10-27-2010, 07:46 PM | #1 |
Drives: 2011 Victory Red Auto 2SS Join Date: Aug 2010
Any one have a copy of the AFM system?
Can anyone point me to a site where I can find a copy of the circuit used to control the AFM system?
10-28-2010, 09:13 PM | #2 |
Motor Head
Drives: CTS-V Join Date: Feb 2009
No I can't.
But, if your question is can the AFM system be defeated? Removing power to the lifter control solenoid will keep the valves working - not go into AFM mode. However, that is not a good thing to do because the ECM turns fuel off to the 4 AFM cylinders when it turns off the valve action. AFM needs to be turned off in the ECM for everything to be happy.
History Camaro's: 83, 93, 95, 98, & 10.
10-28-2010, 09:40 PM | #3 | |
I realized that both need to be controlled. Was hoping that a single circuit would turn off the lifters and the injectors. Or at least a separate on or off circuits to turn them off. So that if that circut was disabled, the engine would run on all 8, full time. |
10-29-2010, 04:35 AM | #4 |
Motor Head
Here is a screen shot of the ECM logic. I don't see any way to defeat AFM and still have everything else working.
10-29-2010, 08:07 AM | #5 |
I was hoping that there was a normally closed relay or relays somewhere that when opened, would control turning off the injectors and valves for AFM. But I guess the ECM controls them, at lest the injectors directly.
10-29-2010, 09:32 AM | #6 |
SIP
Drives: 2011 1SS, L99, A6 , Silver Ice Join Date: Aug 2010
Any reason not to just disable the DOD if you just dnot want it kicking in ?
"My Birthday gift from my wife on 10/19/2010 "
10-29-2010, 09:44 AM | #7 |
Don't want to do a tune and loose the warranty coverage. That is the only way I have heard of to disable it. If there is another way, I would like to know about it.
10-30-2010, 05:06 AM | #8 |
Motor Head
Tap shift is the only way stop AFM without a ECM tune. OBTW a trans tune really makes an A6 car great!
Similar Threads | ||||
P0300 Misfire Code Help | black-knight | 4th Generation Camaros | 4 | 02-08-2010 01:45 PM |
Nitrous Outlet 2010 Camaro Nitrous System and Accessories! | Nitro Dave | Forced Induction | 9 | 11-26-2009 11:49 PM |
Tire Monitoring System | monevz28 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 7 | 11-22-2009 03:42 PM |
Why i think you cant do a Dyno in the same day | 2SSRS@Gen5diy | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 123 | 10-22-2009 07:37 PM |
Camaro ls3 news...true or false? | Dark Knight | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 74 | 06-05-2008 05:29 PM |
