Old 12-09-2010, 09:44 PM   #1
mtcwby
High on "The Camaro Life"
mtcwby's Avatar
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam
Send a message via AIM to mtcwby
Rear Alignment Specs for Drag Racing
Could anyone give me some good alignment specs for the rear of a Camaro for drag racing. I want it to still be good for everyday driving, but need to get the contact patch as good as possible for launching at the strip.
I'm running 18X9.5 +40 offset Corvette wheels and Mickey Thompson 305/45R18 Drag Radials.
Thanks!
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
mtcwby is offline   Reply With Quote
Old 12-14-2010, 05:41 PM   #2
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
We are running the same wheel/tire setup and pushing 610 to the rear wheels. It all depends how violent your car launches and how far it squats during launch. A really "squatty" launch will have a lot of negative camber and less tire contact with the track. Running some positive camber, even if it was just .25 degrees would be ideal for a track-only car but handling will suffer on the street.
We have run between 1.54-1.56 60 ft/times 4 different times on 4 separate tracks using -.5 degrees of rear camber. This is just our street setting and I'm sure we are probably seeing some excessive negative camber off the line but on a prepped track we have had zero wheelspin so there has been no need to adjust it any differently....so far
BMR guy is offline   Reply With Quote
Old 12-15-2010, 01:01 AM   #3
DMSDesign
Suspension Specialist
Drives: 2011 Camaro
You will want to reduce rear negative camber to the max. Even then you are not maxing out on what can be done with rear cambers. Pedders does make a rear camber kit that is easy to install, and you may get an additional .5 or so less negative camber. With these eccentrics, it is possible to get up to +.5 degrees camber on the rear. This is ideal for a launch if launching is your primary desire. Not real good for handling in the corners, however.
mike
dms
DMSDesign is offline   Reply With Quote
Old 12-15-2010, 09:35 AM   #4
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
I agree with Mike, if drag racing is your pure objective then set your camber out to +.5 +.75 depending on how hard the car is coming off the line. The goal is to get the tires to 0 camber at launch and heading down the track this will promote the highest friction patch.
Regards
IPS Brandon is offline   Reply With Quote
Old 12-15-2010, 12:30 PM   #5
BMR guy
BMR guy's Avatar
Drives: 2010 1SS
I think people are missing your statement that you want a setting for the track that is still fine for the street. Obviously you can run positive camber for ideal track settings (up to 1 degree depending on how hard your car squats) but positive camber is not recommended for street driving, especially if you want the car to handle.
My point in my above post is that we are running 10.90's with a 1.5 sixty foot time using our street setting of -.5 degrees. This setting works great on the street and has yet to be a problem at the track...
Old 12-16-2010, 12:35 AM   #6
mtcwby
mtcwby's Avatar
Thanks everyone for all the good feedback. I'll probably go with about a neutral or 0 camber with me sitting in the car and 1/2 tank of fuel.
Then when road tripping, with all my stuff in the trunk and a full tank of gas it will be good on the curvy mtn roads.
Old 12-16-2010, 11:05 PM   #7
redjeff
Drives: Too many to list!!!
Honestly for what your asking I would just try and zero everything out. Maybe a little negative camber for more comfort daily.
redjeff is offline   Reply With Quote
Old 12-17-2010, 09:12 AM   #8
Bruce@raymondsperformance
Bruce@raymondsperformance's Avatar
Drives: 2014 Z28 camaro
We have been setting the drag\street driven cars at 0 on the rear camber and have been getting good traction aswell as good every day performance.
Bruce@raymondsperformance is offline   Reply With Quote
Old 12-20-2010, 12:25 PM   #9
JusticePete
Drives: Camaro Justice
Listen to the Pedders Specialists as they are giving you excellent information.
At the strip at full squat you want your rear tires as square to the pavement as possible. Most cars set up for drag will be running wider rear tires and stockers up front. That is a prescription for understeer. Reducing the rear camber to 0 or a bit positive will reduce the push / understeer.
Think of it this way. The rear IRS is as good as any IRS on any production car being built today. The front strut with virtual pivot point functions well, but not as well as a CTS Caddy. They are in some ways a mismatch with much greater grip in the rear than the front. Add to that the front weight bias and you can see why a drag ready alignment will work quite well on the street.
Old 02-25-2017, 08:57 PM   #10
PFL
PFL's Avatar
Drives: Camaro SS
Which Camber should go for a 100% drag race car, drag street? I do not care about comfort. I need to get a perfect launch.
PFL is offline   Reply With Quote
Old 02-25-2017, 09:54 PM   #11
JusticePete
If you are not running skinnier, the more negative camber you run up front the better. Max inflate your front tires and combined with high negative camber the car will act like you are on fat skinnies.
Old 02-25-2017, 10:03 PM   #12
PFL
PFL's Avatar
Drives: Camaro SS
Thank you for your help. I'm using drag radial for rear, should I use Positive Camber for rear?
Old 02-25-2017, 10:17 PM   #13
JusticePete
Zero, not positive.
Old 02-26-2017, 08:43 AM   #14
se7en
Drives: 10 Procharged SS
Pete my brother........ for drag racing these cars need some positive in the rear.
se7en is offline   Reply With Quote
Discounts for our Military Personnel from MTI Racing MTI Racing V8 Bolt-Ons & Tunes 1 07-02-2010 01:13 PM
PFADT Racing rear trailing arms now shipping! Team STILLEN Suspension / Chassis / Brakes 0 03-09-2010 08:05 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
