Old 11-13-2010, 11:21 AM   #1
Shift
Drives: Me 2001 F150, The wife '11 2SS RS
Change your differential fluid!
We just hit 1,500 miles on the car and since the manual recommends changing the differential fluid at this point I did it last night. And I am astounded by how much metal was in it!
It looked like liquid metal pouring out with a fair amount of little shards stuck to the magnets in the plugs.
If you haven't changed it I would highly recommend you do it. I'm personally going to change it again at the next oil change.
Shift is offline   Reply With Quote
Old 11-13-2010, 11:35 AM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
+1
And use synthetic going back in. I used Royal Purple.
I've already done both Trans Oil and Rear End Oil.
Build Journal
Old 11-13-2010, 11:55 AM   #3
FRANK121
FRANK121's Avatar
Drives: 2022 Camaro ZL1
How hard is it to change the manual says a dealer has to do it and Lord that would cost a fortune!
2022 Black ZL1
RotoFab CAI, AWE Touring Edition Cat Back Exhaust.
665 Crank hp. est. and 660 Crank ft. lbs. est.
Never been Dynoed
FRANK121 is offline   Reply With Quote
Old 11-13-2010, 12:18 PM   #4
Shift
peace of cake, 30-45 minutes
Old 11-13-2010, 12:23 PM   #5
2010 Bumblebee
2010 Bumblebee's Avatar
Drives: Transformers Edition Camaro 2SS/RS
Your Differential only takes one quart.
Don't let them rip you off it's only one quart. The dealer quoted me $140. I told them it's one quart and 15 min to drain the thing. So they looked into it. So the dealer ended up charging me $66 total for the differential fluid change.
Also I pay $70 for the 8 quart synthetic mobil 1 oils change at the dealer. Don't let yours rip you off on that either.
Here is a link for some differential fluid info.
http://www.camaro5.com/forums/showthread.php?t=76160
The Yellow Camaro Club
http://www.camaro5.com/forums/group.php?groupid=128
Northern Massachusetts & Southern New Hampshire Camaro Club
http://www.camaro5.com/forums/group.php?groupid=127
The mother of all supercharger questions thread
http://www.camaro5.com/forums/showthread.php?t=77958
My 2010 Camaro Review
http://www.camaro5.com/forums/showthread.php?p=2025442#post2025442
2010 Transformer Edition Camaro L99 Auto
2010 Bumblebee is offline   Reply With Quote
Old 11-13-2010, 12:24 PM   #6
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
You got any pics of the metal shavings?
INTIMIDAT3R is offline   Reply With Quote
Old 11-13-2010, 12:31 PM   #7
Shift
I dont, I wish I had thought to take some pics of the shavings before I wiped them off the plugs. I will how ever try to get a pic of the fluid up.
Old 11-13-2010, 12:37 PM   #8
Shift
I would say it was comparable to this random pic I found with google
This pic doesn't really do it justice of how bad it really looks but its an idea considering clean gear lube looks like clean motor oil
It looked like mercury pouring into the can I was catching it in
Old 11-13-2010, 12:46 PM   #9
pennor
pennor's Avatar
Drives: 2011 2LT - 73 Corvette 454
Question
Would somebody please tell me where in the manuals there is a recommendation to change differential fluid. I've read through the 2011 owners manual, supplimentals, and warrante manual and have only found one reference to the differential fluid at all, and that was saying how much fluid the differential holds. That reference is on page 12-3. The rear end takes 1 quart by the way.
In secition 11, starting on 11-2 all scheduled maintenance required is outlined. I don't find any reference to rear end fluid changes or manual transmission fluid changes in that section at all.
Further, on page 10-14 you will find this section titled:
Manual Transmission Fluid
It is not necessary to check the manual transmission fluid level. A transmission fluid leak is the only reason for fluid loss. If a leak occurs, take the vehicle to your dealer service department and hit it repaired as soon as possible. See Recommeneded Fluid and Lubricants on page 11-6 for the proper fluid to use.
pennor is offline   Reply With Quote
Old 11-13-2010, 12:47 PM   #10
racrx451
racrx451's Avatar
Drives: 2010 white SS
I hope this isn't the reason my rear end feels like it's going out.... I haven't changed it and it has 7500 miles on it.
racrx451 is offline   Reply With Quote
Old 11-13-2010, 12:48 PM   #11
Shift
In the break in section I think somewhere around page 10-10, says it recommends changing the differential fluid after the break in period if you plan on driving it competitively.
