any ideas?
Thanks in advance.
Old 10-22-2010, 10:51 AM   #2
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
then where are you going to plug the extension cord ? lol . you can leave all your led's on a long time before it drains your battery just dont leave your hid's on.
2010 Hennessey HPE650 2SSRS Blk/Blk
Magnuson TVS2300,ported heads,cam,Hotchkis suspension. Weld 17”s, Mickey Thompson’s.
klatterblast is offline   Reply With Quote
Old 10-22-2010, 10:57 AM   #3
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
My lights are hooked to my parking lights, and when you leave them on the car turns everything off after 10 minutes. My understanding is that RV converters store power so you don't need to plug in. I think this is what AAC uses for their vehicles, but I'm not sure which one to get.
Old 10-22-2010, 11:24 AM   #4
klatterblast
AAC has an extension cord hanging from the back of there car, i saw it when i was there getting lit up. call AAC and ask them about it, they will help you.
Old 10-22-2010, 11:27 AM   #5
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
I know they have something, because they weren't plugged in at all in the hotel parking lot at Camarofest. They told me they used some sort of internal power converter in their big truck, but I don't remember what it was. Maybe they'll see this thread and chime in.
Old 10-22-2010, 05:08 PM   #6
Gotthat02fire
Gotthat02fire's Avatar
Drives: 2010 Camaro 1ss IOM
I'm also intrested in this but my show season is over and my Camaro is starting to be torn down again so this would be great timing for any additional wiring that may be needed!!!
Jannetty Racing Built and Tuned
416 Maggie Max Package even better now!
Gotthat02fire is offline   Reply With Quote
Old 10-25-2010, 12:34 AM   #7
agkelly73
agkelly73's Avatar
Drives: 2016 SS Convertible
Guys, I have AAC halos as well and needed a solution similar. I purchased an "on, off, on" switch which you can pick up from any auto store. I then rewired my lights into that switch. One side on allows the lights to run with the normal headlight switch. The other side "on" allows me to run them constantly during car shows. Just tie it to a constant hot source. I can explain later a little better as I'm on the road right now.
Sent from my SCH-I500 using Tapatalk
agkelly73 is offline   Reply With Quote
Old 10-25-2010, 02:21 PM   #8
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
Yea...I looked into this option as well, but I want to be able to power everything. I have headlight and foglight halos, side markers, taillights, and Showstopper mirrors. I think what you're talking about would only power the headlight halos right?
Old 10-26-2010, 10:21 AM   #9
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
I would have the car rewired to have the option to be turned on via parking lights or via constant 12 volts (through an on / off switch in the car). This can be accomplished with diodes. If you ask someone who knows how to do wiring this can be done and LED's will not drain the battery.
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 10-26-2010, 06:12 PM   #10
Kendell347
Doc
Kendell347's Avatar
Originally Posted by AACstyle View Post
The parking light timer is ground-switched. Putting 12V constant to it will not help in this case.
Actually I was recommending two different circuits so they function during driving and separate when on for show. It would require additional wiring.
Old 10-26-2010, 06:16 PM   #11
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
Russ, you need to ground the headlight switch.
I would take a pic for you but the car is back in the body show getting the door jambs cleared before SEMA, will get a pic for you and a diagram though!
Thanks Justin. I want to run everything including the side markers, taillights and bowtie. What's that big power supply you guys use for the truck?
Old 10-26-2010, 06:21 PM   #12
Noturday
[Not-your-day]
Noturday's Avatar
Drives: 2005 Avalanche
advance auto parts (and i believe others) have a 4 function wireless switch setup (im running one in my truck) for $30 and it works great, you could use one function for the halos, one for your mirrors, one for side markers and one for taillights. wiring each of them individually may be a little difficult, but for the box all you need is a constant +12 and a ground, then there are color coded wires for each of the 4 functions.
on my truck im only using 3 functions now, one for exterior glow, one for interior, and one for head/fog lights. still trying to come up with something for my 4th function....maybe radio.....
Noturday is offline   Reply With Quote
Old 10-27-2010, 04:07 AM   #13
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
If this is something that can be accomplished in a day or two with very limited electrician experience, I'm down too. I want to show off my sidemarkers/P13W at SEMA.
Old 10-28-2010, 12:01 AM   #14
Dangeruss
Dangeruss's Avatar
Drives: Camaro LSX
We have this 30A unit in the Camaro and in the Truck.
Look at page #16 of our catalog:
http://www.automotivelightstore.com/...cleCatalog.pdf
Thanks Justin. That's what I was talking about. Now the million dollar question...how would I hook it up? Would I need to rewire everything?
Angel Eye Mod (93-97 Camaros) CamaroSpike23 4th Generation Camaros 105 05-12-2014 04:17 PM
Unlock Feedback Lights BilJ Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 8 12-08-2010 06:51 PM
Which Interior lights are these. martinezj454545 Cosmetics and Lighting Modification Discussions 4 10-22-2010 06:41 PM
How do I get my Fog Lights to act as my Day time Running Lights??? Camaro Freak 5th Gen Camaro SS LS LT General Discussions 8 10-12-2010 05:16 PM
Unlock Feedback Lights BilJ 5th Gen Camaro SS LS LT General Discussions 8 09-20-2010 03:55 PM
