Old 11-05-2010, 12:51 AM   #1
pRodigy
pRodigy's Avatar
Drives: 2011 black 2ss/rs M6 "hayley"
2 inch headers help/tips for either kooks or arh
for those who have installed 2in headers either kooks or arh, how was the install? did you have enough clearance? does it hit anywhere when your driving the vehicle? any tips for the install? any diy specific for 2in headers to make my life easier lol. thanks for the help and please specify if its the 2in kooks or 2in arh u used
trying to get the most out of life... & then some more..
pRodigy is offline   Reply With Quote
Old 11-05-2010, 06:14 AM   #2
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Why the 2in Got something else planned for it?
9/26/09 Took delivery!
Old 11-05-2010, 03:00 PM   #3
pRodigy
pRodigy's Avatar
lol... in the long run yeah..
Old 11-05-2010, 03:01 PM   #4
pRodigy
pRodigy's Avatar
anyone please?
Old 11-05-2010, 04:28 PM   #5
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I have XS Power 2" headers (they look just like kooks). I had no issues during the install and didn't have to remove the steering shaft. It was a tight fit but did go into place. They aren't anymore difficult to install than 1 7/8 headers.
That being said, it does rub on the steering shaft when turning right. I am in contact with the vendor getting this resolved. I read on this site sometime back about someone who bought a set of 2" headers and it was rubbing the steering shaft. The manufacturer provided a replacement that did not rub. I do not know (the post didn't say) if the new header was clearanced with a dimple or had re-routed tubing to clear the shaft.
I suggest you contact the manufacturer of the headers you are interested and ask if they are steering shaft clearance issues (driver's side) or frame rail clearance issues (passenger side).
Old 11-06-2010, 12:36 AM   #6
pRodigy
pRodigy's Avatar
i guess that was the clearance issue that was brought up to me about the 2 in headers. will take your advice and call kooks thank you.
Old 11-06-2010, 12:43 AM   #7
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
I'm running kooks 2" headers and I have no problems they clear everything though I am running a 427 LSX block with LS7 heads
Old 11-06-2010, 12:56 AM   #8
GQ4Life
Drives: 2010 Camaro SS LS3
I have 2in ARH headers. It is an increase of 1.25% HP over the 1 7/8" headers. Jannetty Racing installed they said its a lil more of a tight fit but it fits find. Talk to Jannetty Racing.
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 11-06-2010, 01:41 PM   #9
Slowhawk
Drives: 1999 Trans Am
I run the 2" ARH. Tight to get in,have to disconnect the steering shaft- 1 minute to do. They clear everything no problem.
Slowhawk is offline   Reply With Quote
Old 11-06-2010, 08:04 PM   #10
MarylandSpeed
Drives: 2012 ZL1 & 2010 2SS/RS
I personally would not mess with 2" headers. 1 7/8" will do better down low, and support 90% of the applications out there. The new Camaro is really an anomoly in most people getting 1 7/8" headers over 1 3/4". With the LS3 in the Corvette, a lot of those guys go with 1 3/4" and consider 1 7/8" big.
MarylandSpeed is offline   Reply With Quote
Old 11-06-2010, 08:35 PM   #11
GQ4Life
Jannetty did back to back test lost nothing down low
Old 11-06-2010, 09:39 PM   #12
pRodigy
pRodigy's Avatar
yeah on the test that ted did... the 2 in was ahead by a bit overall. im probably going with 2in kooks headers.
Old 11-06-2010, 11:32 PM   #13
MarylandSpeed
I am not gonna argue anyone elses results because it is pointless. That being said I have sold a lot of headers in my day, and also tested a lot of headers. We sell 2" headers for most every LSx application we offer including the LS3 and LS7 Corvette. Still we only sell one 2" header for about every 250 of the other size headers we sell. Will 2" work and not cause a problem..yes. Is it completly the wrong size for something that is not severly modded, absolutly. IMO 2" is unncecessary unless you are doing like 700 RWHP.
With headers, you want the smallest header that can flow the maximum output of the engine. A header is all about exhaust velocity and works kinda like a hose. If you take your garden hose, and replace it with a bigger garden hose, the water will come out the end slower unless you turn the water up. Same with a header, if you put a too big header on, you lose exhaust velocity, meaning exhaust gas leaves your engine slower because it is not as compressed. You don't build power as fast down low, and maybe equal it up top once the exhaust gas gets going. We have customers making 500-700 rwhp on a 1 7/8" header jsut fine. Another reason I am not a fan of the 2" header is the 3" collector. In the correct application where a 2" header is needed, I really think you need a 3 1/2" collector to effectivly use that primary size. Kooks offers this in the 4th gen Camaro and Corvette applications, but not the new Camaro. The 3" collector might be why 1 7/8" and 2" dyno the same, since they all ultimatly end up having to get through the same size collector.
Either way, Kooks designed the header and even they will tell you not to use it except in the most extreme applications.
Old 11-07-2010, 01:43 AM   #14
GQ4Life
Well that is the other reason I went with 2" besides the 8 more HP, was because I have plans on more mods in future then me & Ted might continue talks of 3" or so all the way back.
Only thing I think is depending on mods 2" might not be cost effective for the little extra HP bump up top
V8 Camaro Aftermarket Exhaust Video Clips Compilation tjbusa Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 591 07-06-2022 09:38 AM
ARH - American Racing 304SS Long Tube Headers | Limited Time MASSIVE SALE! AutoAgenda V8 Bolt-Ons & Tunes 416 06-09-2013 06:08 PM
ARH Headers + Corsa Catback vs. ARH Full Header-back Exhaust RedJewel2SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 11 06-17-2010 03:46 PM
ARH, Dynatech, or Kooks??? eynigush Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 03-07-2010 02:48 AM
My SS is at Kook's right now getting headers and high flow race exhaust and X pipe Badger Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 83 06-30-2009 01:22 PM
