Old 11-06-2010, 12:24 AM   #1
DesertG8
Drives: Pontiac G8
With a high stall convertor do you want to lock it or unlock it for quarter mile runs
With a single disc fti 3600 convertor I have so many different opinions. First the owner of fti sais to keep it unlocked. Then I heard it is ok to lock it at 100 plus on wot. The vendor told me it takes lots of power and I can lock it. My tuner to be sais to leave it unlocked.
We are waiting for hp tuners to release new software which will allow it to lock on partial throttle. So you do not get the rpms going up and down.
So will you get more performance down the quarter with it locked or unlocked? Unlocked till 100 and then lock it?
This is a g8. But it uses the same trans. as the camaro.
DesertG8 is offline   Reply With Quote
Old 11-06-2010, 01:09 AM   #2
tvwilkes
tvwilkes's Avatar
Drives: 2010 Camaro 2SS
Single disk needs to stay unlocked.
tvwilkes is offline   Reply With Quote
Old 11-06-2010, 02:44 AM   #3
Supercharged SS
Drives: 2010 Camaro
Like the guy above me said, you can't lock a single disc converter. I believe you'll cook the clutch. I had on come apart from doing this and it wasn't pretty. It took out the pump.
Old 11-06-2010, 08:32 AM   #4
69lt1bird
69lt1bird's Avatar
Drives: 1969 Pontiac Firebid
Leave it unlocked like Greg from FTI told you or you will ruin your converter.
Free HP Tuners Beginners Tuning Guide
Michigan Snowmobiler
1969 Firebird: 7.55@97.93 1/8 1.70 60 ft.[/COLOR] EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
69lt1bird is offline   Reply With Quote
Old 11-06-2010, 11:57 AM   #5
DesertG8
Drives: Pontiac G8
Thanks for the input. I will do so.
Right now I have the superchips tune on it. It is way past it's potential since I have headers and the stall.
The person in Phoenix who is going to do the tune is well known. He wants me to be patient since new software will be out anytime from hp tuners which will lock the convertor on partial throttle thereby making the driving experience better on the city streets.
Is the convertor locking on full throttle now with the superchips tune???
Old 11-07-2010, 02:48 PM   #6
Slowhawk
Drives: 1999 Trans Am
As they all said.Leave it unlocked.Only the multi disks can be locked and even them they need to be rebuilt in time. Alot of people are waiting for the tranny tune -promise from alot of tuning company's. We really need full control of these tranny's.
Slowhawk is offline   Reply With Quote
Old 11-09-2010, 01:18 PM   #7
DSX
Drives: 2006 Z06
Leave it unlocked. If you had a triple disk and wanted to know where to lock it, then you should do two dyno pulls in 4th... one forcing it to lock from the start, and one leaving it unlocked the entire time. Graph both pulls against vehicle speed... NOT engine RPM. Where the two graphs cross is where you should lock it. If you have long gears, then do that with 3rd as well.
Since it's a single, I wouldn't push it.
DSX is offline   Reply With Quote
Old 11-09-2010, 07:28 PM   #8
DesertG8
Drives: Pontiac G8
I will not. Greg said I can lock it from 100 plus. But I do not even think this is possible with hp tuners. I just hope it is not locking now with the superchips tune on full throttle. I do have at least a large transmission cooler in the front bumper.
Old 11-09-2010, 08:41 PM   #9
ArkySS
Camaroless for now...
ArkySS's Avatar
Drives: 2014 Blue Topaz Silverado
My 3200 is a LU converter but I need a trans tune BAD because I think it struggles about half the time to lockup!!!
It was fun while it lasted.....
ArkySS is offline   Reply With Quote
Torque Converters CamaroSpike23 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 48 08-16-2014 03:07 AM
ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL ADKINS PERFORMANCE Suspension / Chassis / Brakes 0 08-03-2010 01:08 PM
New Camo shots of a Camaro bballr4567 Camaro ZL1 Forum - ZL1 Specific Topics 150 02-18-2010 01:13 PM
Torque Converters Milk 1027 Wiki 0 08-12-2009 07:31 PM
