Old 10-28-2010, 11:28 AM   #1
Lynch
Lynch's Avatar
Drives: 2011 Black LS
HID headlights, halo rings and running lights
I have 2011 ls. i have the boring stock headlights with no running lights or halo rings. I would like to look into buying these if anyone know of any websites i would greatly appreciate it. I want the Halo rings, with HID bulbs, as well as running lights in the front bumper.
Thanks, for any and all help
Lynch is offline   Reply With Quote
Old 10-28-2010, 11:32 AM   #2
MotorCityTransplant
MotorCityTransplant's Avatar
Drives: 2010 LS Camaro CGM 6M
You can add running lights to your LS by buying the running light housing and new bezel. I used these parts to install running lights on my LS. If you have any questions let me know.
MotorCityTransplant is offline   Reply With Quote
Old 10-28-2010, 12:08 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
BfXenon or AAC.
I think AAC is the only one with halos though. There is also a product some were getting off ebay that looked like it might work.....search on Eagle Eye. I think that was the name.
http://www.camaro5.com/forums/showthread.php?t=69917
Build Journal
Old 10-28-2010, 12:18 PM   #4
turboguy327
Banned
Drives: 2011 Chevy Camaro
You can open your headlights which you will need to do either way. And make your own halos with curtain rods and leds. And get a hid kit from ddmtuning.com. you will have about half of the cost into the project as buying the supplies from other places.
Sent from my DROIDX using Tapatalk
turboguy327 is offline   Reply With Quote
Old 10-28-2010, 12:21 PM   #5
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
Fogs lights should be relatively cheap. To get the same exact look as the RS package headlights or the headlights themselves you will spend a lot.
DarkneSS is offline   Reply With Quote
Quick question about HID and Halo LIghts ttazzijr700 5th Gen Camaro SS LS LT General Discussions 81 01-30-2011 09:43 PM
