![]() Drives: 2010 Camaro 1ss/Rs package Join Date: Feb 2010
i intslled my whole set up last night and it was pretty smooth but after i started it up i was adjusting the eq on the unit and all of a sudden my right rear speaker started making alot of noise as if it bleew im not sure what happen but i put the volume higher with more bass and the noise went away and the speaker sounded fine at a high volume but then i lowered it and it came back its just a steady loud static noise i just listended to my music loud but then when i got home i lowered it again before i shut the car off and my front right speaker started doing the same thing. an to make matters worse i was tired of working on it so i decided to just shut the car off.. Speakers still kept making noise i took out the key and closed the door and locked it and they still kept going i was afraid that the battery would get drained so i bulled the fuse from the truck thats for the radio and i havnt messed with it since then.
![]() i need help trying to fix it idk if its my unit or if its just the speakers. any help thank you guys an sorry for the huge story |
![]() Drives: 2010 2SS/RS L99 Join Date: Nov 2009
That sucks. Maybe double check the metra wiring. I'd look at the power and grounds first. If the Battery and ACC lines are mixed up it may not turn off.
they said i blew out the moduele of the kit something about it not being able to handle the base ? pls let me kno if this si true ? because im thinking these guys didnt kno what they were doing.. they told me that i cant put to much bass on it
![]() Drives: 2010 camaro Join Date: Nov 2010
damn that sux
BLESSEDCHEF10
does anyones head unit turn off or go blank when youre using the blue tooth just wondering cause mine does.
#6 |
![]() Drives: n/a Join Date: Dec 2010
seems i should stray away from the metra..
