Old 12-12-2010, 07:21 PM   #1
BowlingSS
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT
Transmission Fluid Change
I was changing my oil for the first time the other day and was looking at how to change the transmission fluid. Where is the fill point on a L99? I assume you have to remove the pan to change the fluid. What is that big bolt on the bottom of the pan?
Thanks.
Bill
BowlingSS is offline   Reply With Quote
Old 12-12-2010, 08:00 PM   #2
2010 2SS RS
Drives: Metalic Silver 2010 Camaro 2SS RS
Thanks.
Bill
Ok the big bolt on the bottom of the pan is a drain plug, so you don't have to drop the pan every time you wanna change the fluid only when you wanna change the filter and like any auto tranny I've every worked on you fill it from the dipstick opening with a funnel the exacty amount of tranny fluid you have to put into it is listed along with other useful info is in your owners manual !!
2010 2SS RS is offline   Reply With Quote
Old 12-12-2010, 09:10 PM   #3
SwedeandBlondie
SwedeandBlondie's Avatar
Drives: 2011 Black 2SS/RS L99 on order
I did a cursory check for a dipstick, but came up short. I didn't look real hard though. Where can one find the tranny dipstick?
Frank and Kim
2011 SS/RS Black on Black (Born 11/18/2010)
2011 Hemi Ram Crew Cab 1500 4X4 Black on Black
2009 HD Street Glide
2005 HD Fatboy
SwedeandBlondie is offline   Reply With Quote
Old 12-12-2010, 09:16 PM   #4
Wreckwriter
G8 Racer
Drives: 08 Pontiac G8
If it's the same as the G8, and I bet if is, you can find it in your dreams. Fm doesn't trust us to put the right fluid in. Checking /adding is a major pain.
Sent from my DROID2 using Tapatalk
Wreckwriter is offline   Reply With Quote
Old 12-12-2010, 09:33 PM   #5
Scott@Bjorn3D
Sealed unit, there is no dipstick for it. You drain it and then you have to have a pump to pump it back in. I am leaving that up to my dealer, do not want to F'up the tranny.
Scott@Bjorn3D is offline   Reply With Quote
Old 12-12-2010, 09:37 PM   #6
Wreckwriter
G8 Racer
It isn't sealed, simply lacks a stick.
Old 12-13-2010, 06:34 PM   #7
BowlingSS
OK where do you put the fluid? Is it like the rear end with a fill and overflow plug?
Bill
Old 12-13-2010, 06:45 PM   #8
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
This might help you out...
http://www.camaro5.com/forums/showthread.php?t=102482
SlowSS is offline   Reply With Quote
Old 12-13-2010, 06:56 PM   #9
hypurone
I'm not totally useless..
hypurone's Avatar
Drives: ...
Originally Posted by SlowSS View Post
He's asking about an L99, that would be an A6 not an M6.
Anyway, the big "bolt" thing (a tube actually running up into the pan) is actually used to tell when the trans is full. If full with this removed some fluid will come out. It will NOT drain the trans or even the pan.
The fill point is supposedly on the right side of the trans just above the top of the pan. Very hard to see...I still have not found it, tho I haven't had mine on a lift with time to search for it....
"You were really flyin' when I passed you back there!" - Born on 10/05/09 MyCamaroBuildInfo
hypurone is offline   Reply With Quote
Old 12-13-2010, 09:01 PM   #10
BowlingSS
So I guess you have to take the pan off to drain. I will have to look the next time I am under there. I guess you have to pump the fluid into the fill hole.
Bill
Old 12-14-2010, 08:44 AM   #11
hypurone
hypurone's Avatar
Drives: ...
Bill
Yes, drop the pan to drain some and change the filter. Still have not been able to ascertain whether or not our TC has a drain as well. A hand or air driven pump is def needed to refill.. Don't see this happening on the ground or ramps, gonna need a lift. What a PITA....
Old 12-14-2010, 09:05 AM   #12
BowlingSS
Does anyone have a picture of the fill plug? Is it like the plugs on the rear end?
Bill
Old 12-14-2010, 09:53 AM   #13
Wreckwriter
G8 Racer
Assuming it's like the 6l80 it's a little plastic plug. Pulls out with fingers. Passenger side of trans near front on top.
Old 12-14-2010, 04:00 PM   #14
BowlingSS
It is a 6L80E I think so it is probably in the same location.
Thanks.
Bill
Understanding Brake Fluid: DOT 3, DOT 4, DOT 5.1 TAG UR IT Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 58 12-01-2019 10:54 PM
