Old 12-09-2010, 06:57 PM   #1
DCC1464
COTW 5/27/13
DCC1464's Avatar
Drives: '11 S/C SS/RS CGM
Question both sides mounted 12's ?
Looking to install 2 12's but i dont care much for the Dual box's.
Was wondering if anyone has tryed or seen side mounts for both driver and passenger side?
DCC1464 is offline   Reply With Quote
Old 12-09-2010, 06:58 PM   #2
Indpowr
Drives: Corvette C6
We did ours in the center. I have seen dual tens on the sides..
Old 12-09-2010, 07:44 PM   #3
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
two 12's???? but, why??? you're 2 feet away from them.
a single 10" can be heard for two blocks.
10/28/2010 got it
y2k king is offline   Reply With Quote
Old 12-09-2010, 07:48 PM   #4
Indpowr
Drives: Corvette C6
Maybe he wants to be heard from 4 blocks...
Everyone has what they like. Some Camaro owners want 1000hp.
Old 12-09-2010, 08:15 PM   #5
JSC81
JSC81's Avatar
Drives: 2010 1SS/RS M6
You can get a seperate box from stealthbox for both sides ea holding one 12.
On a seperate note based of the one 10 comment Im with you I used to go 2x 12" and this time I figured hell save some trunk space mount one quality speaker (10" JL W7" is more than enough to make my ears ring.
JSC81 is offline   Reply With Quote
Old 12-09-2010, 08:17 PM   #6
Indpowr
Drives: Corvette C6
We still have 1/2 of our truck space with 2 12s. . It was a requirement that our horse saddle and gear would still fit in the trunk...LOL
Old 12-10-2010, 02:23 AM   #7
cdigiovanni
Drives: 2010 SS2, 03 vette supercharged,
put a great set of tens in a band pass box remove rear 6x9s fire a port thru 6x9 location. place 6in sep in the rear side panels for perfect sound and bass
cdigiovanni is offline   Reply With Quote
Old 12-10-2010, 05:36 AM   #8
Glizzy6d
Drives: 2011 1LS Black
nvrmnd, just read/ the part about 6inch lol
5TH GEN CAMAROS OF THE CAROLINAS
Member since 10Dec2010
Glizzy6d is offline   Reply With Quote
Old 12-10-2010, 04:03 PM   #9
Topdown
The wait is over!
Topdown's Avatar
Drives: 2010 Camaro, IOM, L99, Auto
instead of giving my opinion on whether its a good or bad idea...
yes, you can mount 2 12's in the side-boxes... you will need to find a 12" sub that likes a small-ish enclosure (Phoenix Gold RSDC or a Dayton HO for example) since the enclosures wont be very big, and your going to need to make sure you have a sub that can fit the depth (dont forget to give around 3/4" behind the sub for cooling).
I dont know what enclosure your looking at (******** makes a real nice enclosure thats fairly inexpensive) or I might be able to recommend a sub that will fit. Obviously if you go with a custom enclosure (fiberglass) you can make the enclosure size whatever you want and fit virtually any sub you want.
Ordered - 4/17/2010
Delivered - 5/29/2010
AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener
Topdown is offline   Reply With Quote
Old 12-10-2010, 06:43 PM   #10
DCC1464
COTW 5/27/13
DCC1464's Avatar
little update, E-mailed ******** and was informed that a 12 will not work on the passenger side in a stealth box. sooo look like im gona either go with a custom made or give up and do a dual box
Old 12-10-2010, 07:19 PM   #11
xxlbeerz
xxlbeerz's Avatar
Drives: 2010 Black on Black
I just installed the ******** large box for one 12" on the d-side with 1500w amp. Hits hard enough to blur vision when up... right there with the two 10w6 and 1000/1 I had in my last car and my trunk is perfectly usable.
xxlbeerz is offline   Reply With Quote
Old 12-10-2010, 10:52 PM   #12
mrray13
Drives: 2010 1LT RS Rally Yellow
What is 6in sep?
And bandpass in the same statement as perfect sound and bass? Do you know how hard it is to design a bandpass enclosure that isn't a one note street beater wonder? Then you have to back it up with proper mid bass, mid range and tweeter crossover and staging! And do all this in car, which is the absolute worst medium for anything perfect in SQ.
Unless you have experience designing and building enclosures, stay away from bandpass, unless all you want is typical street beater thump. It won't be any where near truly perfect sound and bass, which is most likely never going to be achieved in a car anyway.
mrray13 is offline   Reply With Quote
Old 12-14-2010, 09:11 PM   #13
cdigiovanni
Originally Posted by mrray13 View Post
What is 6in sep?
thanks for your input... althought im not a builder I use a amazing shop to build my systems... Sound Station in SINY... anyway...
I have a bandbass box with 2 10s, firing from a sealed box into another box with a huge ports (5inx8in) firing thought where the 6x9 were. the key to this set up is the port size, in most cases the ports arent big enough to handle the air movement of the sub. so yes in that case in would be a "typical street beater" ..... president of ARC audio and other ARC audio reps have heard my car and they are plenty satified with the amount of bass and sound from their 10's..... push 300watt to each sub! any they can handle an play any genre of music... w/out the 6x9s I installed 6in separates for midbass etc in the rear panels.
Arc shipped the car out to cali to have it on display.
Old 12-15-2010, 03:15 PM   #14
copper3000
Troy
copper3000's Avatar
Drives: 2018 ZL1 Camaro
Me too! Way more power than I could ever use...
******** rocks!!
copper3000 is offline   Reply With Quote
12's, dual, side mounted
The Radar / Laser MEGA thread raqball Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 116 01-29-2017 12:04 AM
Razzi SS GFX Sides and Back motor1 Exterior Parts & Accessories 8 06-23-2010 09:54 AM
Kicker 12's or Kenwood 12's atlang3lo Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 19 05-17-2010 02:17 PM
Some Texas Lighting Laws Mecha USA - Texas 5 10-20-2009 02:49 PM
