Old 11-09-2010, 04:15 AM   #1
Whorable MPG1975
I'd rather be Blown.
Whorable MPG1975's Avatar
Drives: 1975 CAMARO 454ciBBC/TKO-600
Any gains with shorty headers and Twin turbos?
Looking at twin turbo kits and was wondering if the shorty headers would work well with them instead of the stock manifolds? I was thinking my 1st wave of mods being an after cat exhaust upgrade and shorty headers than later putting the turbo's on. The final push would be a matching cam. Who has done this?
"Feel free to chime in if the designers ill-advice this!"
Whorable MPG1975 is offline   Reply With Quote
Old 11-09-2010, 08:26 AM   #2
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
After watching this video, I learned more about back pressure and how it can be solved. http://www.phastekperformance.com/20...ders-s/324.htm
So, I'm sure there will be more benefit to having shortys before turbos and a free flowing exhaust after the turbo. This will really help boosting the turbo faster. Couple of points come up, but you should really talk to the turbo kit vendor to get the answer.
a) Can Shortys handle the weight of the turbos? Remember the heavy turbos are mounted to the manifold and the manifold is strong. Most of these shortys will crack and/or break due to heat and the weight and bouncing.
b) the TT kits are designed to hookup to the manifold where it leaves off. Your shortys must be ending the exact position as stock manifold.
If you can't get a guaranteed solution to the manifold issue, I'd stay with stock, but get a 3" exhaust right after the turbo. This way the hot side releases fast and turbos will spool quicker and keeping them cooler.
There three good TT kits out there, call them up and see what they say. I'll bet you they'll say leave the stock manifold alone.
Oh btw, do the TT and exhaust all at the same time, makes your life easier.
Good luck.
Z_Rocks is offline   Reply With Quote
Old 11-09-2010, 09:46 AM   #3
AdamCzap
Drives: 18 zl1, 17 sierra denali
Slapping on a 3" exhaust AFTER the turbos will do just like Z_Rocks says. My car picked up a ridiculous 27rwhp going from a restricted airflow to unrestricted (via my exhaust cutouts). I have youtube videos of back to back dyno runs closed vs. open:
dumps closed, stock exhaust:
dumps open, "free flowing" exhaust:
AdamCzap is offline   Reply With Quote
Old 11-09-2010, 09:56 AM   #4
Z_Rocks
Z_Rocks's Avatar
Hey Adam, how is the car running? I bet with the cooler air, you're getting more boost now.
When the cutouts are open, does it get loud inside of the car? How much were those cutouts $$$? I liked the opening/closing motors but weren't they expensive? Almost cost of full exhaust?
Old 11-09-2010, 11:02 AM   #5
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
I'm pretty sure his boost will not go up because it i regulated by his waste gate and/or boost controller. But, his hp might go up as the cooler air is denser and the intake air charge temp will be lower.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 11-09-2010, 11:27 AM   #6
Z_Rocks
Z_Rocks's Avatar
You're right, mentally I was thinking more power, but I wrote more boost
I love turbos, especially during cooler weather!
Old 11-09-2010, 11:32 AM   #7
AdamCzap
The car is running awesome. The noweeds.net diverters are what I have. I think I paid $900, which is expensive, but the quality is top notch and definitely better than QTP's cutouts. And no, don't even think about listening to your radio or having a phone conversation in the car with them open .
My current problem is that my rear tires need replacing. I have 23k miles on them and the wear line is getting down to the limit.
Old 11-09-2010, 11:38 AM   #8
AdamCzap
I occured to me that I never answered the question in the OP. I asked Hellion about getting shorty headers when I installed my kit, and they said you could do it and it would fit, but you would NOT get any power gains. The big 3 system builders for TT all made them to work with stock manifolds. You would, however, benefit from a 3" exhaust in a big way as my dyno videos show.
Old 11-09-2010, 08:45 PM   #9
Whorable MPG1975
Nice numbers Adam! My L99 is going to do the same thing one day!
I was planning on doing the exhaust cut outs too, glad to see it picked up some horsepower too! I can't wait to do that on the 75' I got (with matching Mad Max style switch on the shifter, brar har har).
What system are you using after the turbo's than? I am planning on one of the big 3 TT kits out there right now. It is hard to beat a good cast iron exhaust manifold for strength, thats for sure. Hmmm, better use the money on a cam than.
The wife won't understand at first...
Old 11-09-2010, 08:46 PM   #10
Whorable MPG1975
... and was hoping the vendor's would jump in...
Old 11-09-2010, 08:54 PM   #11
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
I'd rather hang a turbo off the cast part due to heat/weight.
xxlbeerz is offline   Reply With Quote
Old 11-09-2010, 10:06 PM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
It is very true about the restriction with the exhaust especially after the turbos. Many people put on great kits and then kill a good percentage of power with insufficient exhaust. On one particular high HP turbo motor (not mine) it pretty much put a ceiling on the motor at 1,500 HP. Removing the exhaust let it climb to roughly 2,000 HP. This is an extreme example, but it shows you how severe an exhaust restriction can be.
Old 11-13-2010, 09:26 AM   #13
AdamCzap
stock exhaust system. it's restrictive, but when i'm not standing on the gas pedal it plays nice with the neighbors. been thinking about a 3" though...
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 93 08-30-2021 06:56 PM
TT question metallicide Forced Induction - V8 24 01-30-2011 07:30 PM
debating twin turbos. need advice RobRiot88 Forced Induction - V8 0 10-19-2010 10:40 PM
Why TT over SC? Jefe's SS Forced Induction - V8 10 10-02-2010 04:14 AM
STS Twin Turbos SupremacyCustoms Forced Induction - V8 0 02-16-2010 02:35 PM
