Old 10-31-2010, 07:13 AM   #1
tregwal
Drives: Yellow
20" Foose speed wheels
Whats the widest tires you can run on these wheels on a Camaro ss 20"x 8.5 35mm offset & the 20"x 10 40mm offset.....Can you run the Pzeros 275/40/20 on ftont and 305/35/20 on the back with out rubbing issues.
tregwal is offline   Reply With Quote
Old 10-31-2010, 08:02 AM   #2
edneyens
edneyens's Avatar
Drives: 1SS/RS/M6-White/Beige
I have some other Foose (Legends) wheels where I use 20 x10 with +40mm offset all the way around. I am using the tires you listed 275 in front 305 in back. My car is lowered one inch by after market springs. The front wheel/tire set is the point of concern, close to rubbing on the strut tower - initially I had to take caution on camber adjustments... Later I added Pfadt camber/caster adjustment plates on the struts and now can get -1.5 camber with reasonable clearance. Down the road I plan to upgrade to Pedders Xa coil overs and get another 10 mm strut-tire clearance - then I plan to use 305 tires all around. I see no issues if one wanted to use the 315 tires on back. Hope this information helps...
edneyens is offline   Reply With Quote
Old 10-31-2010, 08:28 AM   #3
Ltdodge
Ltdodge's Avatar
Drives: 2008 Z06
I have the foose wheels and am running 245 up front and 315 in the rear. I originally had the 275 up front and they fit perfect, but I had to swap them out because they were worn and i put the 245 back on, but they fit perfect. I also have the pfadt 1.25" drop springs
here are the epics with the 275 up front and 315 in the rear
http://www.camaro5.com/forums/showthread.php?t=84207
I am selling my foose speed wheels see link, willing to separate if you want:
http://www.camaro5.com/forums/showthread.php?t=111172
Ltdodge is offline   Reply With Quote
Old 11-01-2010, 02:41 AM   #4
tregwal
Drives: Yellow
So leaving the stock offsets & the stock suspension my set up I want should work?
Old 11-01-2010, 09:06 AM   #5
edneyens
edneyens's Avatar
Based on my experience and many reports from other forum members using the stock rear wheel/tire combination all the way around I would say you should have no problems with the wheel/tire combination's you want to use....
20" FOOSE SPEED STAGGERED WHEEL PACKAGE!! BestWheelDeals Wheels / Tires 72 06-01-2013 02:27 PM
Ok, I now have my wheels :D PQ Wheels and Tires Talk Sponsored by The Tire Rack 722 12-19-2010 12:13 AM
20" SS PVD Black Chrome Wheels wheelguy Wheels / Tires 3 04-12-2010 12:54 AM
20" KMC Rockstar staggered wheels with Nitto tires Speed Depot Wheels / Tires 3 02-26-2010 11:18 AM
