![]() ![]() ![]() ![]() Drives: 2014 Z51 Corvette Join Date: Dec 2008
Any TSB for L99 leaking oil
I was going to change my oil before putting car in storage and when I got underneath the car I noticed drops of oil to the rear past the oil filter. Filter and drain plug are tight. I put about 3000 mlies on car this year and it is about 2 quarts low. Anybody know if there are any TSB's?
![]() Drives: 95' Z28, 2010 2ss RS Join Date: Feb 2010
Yes, there is. Several people on this forum have had the same problem, as I have, and the dealer fixes it under warranty. It is a crankshaft seal that has gone bad if memory is correct. Relatively minor, it should be fixed in one day. If I can find the service bulletin I will post it, but yeah get it fixed by the dealer.
2010 Camaro SS - LS3
Magnaflow 3" Competition Series Catback Off road x-pipe Kooks LT Headers |
![]() Drives: 2010 2SS RS black ground effects Join Date: Oct 2010
I noticed mine leaking oil also on the pavement. I tightened my oil filter and it seemed to stop leaking significantly. This weekend I installed MBRP exhaust and noticed oil around the oil filter when it was on the lift. I think I am going to have the dealer look at my L99. Crankshaft seal?????
![]() Drives: 2SS Join Date: Sep 2010
Does this issue only happen with the 2010's, or is a problem with the 2011's as well? Anybody know?
Does this repair involve pulling engine or tranny? I am goig to the dealer tomorrow and it would be helpful to know the TSB, also will they be draining the oil?
#6 |
Drives: 1999 Trans Am Join Date: Jul 2009
From what I've seen alot of times it's the oil cooler.I just tighten the bolts holding it together and it ussually stops the problem. My personal car had 200 miles on it and the cooler was leaking.Got a good 1/2 to full turn on all the bolts.Leak stopped completely. Now every car that is on the lift gets the bolts checked and I'd say 80% of them have oil seeping from the cooler.
#7 |
![]() Drives: 2010 SS2/RS Victory Red Join Date: Jul 2009
TECHNICAL
Bulletin No.: 05-06-01-034L Date: July 23, 2010 Subject: 5.3L, 5.7L, 6.0L, 6.2L, 7.0L - Engine Oil Leak at Rear Cover Assembly Area (Engine Block Porosity RTV Repair Procedure) Models: 2004-2007 Buick Rainier 2008-2009 Buick LaCrosse Super, Allure Super (Canada Only) 2005-2011 Cadillac CTS-V 2007-2011 Cadillac Escalade, Escalade ESV, Escalade EXT 2003-2009 Chevrolet TrailBlazer 2003-2011 Chevrolet Corvette 2004-2006 Chevrolet SSR 2005-2011 Chevrolet Silverado, Silverado SS 2006-2007 Chevrolet Monte Carlo SS 2006-2009 Chevrolet TrailBlazer SS, Impala SS 2007-2011 Chevrolet Avalanche, Suburban, Tahoe 2009-2010 Chevrolet Colorado Pickup 2010-2011Chevrolet Camaro 2003-2009 GMC Envoy 2003-2011 GMC Sierra 2004-2005 GMC Envoy XUV 2007-2011 GMC Yukon XL, Yukon Denali, Yukon XL Denali 2009-2011 GMC Canyon 2004-2006 Pontiac GTO 2005-2008 Pontiac Grand Prix GXP 2008-2009 Pontiac G8 GT 2009 Pontiac G8 GXP 2005-2009 Saab 9-7X 5.3i 2008-2009 Saab 9-7X Aero 2003-2010 HUMMER H2 2006-2010 HUMMER H3 with 5.3L, 5.7L, 6.0L, 6.2L, 7.0L VORTEC(TM) GEN III or GEN IV V8 Engine (All Aluminum Block) (RPOs L33, LC9, LH6, LH8, LH9, LM4, LS4, LS1, LS6, L76, L77, LFA, LZ1, LS2, L92, L94, L99, L9H, LS3, LS9, LSA, LS7) Supercede: This bulletin is being revised to add the 2011 model year and update the Warranty Information for the Corvette. Please discard Corporate Bulletin Number 05-06-01-034K (Section 06 - Engine/Propulsion System). Condition Some customers may comment on an engine oil leak. Cause Upon initial diagnosis, it may