Old 11-22-2010, 01:01 AM   #1
2010Camaro55
Drives: 2010 LT2 Switch Blade Silver
LT Wheels VS SS Wheels
Hello,
I have a 2010 LT2 V6 with the factory 18inch wheels, can anyone tell me if I can put the 19 or 20 inch SS wheels and tires on it with no issues? I understand that the stock 19 or 20s that can come on some LT models will not fit the SS because of caliper issues but was not sure if I could put SS wheels on the LT without an issue?
Nest question would you recommend 19 inch or 20 inch wheels?
Thank you for your response in advance.
JC
2010Camaro55 is offline   Reply With Quote
Old 11-22-2010, 01:05 AM   #2
rally yellow ss rs
rally yellow ss rs's Avatar
Drives: 2010 Rally Yellow 2SS RS
I would just go for the 20's if you can find them with decent rubber still on them. Dont forget that upgrading your brakes is needed to stop the much heavier wheels/tires at a distance close to what you have now.
rally yellow ss rs is offline   Reply With Quote
Old 11-22-2010, 01:10 AM   #3
cyberLS
cyberLS's Avatar
Drives: 2010 Cyber Grey LS
if you have a 2 lt you should have 19's already not 18's. but i say go 20's or after market. can turn out cheaper?
cyberLS is offline   Reply With Quote
Old 11-22-2010, 01:11 AM   #4
StreetReporter
StreetReporter's Avatar
Drives: 2010 Camaro 2LT RS Black on Black
There are ZERO fitment issues putting any factory Camaro wheels on the LT.
The problem is the other way around -- the 18" 'Heritage' wheels don't allow for enough clearance with the Brembo brake calipers.
I have a 2LT RS and bought a set of the 18" LS wheels for winter -- no issues at all. I have the 20" polished aluminum wheels for summer.
Good luck!
"If at first you don't succeed, conceal all evidence you tried in the first place."
StreetReporter is offline   Reply With Quote
Old 11-22-2010, 01:15 AM   #5
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
Actually your stopping the car. The larger Dia. rims and tires applying more torque only if the final Dia. is larger sense the 20" rim has a lower profile tire. Just sayin.
KEEP RT is offline   Reply With Quote
Old 11-22-2010, 01:17 AM   #6
KEEP RT
KEEP RT's Avatar
Drives: 2010 2SS/RS
Also I'd guess that the aluminum rims are lighter than the steel Haritage. but I'm not sure.
Old 11-22-2010, 01:19 AM   #7
2010Camaro55
Thanks guys for the quick info. Just so I have this correct I will have no issues
with the 20 SS wheels and and tires, and my current calipers and rotors should be fine as long as I stay with 20 or under? Just want to make sure before I press the buy it now on eBay ! Thanks
JC
Old 11-22-2010, 01:20 AM   #8
2010Camaro55
The Haritage wheels are heavy and ugly LOL..
Old 11-22-2010, 01:23 AM   #9
rally yellow ss rs
JC
You will still be able to break your vehicle , just not as short of a distance as you can now.
Old 11-22-2010, 01:26 AM   #10
2010Camaro55
I see, so learn to break sooner and my be replacing pad sooner then normal.
JC
Old 11-22-2010, 01:30 AM   #11
rally yellow ss rs
to easy... Just learned to break sooner when I put 20's and bigger heaver tires on my truck. COuldnt afford the brake upgrade, but then again I wasnt driving it around like I stole it...you know, the way us Camaro owners drive.
Old 11-22-2010, 01:41 AM   #12
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
you will be all good!!!
but why did your 2LT come with Heritage wheels?
Old 11-22-2010, 01:44 AM   #13
2010Camaro55
I know that all to well, Love the car just wish I would of stepped up and bought the SS.
O'well its still a Camaro..
Old 11-22-2010, 01:46 AM   #14
2010Camaro55
It was a demo that they swapped the original wheels and tires out for a customer that purchased an LS that was on the lot before me, So I ended up on the short end of the deal I guess.
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 01:26 PM
20" SS Sterling Silver Wheels and Tires New Takeoffs FS camarojake Wheels / Tires 1 04-13-2010 11:28 AM
CCW 505a's on a SIM SS 275 fronts & 315 rears robertway Wheels and Tires Talk Sponsored by The Tire Rack 63 01-20-2010 12:56 PM
2010 CAMARO SS 20 POLISHED WHEELS & TIRES 1,800 or Best offer comptect Wheels / Tires 11 07-23-2009 02:33 AM
