Old 11-01-2010, 04:59 PM   #1
Mankind
Whats a Millwright?
Mankind's Avatar
Drives: 2LT/RS SIM, 05 Wht Denali
Updated solution to JBA shorty header leak.
I know nearly everyone who has installed JBA's have had leaking and CEL issues. I did. After a few experiments i made a gasket from material we use for high heat/high pressure applications at work. This solution was very effective and i have been running for 8 months with no CEL. Friday i got the dreaded CEL. Code displayed the passenger side was leaking. Took it down and found a bad install on my part was the cause, even though it took 8 months to finally show up.
Unfortunately the "V" clamp broke taking it off. Called JBA and they are sending me a new one free of charge.
The gaskets are made of two layers of graphoil material with a .001 stainless shim between them. At one time NAPA had the material in a sheet they could order. It was listed as a universal exhaust gasket material. The shim can cut an individual's finger very badly if mishandled so they may not have access to it anymore.
I would suggest to any of you still having JBA leak issues to look into getting these done. They are 2.5 inches inside diameter and 3.124 outside diameter.
Mankind is offline   Reply With Quote
Old 11-01-2010, 05:32 PM   #2
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Thanks for the update!!!
One day I will have to get around to fixing mine..
scrming is offline   Reply With Quote
Old 11-01-2010, 08:24 PM   #3
jkelly
EMERALD COAST CAMAROS
jkelly's Avatar
Drives: 2lt summit white dk gray int
Has JBA mentioned updating their gaskets, we've been looking at their shorties, but with all the leak issues we're not sure
Big Bertha!
2010 summit white 2Lt cgm rally stripes,hot pink pin stripes,doug thorley shorties,pink bowties,led side markers,sequetial led tail lights,NLP spoiler,magnaflow axel back exhaust, AIRAID CAI(soon to be Vararam)
jkelly is offline   Reply With Quote
Old 11-01-2010, 08:26 PM   #4
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
Any other symptoms/noise issues before the gaskets gave way?
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Old 11-02-2010, 07:10 AM   #5
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
I know this is going to break all the rules. But I used blue tape on both flanges then use jp weld to form a gaskit. It held all summer and last week THAT FRIGGING CELL. I've put almost 6500 miles this year with no cell. I'm prob going to weld them in over winter or just go long tube. Any takers on long tubes?
chevy 3 is offline   Reply With Quote
Old 11-02-2010, 08:15 AM   #6
CamaroFreako
KMK
CamaroFreako's Avatar
Drives: Slow V6 Camaro
I removed the shitty JBA and got my money back, the best solution ever
CamaroFreako is offline   Reply With Quote
Old 11-03-2010, 01:06 PM   #7
Mankind
Whats a Millwright?
Mankind's Avatar
Anyone who is interested in trying my solution can PM me and i can work on getting some out to you. I know it sux to have to deal with it but I have spoken to JBA tech guys a cpl times and they tell me i need to resurface the stacker flange then try again. Not everyone can get their flange resurfaced so these gaskets are the best thing i have found short of solid welding or sending them back for refund.
Old 11-03-2010, 01:42 PM   #8
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Can you just buy the original GM gaskets and use those?
BoostedX2 is offline   Reply With Quote
Old 11-03-2010, 04:23 PM   #9
Mankind
Whats a Millwright?
Mankind's Avatar
We are using the OE GM gaskets for the header to engine surface. They aren't leaking. There is no gaskets for the JBA V6 headers to exhaust pipe connection. They have a 2.5" "V" clamp, band, that hold the two flanges together with a metal to metal surface contact. This is where they tend to leak. Welding less than 3 inches from a flat surface will not leave a flat surface when finished.
Old 11-03-2010, 09:14 PM   #10
CapeSS
CapeSS's Avatar
Drives: Black SS/RS w/white rally stripes
Well thanks for all the info on the JBA shorties, I had them on my Christmas list, guess I'll b scratching them off........unless JBA comes up with a better design
CapeSS is offline   Reply With Quote
Old 11-05-2010, 03:55 AM   #11
a red maro
Drives: Victory Red 2lt RS V6 auto
has anyone that's installed DT shorty's had any CEL pop up?
a red maro is offline   Reply With Quote
Old 11-10-2010, 02:57 PM   #12
speedy_g
speedy_g's Avatar
Drives: CAMARO RS V6
Ya mine still suck ! Even with the gaskets and I'm a machinists so I did check flatness to be good after welding..after some strghting out of course .during winter ill need to redo or try something new ..
speedy_g is offline   Reply With Quote
JBA SHORTY HEADERS = CEL speedy_g Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 64 06-25-2012 01:57 PM
MIRROR - Plea for help. (updated with solution) LDGn63 5th Gen Camaro SS LS LT General Discussions 257 07-14-2011 06:14 PM
Transformer Edition Camaro Questions 2010bumblebeeSS 5th Gen Camaro SS LS LT General Discussions 17 04-21-2010 11:05 PM
LT Header Hiss (Exhaust leak sound) NinoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 03-11-2010 08:41 AM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 07:39 AM
