Old 10-29-2010, 07:51 PM   #1
Chalk_2
Drives: 2010 Camaro 2SS/RS
Screw in Tire
I just noticed I have a screw imbedded in my right front tire. Its about an inch in from the side wall. Can this be repaired?
Chalk_2 is offline   Reply With Quote
Old 10-29-2010, 07:52 PM   #2
MF2SSRS
Drives: VR 1LE
Just have it plugged up. No need for a new tire.
MF2SSRS is offline   Reply With Quote
Old 10-29-2010, 07:54 PM   #3
Chalk_2
Ok cool. I was thinking the Pirreli's were different.
Old 10-29-2010, 07:57 PM   #4
427Carl
427CARL
427Carl's Avatar
Drives: 2011 Camaro SS 6speed
Send a message via Yahoo to 427Carl
Get it properly repaired! A plug forces the tire apart and it (tire) will separate... Most shops can do a proper high speed rated repair.... don't be cheap...
427Carl is offline   Reply With Quote
Old 10-29-2010, 08:01 PM   #5
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
get it patched on the inside. not real expensive.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 10-29-2010, 08:05 PM   #6
Chalk_2
Got it, Thanks for the help.
Old 10-30-2010, 10:26 AM   #7
ADIO SS
ADIO SS's Avatar
Drives: 2010 White SS/RS L99
On the bright side - the screw may not be that long and penetrated the tire all the way through - has happened to me... Are you feeling lucky?
ADIO SS is offline   Reply With Quote
Old 10-30-2010, 11:50 AM   #8
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
Discount tire will repair this for free
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 10-30-2010, 11:53 AM   #9
xLoGiK1
xLoGiK1's Avatar
Drives: 2010 2LT/RS Camaro
If it's too close to the side wall then it can't be patched. That's what happened to me. I had to get it plugged because it was right on the edge of the side wall.
xLoGiK1 is offline   Reply With Quote
Old 10-31-2010, 01:13 PM   #10
firestone_ss
firestone_ss's Avatar
Drives: 2010 camaro ss
[QUOTE=427Carl;2496203]Get it properly repaired! A plug forces the tire apart and it (tire) will separate... Most shops can do a proper high speed rated repair.... don't be cheap...
never heard of this before.Industry standard is to patch/plug the tire{yes that means both patch and plug not one or the other} and then the tire is no longer speed rated.If this is a 20 in pirelli the tire will not be speed rated the same as the other three.If your not racing the car down a track then you will never notice but if you are replace the tire.
firestone_ss is offline   Reply With Quote
Old 10-31-2010, 02:20 PM   #11
Ron66Vette&10SS
Plays with Hot Wheels
Ron66Vette&10SS's Avatar
Drives: '17 Jet Black ZL1
It may be too close to the sidewall to be repaired. I ran into this with my Z06 a few years back. I took it to a few different places, but they all said it was too close. Supposedly some government standard changed a few years back which changed how much of the tire is considered "sidewall" and unrepairable.
Who knows, maybe you got lucky and it's a short screw that didn't penetrate all the way through.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring)
Ron66Vette&10SS is offline   Reply With Quote
Old 10-31-2010, 06:34 PM   #12
Al
Al's Avatar
Drives: 2011 SS CGM
Screwed
Picked up this screw at Watkins Glen Racetrack. I pulled it, roughed the opening with a tire file, then used contact cement with one of those gooey rope plugs. Hasn't lost air yet (few weeks). Might have the inside patched when the winter wheels go on. Had some snow flurries in the air today, the summer tires are still usable, fun on cold wet parking lots at 37 degrees !!
Al is offline   Reply With Quote
Old 11-01-2010, 12:29 AM   #13
Chalk_2
It is definitely too close to the side wall, after a second look. Thank god I bought the road hazard insurance. I guess I'll take it back to the dealer to have it replaced.
Old 11-01-2010, 11:02 PM   #14
oldfriend
Drives: Fiat 500 E
2SS
WHAT , ARE YOU ON ...... IT IS CLOSER TO THE CENTER THAN TO THE WALL YOU .......:fa cepalm::fa cepalm:
Colorado members check in here 2010 SS RS USA - Rockies / Midwest 8853 06-13-2022 08:45 PM
Tire pressure computer issue UT-Engineer Wheels and Tires Talk Sponsored by The Tire Rack 7 02-13-2012 07:18 PM
Exhaust bolt in tire = bad day GPD151 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 07-30-2010 12:56 AM
Are they rims or are they wheels?? topgun1 Off-topic Discussions 28 07-07-2010 12:02 AM
Ruined Tire scott53 Wheels and Tires Talk Sponsored by The Tire Rack 10 05-20-2010 08:00 PM
