Old 11-19-2010, 09:07 PM   #1
metallicide
metallicide's Avatar
Drives: 2010 Camaro 2SS
TT kit installation
How difficult would the installation on granatelli kit be for someone inbetween novice and intermediate with mechanics. I worked alot on small motors, and did alot of auto body but never dug much into the motor. This kit seems pretty straight up though and looks pretty easy. I wont have a lift just jack stands.
metallicide is offline   Reply With Quote
Old 11-19-2010, 09:27 PM   #2
Matts Electric
Matts Electric's Avatar
Drives: 2011 ss/rs
I'm doing that same kit ,well its actually built bt Turbo Technology. I started on it today about 9am and quit about 4pm its about half done. The kit fits perfectly, I would say the hard thing is getting apart the 02 sensors clip and the intake and injectors. Its just time consuming and you just have to be patient,watching how the intake comes off and goes back on. I think just about any mechanically inclined person could install this kit.
Matts Electric is offline   Reply With Quote
Old 11-19-2010, 09:28 PM   #3
metallicide
sounds good
Old 11-19-2010, 10:29 PM   #4
SRT10KLLR
Drives: 2010 Camaro 2SS/RS
I will be finding out here shortly. It seams to be a pretty straight forward bolt-on.
Why would you need to remove the intake manifold or do you mean the intake as in a CAI? Just replace the injectors and bolt on the turbos, piping and inter cooler.
2005 Dodge Ram 2500 RCSB Thunder Road Hemi Sport w/STS Turbo
2004 Dodge Ram SRT-10 - Silver - Stock
2003 Chevy 1500 RCSB Stepside 400SS - 408 in now awaiting Turbo
SRT10KLLR is offline   Reply With Quote
Old 11-19-2010, 10:30 PM   #5
AdamCzap
Drives: 18 zl1, 17 sierra denali
If you have enough to buy the kit then pay also for the piece of mind of having it professionally installed and tuned. There is no reason to tie up 16 hours of your own time and then what if you break something you can't fix?
AdamCzap is offline   Reply With Quote
Old 11-19-2010, 10:38 PM   #6
SRT10KLLR
I have done that in the past but I don't like not knowing how to fix issues later. I you install it yourself then you know ever component installed so you can troubleshoot things later if need be. I don't want to be stranded on the road somewhere and not be able to get a hold of the manufacturer.
Old 11-19-2010, 10:43 PM   #7
metallicide
doing the work is half the fun. I have free time id rather be doing that. Its a bolt on....not sure what im going to break that i cant fix. Look at some instructions....its pretty easy.
Old 11-19-2010, 10:54 PM   #8
KeeBee
Drives: 2011 Camaro SS/RS, 70 1/2 SS Camaro
Depends on how much it is to have it installed and tuned. If it takes 6 to 8 hours to install that could run another 2 to 3K.
KeeBee is offline   Reply With Quote
Old 11-19-2010, 11:37 PM   #9
376TT
376TT's Avatar
Drives: 2010 Nickey/Chicago FLP Twin Turbo
I noticed you are in Illinois. I can suggest, from experence the workmanship and detail of work the guys at FLP are capable of. Give them a call and talk to Tony at their Naperville shop.
You may want to reconsider the install. They done my Nickey Camaro.
376TT is offline   Reply With Quote
Old 11-20-2010, 04:07 AM   #10
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Wow, if you think that way about everything you'll never doing anything challenging or rewarding the rest of your life....
bigsquirrel is offline   Reply With Quote
Old 11-20-2010, 08:02 AM   #11
metallicide
Thanks man appreciate it, if I hit any big hitches I might just call them up. I cant forsee this being real difficult, its pretty well bolt on...remove wheels, front bumber, run the tubing, mount the intercooler, turbos to manifolds....my only thing im not sure about is the fuel rails.
Old 11-20-2010, 08:07 AM   #12
Fishdadddy
Fishdadddy's Avatar
Drives: 2010 2SS/RS ; 1970 Firebird Formula
Keep us posted on how it goes.
Fishdadddy is offline   Reply With Quote
Old 11-20-2010, 12:25 PM   #13
bigsquirrel
Just get the right fuel line quick release tools (Don't be fooled there's still nothing quick or easy about it) and it'll be fine.
Also read up on the proper ways to prime your water pump and the intercooler pump.
Old 11-20-2010, 01:33 PM   #14
KeeBee
If the TT kits come with the directions like Magnacharger come with it should be pretty easy to install.
Camaro Brembo Big Brake Kit, Installed!! SS Mike Suspension / Brakes / Chassis 125 09-09-2010 01:34 PM
4.10 or 3.73 Gear & Install Kit Combo Apex Paul Transmission / Driveline 21 08-21-2010 02:55 PM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
2010 Camaro Fog/DRL Light 5202 HID kits .... HID_Guy Exterior Parts & Accessories 1 09-07-2009 01:19 PM