be determined that the leak is coming from the rear cover gasket. This condition may be caused by engine block porosity on the sealing surface. This issue pertains to aluminum block applications only. Correction Follow the steps for Oil Leak Diagnosis in SI to determine the source of the leak. If the leak has been diagnosed as coming from the engine rear cover assembly, refer to Engine Rear Cover Replacement in SI and remove the engine rear cover assembly. Inspect the engine block and engine rear cover for porosity on the mating surfaces. - If porosity is found on the engine rear cover (see illustration below), replace the engine rear cover assembly, GM P/N 12633579. - If porosity is found on the engine block, use the following procedure to apply RTV to repair the engine block porosity. The porosity issue is in the gasket sealing surface at the top of the cover, near the high pressure oil crossover port. Refer to the picture below. The oil leaks by the gasket and runs down the side of the cover, and may appear to be a leak at the t-joint area of the cover. The fix is to replace the cover with GM P/N 12633579. Also, if porosity is found anywhere on the sealing surface of the engine block, use the following procedure to apply RTV to repair the engine block porosity. Refer to the illustration below. Important Clean any residual oil from the block and cover before applying the sealant in the next step. 1. Wipe a small amount of RTV, P/N 12378521 (in Canada, use P/N 88901148), onto the surface using a plastic scraper to fill the porosity. 2. Remove any excess RTV material, especially from inside the high pressure oil passage. Refer to #1 in the above illustration. 3. The joint may be closed immediately after applying the RTV. Total joint time after the RTV has been applied must be under 20 minutes. Important Refer to Engine Rear Cover Replacement in SI and follow the tightening specifications and sequence. 4. Reinstall the engine rear cover using a new gasket and a new crankshaft rear main seal. Refer to Engine Rear Cover Replacement in SI. Parts Information Important For Saab (U.S.) only, use P/N 88861206 - Engine Oil Dye (U.S.) or equivalent. Warranty Information (excluding Saab U.S. Models) For vehicles repaired under warranty, use: Warranty Information (Saab U.S. Models) For vehicles repaired under warranty, use the table. Disclaimer |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 Stingray 2LT/Z51 Join Date: Feb 2010
Just had this same problem (crankshaft seal leaking) with my 2011 @ 192 miles. Yes... 192 miles.
Dealer fixed....
*CAMARO5 CAMARO OF THE WEEK 3/21/11*
*1ST PLACE - NAVAL STATION SAN DIEGO CAR SHOW 4/17/11* *PEOPLE'S CHOICE AWARD - SAN DIEGO FREEDOM FESTIVAL CAR SHOW 7/4/11* *TROPHY RECIPIENT - GREATEST SHOW ON TURF 9/11/11* *1ST PLACE MODERN MUSCLE - CORONADO SPEED FESTIVAL 9/23/11* *AWARD OF EXCELLENCE - GOOD GUYS DEL MAR FALL NATIONALS 11/27/11* *1ST PLACE / '82&UP CAMARO/FIREBIRD- FORT WALTON BEACH FF SHOW 2/16/13* BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=120353 |
| 2010 Camaro V6 Oil and Oil Filter Change | azamazonqueen | Camaro DIY & HOW-TO instructions & discussions | 116 | 03-19-2017 02:36 PM |
| DIY: Camaro Oil Change | adub4185 | Camaro DIY & HOW-TO instructions & discussions | 180 | 04-23-2014 07:11 PM |
| First Camaro DIY Oil Change = 4 Hours -FML | Infern0 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 63 | 09-25-2010 04:18 PM |
| Major U.S. oil source is tapped | KILLER74Z28 | Off-topic Discussions | 32 | 10-30-2007 10:47 AM |
