Old 12-04-2010, 01:02 AM   #1
NewGen
NewGen's Avatar
Drives: 2013 Camaro ZL1
Send a message via AIM to NewGen Send a message via MSN to NewGen
Question Daily Driver
What would be the best type of suspension set-up for a daily driven car? Thanks in advance for all the info
Young Man wanting Big Power
NewGen is offline   Reply With Quote
Old 12-04-2010, 01:17 AM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Is it pure daily driver or will it include some track time too? What are your goals? How much $$ do you wanna spend? There's LOTS of things to consider other than just being a daily driver.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-04-2010, 01:22 AM   #3
NewGen
NewGen's Avatar
It may see some strip time but nothing major... maybe like $2500... i know i want to lower it and put sways on it but idk which route to go
Old 12-04-2010, 04:17 AM   #4
axis
Search Ninja
axis's Avatar
You can do a helluva lot with $2500. Lowering springs and sways would be my first choice. In fact they were, . Look at the offerings and decide how low you want to go. I wouldn't go any lower than 1.25in unless you want to be spending more on camber plates. The factory adjustment seems to be fine to 1.25in, then it gets dicey after that. You could also look into replacing a few of the bushings.
Obviously by my sig, i'm a fan of Pfadt suspension parts. TBH, I haven't tried the others but i'm very happy with my Pfadt springs and sways. Give them a call to see if they are still running specials. You can also check with Apex. They are well known distributor for them.
Halltech CF 102 fed
Old 12-04-2010, 08:50 AM   #5
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Thanks for the referral axis.
New Gen, $2500 can go a long way for a daily driver with limited strip use. I'll put something together and shoot you a PM.
Old 12-04-2010, 08:55 AM   #6
GEEo
OKCamaros
GEEo's Avatar
Drives: 4 banger Diesel
+1 PFADT!
Old 12-04-2010, 10:50 AM   #7
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
the best i can say is pedders daily driver package is the perfect way to go, it will tighten up the car where it needs to be and still give you an outstanding ride quality add that and a sway bar package and you are set and after install you will have a ton of money left over to take a nice trip and test out the suspension
camaro4mybday is offline   Reply With Quote
Old 12-04-2010, 11:03 AM   #8
Apex Motorsports
PM sent New Gen. That package should give you what you are looking for and help keep a lot of that money in your pocket. Let me know if you have any questions.
Old 12-04-2010, 11:10 AM   #9
ssmike
BL1ZZRD
ssmike's Avatar
Please tell us what you suggested!
Old 12-04-2010, 11:14 AM   #10
seddon
seddon's Avatar
Drives: 2017 ZL1
I say do the pedders Xa coils I had H&R springs they were ok but the coils were a night and day difference then add some sways and you will be good IMO
seddon is offline   Reply With Quote
Old 12-04-2010, 11:34 AM   #11
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
If you want see my thread on the Hotchkis tv1 install and My observations on the road. This is springs and sways only so the base start line as others have said.
VR Baron is offline   Reply With Quote
Old 12-04-2010, 11:44 AM   #12
Apex Motorsports
Ok. Since I grew up running the roads in Louisiana I know exactly what kind of use he is looking at. I suggested BMR 1 inch lowering springs, sway bars, and Total Suspension Bushing Kit along with a set of Pfadt rear trailing arms. That will give him a nice street setup that will also keep the rear end planted at the drag strip and leave plenty of money in his pocket.
Old 12-04-2010, 12:43 PM   #13
NewGen
NewGen's Avatar
Thanks for all the info guys
Old 12-04-2010, 12:43 PM   #14
NewGen
NewGen's Avatar
eventually i plan on adding some 22s to it as well
Where we are coming from (check inside) ljustin293 2010 Camaro5 Fest (I) 106 05-13-2010 12:31 AM
Camaro 5 Fest Drivers or Spectators garcmol 2010 Camaro5 Fest (I) 427 04-23-2010 03:32 PM
CLOSED - Driver Signup for the 1st Annual Official Camaro5Fest (April 16-18, 2010) GTAHVIT 2010 Camaro5 Fest (I) 923 03-20-2010 12:56 AM
