Old 11-24-2010, 09:30 PM   #1
RetiredRacer
Drives: 2LT RS ABM
Spare Tire - Silly Question
Since I've upgraded my 2LT / RS to the SS Brembo's front and rear, the factory spare tire is a "no go". Haven't really worried about it, but maybe I should. What are other folks doing for a "spare"?
RetiredRacer is offline   Reply With Quote
Old 11-24-2010, 09:51 PM   #2
ron10
Drives: 2010 2SS IOM L99
i bought one off of ebay.comes with lugs,jack,spacer and wrecch.
Old 11-24-2010, 09:53 PM   #3
FEN
FEN's Avatar
Drives: BLACK 2SS/RS
If you already have the OEM spare contact Gary's Custom and have him make you a 1 3/4" hub-centric wheel adapter.I have the 2SS/RS and ordered the OEM spare/jack/tools,etc and the 1 3/4" adapter allows the wheel to clear the calipers.I test fitted mine befopre i mounted the tire.My car does NOT have the "roller skate" weights.....if you have these you may also need to swap out the pads.I beleive i paid aprox $115 to have it made.
BTW: I only test fit mine for clearance on the front because i dont want to run a smaller diameter spare out back because of the SS diff. I beleive the rear rotor is .400 larger in diameter than the front so im not sure if there would be a problem? If i get a flat out back i will have to run my spare up front and move my front tire to the rear.You wont have this problem with the LT.
CCW polished 505a's
Front 20x10 w/275/40/20's
Rear 20x11.5 w/305/35/20's
Eibach 1" Pro Spring Kit
Factory GFX
MPD1 spoiler
painted bowties
15% tint
FEN is offline   Reply With Quote
Spare tire ordering question. Vorador Wheels and Tires Talk Sponsored by The Tire Rack 1 06-23-2010 12:02 PM