Old 11-13-2010, 12:58 PM   #12
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
If anyone hasn't changed it already, change it now. I highly recommend Royal Purple Maxgear 75w90 gear oil. 1 qt will make a noticeable difference.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 11-13-2010, 01:01 PM   #13
ravensjeff
100% Chevy & Harley Man
ravensjeff's Avatar
Drives: 2010 2SS: Blown LSX 376-B15
Competitively is a whole lot different then normal driving. That was referring to road racing.
I ended up changing ratio to 3:70. Part of Lingenfelter mods. I'm a little surprised at the amount of metal you are talking about though. Need a mechanic input to see if its normal.
LSX 376-B15, TVS2300 SC, Harland Sharp Rockers w/ Trunion Bearings, ATI Balancer/keyed, AR LT Headers/Borla Catback Exhaust, DSS 1400 HP Axles, DSS aluminum driveshaft, 3.70, Hotchkis Springs/Sway bars, Forgeline SO3P Aluminum Wheels (20x9.5 F/20x11 R)w/ Hidden Titanium Hardware, Nitto NT05 Tires (27540ZR20 F/31535ZR20 R), Billet LPE brake/gas pedals, Escort 9500ci Radar Detector Laser Jammer, Roto Fab CAI with Ice Silver box, Carbon fiber tube/MAF Housing Assy, LPE Aluminum coil covers, SS9 Sleeper Fiber Glass Hood (ACS), Carbotech 1521 ceramic brake pads, Elite catch can.
ravensjeff is offline   Reply With Quote
Old 11-13-2010, 01:09 PM   #14
pennor
pennor's Avatar
Thanks for the heads-up on where to find this information. The break in section begins on page 9-18 and continues on page 9-19. Just for the fun of it and because it's raining and I have time on Saturuday, I'll include it here for everyone's reading pleasure. It actually answers a bunch of other questions that come up all the time on this site. Note that the very last bullet item talkes about the rear axle fluid change and is quite specific. I put that one in red just to highlight it.
New Vehicle Break-In
Notice: Follow these guildelines during the first 2415km/1,500 miles of driving this vehicle. Parts have a break-in period and performance will be better in the long run.
  • For the first 2414km/1,500 miles:
  • Avoid full throttle starts and abrupt stops.
  • Do not exceed 4,000 engine rpm.
  • Avoid driving at any one constant speed, fast or slow.
  • Do not drive above 176km/h (100 mph).
  • Avoid downshifting to brake or slow the vehicle when the engine speed will exceed 4000 RPM.
  • Do no let the engine labor. Never lug the engine in high gear at low speeds. With a manual transmission, shift to the next lower gear. This rule applies at all times, not just during the break-in period.
  • Do not participate in racing events, sport driving schools, or similar activities during the break-in period.
  • Check engine oil with every refueling and add if necessary. Oil and fuel consumption may be higher than normal during the first 2414 km/1,500 miles.
  • To break in new tires, drive at moderate speeds and avoid hard cornering for the first 322 km/200 miles. New tires doe not have maximum traction and may tend to slip.
  • New brake lining also need a break-in period. Avoid making hard stops during the first 322 km/200 miles. This is recommended every time brake linings are replaced.
  • Should the vehicle be used for racing or competitive driving (after break-in) the rear axle lubricant must be replaced before hand.
Clutch fluid contamination problems on Vette fixed for Camaro??? LDGn63 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 11 05-28-2012 10:17 PM
V6 M6 transmission fluid change help camaro guy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 8 05-14-2012 07:55 AM
rear differential fluid drain/fill plug location Dentyneice Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 9 11-27-2010 11:54 PM
Put More Power To The Pavement With Pfadt Engine Mounts And Differential Bushings!!!! Apex Motorsports Transmission / Driveline 28 11-27-2010 11:46 AM
I want to change rear diff and tranny fluid.?? The Enforcer V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 6 04-06-2010 04:11 PM
