Old 11-02-2010, 07:00 AM   #1
Brettscamaro
BrettsCamaro
Drives: Black 2ss Rs
Newbie Dont laugh just help please
Hi on my 2011 2ss I have about 5800 miles and I was checking the car and I notice that some of the little nipple/prickley things werent there anymore around the tire but some are..This is no indication of needing new tires is it?
Brettscamaro is offline   Reply With Quote
Old 11-02-2010, 07:11 AM   #2
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
No. Not a chance. Only if you were doing burnouts would you need tires at just 5800 miles.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 11-02-2010, 07:12 AM   #3
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
Not to worry. Thats how tires come out of the molds new. You do not need tires. Here is a article from the Tire Rack tech center explaining how to measure your tire with a coin.
http://www.tirerack.com/a.jsp?a=BG6&....jsp&techid=51
Rudy@Tirerack is offline   Reply With Quote
Old 11-02-2010, 07:16 AM   #4
Brettscamaro
BrettsCamaro
Thanks. greatly appreciated~!!!
Old 11-02-2010, 07:17 AM   #5
Blackhawk6
Blackhawk6's Avatar
Drives: Born:18 Sept 2009 #47903
No worries. I am at almost 30,000 miles and still on the same front tires had to change the back because of a peice of metal stuck in the sidewall. It is the dept of the tread that is measured. Place a penny in the tread grove with lincoln's head pointing down and the top of lincoln's should always be covered if tread is at the top of his head then you have 2/32 remaining
The Law
According to most states' laws, tires are legally worn out when they have worn down to 2/32" of remaining tread depth. To help warn drivers that their tires have reached that point, tires sold in North America are required to have indicators molded into their tread design called "wear bars" which run across their tread pattern from their outside shoulder to inside shoulder. Wear bars are designed to visually connect the elements of the tire's tread pattern and warn drivers when their tires no longer meet minimum tread depth requirements.
Common Sense
However, as a tire wears it's important to realize that the tire's ability to perform in rain and snow will be reduced. With 2/32" of remaining tread depth, resistance to hydroplaning in the rain at highway speeds has been significantly reduced, and traction in snow has been virtually eliminated.
If rain and wet roads are a concern, you should consider replacing your tires when they reach approximately 4/32" of remaining tread depth. Since water can't be compressed, you need enough tread depth to allow rain to escape through the tire's grooves. If the water can't escape fast enough, your vehicle's tires will be forced to hydroplane (float) on top of the water, losing traction.
If snow-covered roads are a concern, you should consider replacing your tires when they reach approximately 6/32" of remaining tread depth to maintain good mobility. You need more tread depth in snow because your tires need to compress the snow in their grooves and release it as they roll. If there isn't sufficient tread depth, the "bites" of snow your tires can take on each revolution will be reduced to "nibbles," and your vehicle's traction and mobility will be sacrificed. Because tread depth is such an important element for snow traction, winter tires usually start with noticeably deeper tread depths than typical All-Season or summer tires. Some winter tires even have a second series of "wear bars" molded in their tread pattern indicating approximately 6/32" remaining tread depth to warn you when your tires no longer meet the desired tread depth.
2010 Camaro 2SS________________________________________Litho#140
Blackhawk6 is offline   Reply With Quote
Old 11-02-2010, 07:29 AM   #6
hotrodhoodrat
hotrodhoodratz
hotrodhoodrat's Avatar
Drives: 68' & 70' Pontiac's /2004 D. Dakota
I wouldn't worry to much, it's all depending on the type of tier you have, some tires can rate up to 120K miles, depending on the amount of use-age you put on them & the terrain you drive, those are new tiers, Google your tier it should tell you ruffly what the manufacture recommends, check them tho, once you get closer to that mileage point, its safe to not go over the recommended amount.
Hope this helps.
The all new Convertible !, Welcome to the Fleet !
hotrodhoodrat is offline   Reply With Quote
Utah Utes? SSOOCH USA - Southwest 6928 07-15-2022 07:56 PM
Sorry for the newbie question ---K&N filter ttexxan Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 8 03-09-2017 06:13 PM
Another gut-wrenching accident...not for the squeamish. chef-beavis Off-topic Discussions 71 03-31-2013 01:20 PM
Fouth Gen Camaro vs. Subaru STi MrCool 4th Generation Camaros 90 04-28-2010 01:17 PM
BAD NJ Pollen Damage ! shinzon 5th Gen Camaro SS LS LT General Discussions 23 04-11-2010 12:48 PM
