![]() Drives: 2018 PP GT Join Date: Mar 2010
new clutch and now transmission grinds
had my SS into the dealership for a noise in the tranny when depressing the clutch pedal, they diagnosed and replaced clutch assy and release bearing assy. picked it up tonight and first thing i noticed is the clutch engages very close to the floor. then as i was driving i shifted to second with the clutch pushed all trhe way in and it made grinding noise going into second. turned around and as i was coming to a stop shifted into first and tranny wouldnt go into first and made same grinding noise. all new clutch parts yet it is obviously not disengaging the clutch.. left the car there . any theories?
#2 | |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
so i wonder why the tech wouldnt have noticed that it wasnt right. or is it possible it felt right and then air collected after the car was sitting idle for a day?
![]() Drives: red 2011 ss Join Date: Jun 2010
HYDRAULIC CLUTCH ARE HARD TO GET OUT THE AIR.
Boosted Moderator
Anything is possible, I'm sure they will get it right... unfortunately, that meant leaving the car again...
