Old 10-28-2010, 08:02 PM   #1
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
CEL code just now after 2300 miles since install
Hey just thought I would throw this up and see what people think it might be. Dont have a scanner or anything. Can autozone do it?
Car has 2300 miles since Mods installed and tuned by livernois.
Maggie 8psi
kooks headers
noweeds exhaust
rotofab
bap
ported tb
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
jsharp is offline   Reply With Quote
Old 10-28-2010, 08:16 PM   #2
SC2150
Any auto parts store should be able to scan & clear the code. Post up what it is but I would not be to concerned.
Old 10-28-2010, 08:18 PM   #3
jsharp
jsharp's Avatar
not concerned really but deff dont want it to keep coming on ya know!
Old 10-28-2010, 08:26 PM   #4
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Be smart buy a scanner. Car is throwing a code for a reason, figure out the reason. SC is more than likely right in it isnt a big deal however it it were me I would buy a scanner (I like tools) and figure out what the code is.
Cheers
K
Moriartii is offline   Reply With Quote
Old 10-28-2010, 08:31 PM   #5
jsharp
jsharp's Avatar
what is a good one to buy and where at for how much?
Old 10-28-2010, 08:44 PM   #6
SC2150
Advance auto has some decent ones or around $100. Just make sure it is the latest version as the capabilities are increasing & the prices decreasing.
Old 10-28-2010, 08:50 PM   #7
Moriartii
Moriartii's Avatar
GAK I hate autozone, I usually look at Amazon if you can stand waiting for it to ship to you.
Or if you gotta have one, check out Amazon, narrow down your choices then hit up autozone or better yet Advanced Auto.
Cheers
K
Old 10-28-2010, 10:56 PM   #8
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Does the maggie come with a tuner? If so you probably already have one.
bigsquirrel is offline   Reply With Quote
Old 10-29-2010, 08:27 AM   #9
jsharp
jsharp's Avatar
no had it custom tuned at livernois and didnt receive tuner
Old 10-29-2010, 07:01 PM   #10
jsharp
jsharp's Avatar
P0171
I had it read and turned off at autozone. Guy asked if I just got gas and I did about 30 miles ago and it was lesser quality kroger 93 intead of the shell 93 I had been using. Vehicle was running while fueling to half a tank. I did notice right after I got gas that the car was lightly bucking rolling around in mall parking lot and then another few miles not sure when the CEL was on. I havent got on the car but once since the gas fill up so it may have came on then? I am sure you already know but it listed:
possible causes
oxygen sensor defective
ignition misfire-repair
fuel injector problem
What do you suggest now that the code is off and 1/4 tank of gas left?
Old 10-29-2010, 07:24 PM   #11
SC2150
Fill with good gas. I bet your fine now.
Old 10-29-2010, 07:27 PM   #12
jsharp
jsharp's Avatar
k so should I run it almost out and then put good in or just add good now? Should I stay away from track on sunday or put some of the race gas sold at the track in it?
Old 10-29-2010, 07:31 PM   #13
Supercharged SS
Drives: 2010 Camaro
Run it you biotch!! I'd fill it now with gd gas and run as much as you can through the car. Maybe some 100 at the track will help balance out the remaining bad gas that is lingering after this fillup. I've had to shut cel lights of while sitting in the staging lanes so if it seems ok it probably is. Thats gd is wasn't a major issue!
Old 10-30-2010, 11:24 AM   #14
Frost
Frost's Avatar
Drives: GM anything
p0171 Is fuel system lean bank1. Your tank of gas did not set this code, nor will gas correct it. This code is set because the trim system has extended (heavy positive trimming) past a threshold in it's correction of the driver's side. This is definitely something to look into.
Frost is offline   Reply With Quote
Magnuson 2300 Install - yeah baby! ffrcobra_65 Forced Induction - V8 21 01-28-2010 07:51 PM
Bumblebeecamaro gets supercharged by a Maggie TVS 2300 (plenty of pics inside) bumblebeecamaro Forced Induction - V8 10 01-15-2010 12:11 AM
21CMC 1 of a kind Camaro TVS 2300 install 21STCENTURY Forced Induction - V8 5 11-25-2009 02:08 PM
