Old 12-23-2010, 03:36 PM   #1
JFR1
JFR1's Avatar
Drives: 2011 1LS. Garaged:Stock 69 Z28
Help - Mod Problems - Tires and Wheels killing MPG?
Situation:
'Have a 2011 LS with 3K miles. Added Flowmaster exhaust and Air Raid CAI within a week of first putting on the road. Factory Heritage wheels 245/55r18. About 35lbs per wheel. Spirited driving, 20% on interstate. When cruising, try to keep RPMS less than 2000 equals about 66mph and 33mpg on computer. Overall MPG calculated (not computer) after 2500 miles at 25-26. Computer showing 24mpg.
Local dealership had a set of 2LT wheels and brand new tires, $1100 for the set. Wheels have been triple plated chromed - look great. 245/50R19. 31lbs per wheel.
Problem:
MPG has fallen to 18-19mpg. I havent changed driving habits. I can feel the difference in the new Pirelli 19's vs the BR Goodrich 18's. Checked spedometer with GPS - right on. Both calculated and computer MPG same.
Could this small tire/wheel change make my MPG fall (25%)? The 19" wheels and tires are factory 2LT. Window sticker MPG is same on an LS and 2LT. Local dealership service department does not have a clue.
I wonder if GM has engine programmed differently for LS vs 2LT???
Dealership wants $150 to diagnose on computer. I know they will tell me the changes I made on exhaust and CAI is the problem. But I was getting Better MPG after adding exhaust and CAI. Only other change is wheel/tires.
Appreciate any ideas and Help. Merry Christmas!
JFR1 is offline   Reply With Quote
Old 12-23-2010, 03:58 PM   #2
PlantCityPete
PlantCityPete's Avatar
Drives: 2010 1LT/RS IBM
Put bigger (taller and wider) tires on two previous trucks, both lost about 3 miles to the gallon on each. i have 1lt with 20 inch wheels, exhaust and cai , get average 20mpg. And thats mostly 75 to 80 on interstate. (80% highway)
PlantCityPete is offline   Reply With Quote
Old 12-23-2010, 04:03 PM   #3
PlantCityPete
By the way make sure you are running correct air pressure for that tire.
Old 12-23-2010, 04:05 PM   #4
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Makes no sense at all. The change in diameter is only .1 of an inch by going from the 245/55/18 (28.6") to the 245/50/19 (28.7"). If anything you should be getting BETTER mileage with the lighter wheels. If you've got a good dealer who's not going to dick you around, something doesn't seem right. But you're correct, if they are shady, they could blame it on any number of things you did. I'd take it in, explain to them the order of things (CAI/Exhaust before the mileage drop) and see what they say. But I gotta tell you, I've never gotten that "before" mileage on my car! 18-20 mostly city, but still, you must have a light foot!
Might wanna post a link to this up in the wheels/tires section, may get more responses.
[B]
Old 12-23-2010, 04:06 PM   #5
CamaroDreams07
Drives: Slow V6
Absolutely great point that I completely overlooked. That makes a big difference. Good catch Pete!
[B]
Old 12-23-2010, 04:30 PM   #6
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
Originally Posted by JFR1 View Post
Situation:
Problem:
Are you in the "COLD" part of Florida? I know you guys are having a bit of a cold snap down there... MPG goes down when it gets cold...
Do you use the same gas station?
scrming is offline   Reply With Quote
Old 12-23-2010, 07:44 PM   #7
VASCAR2
VASCAR2's Avatar
Drives: 94 Camaro, 10 1LT IBM Camaro
I can easily effect my MPG by 2 or 3 miles per gallon by how aggressively I drive on acceleration. I also notice my MPG went down in the winter with the different blend in winter gasoline by at least 2 MPG. My 1LT auto is stock and has 19" polished aluminum wheels with Pirelli all season tires at 35 PSI. I have about 50/50 city/highway driving and average anywhere from 20 to 24 in summer depending on how lead footed I am. I've gotten 29 MPG on interstate going 70 to 75 MPH for a 300 mile trip. Last winter the best mileage I got was about 21 maybe 22 MPG in my normal local driving. The more highway miles the more my mileage goes up. The more stops and starts the lower my mileage is.
VASCAR2 is offline   Reply With Quote
Old 12-24-2010, 08:45 AM   #8
verboten
Drives: Black
The thing about wheels is you have to spin them, and that takes much more effort than it does to move an object that isn't spinning. You're dealing with the polar moment of inertia.
In fact, just for fun I looked up how much straight-line performance you'd lose by switching from 16" wheels to 20" wheels if the wheels weighed the same. It'd be about like adding 200 static weight to the car, which would take an additional 11ft-lbs of torque (roughly 15hp @ the rev limiter) to compensate and get the same acceleration as a stock car. That's bad enough.
In addition, that extra 200lbs of equivelant weight that you're adding to the vehicle? You're going to have to slow it down, too.
verboten is offline   Reply With Quote
Old 12-24-2010, 08:53 AM   #9
JFR1
JFR1's Avatar
Thanks to All - Merry Christmas
Thanks all for the input and advice. Seems that my mpg at 19 is about what others are getting. Just cant understand the drop.
Does anyone know if the factory 'tune' is different for a 1LS auto vs a 2LT auto? I may just get Ted at Jannety racing to re-tune the computer. Thanks.
Old 12-24-2010, 09:43 AM   #10
GretchenGotGrowl
GretchenGotGrowl's Avatar
Drives: 11 F150 EB/13 Sonic RS/15 Z06
I'm pretty sure the tunes are the same. Like CamaroDreams07 pointed out, the difference in overall diameter of the wheels is only 0.1 inch, so that will have almost no affect on the speedomter calibration. It is mostly like what Scrming suggested -- colder weather means worse MPG. Mine has gone down about 1 MPG around town. If they only put ethanol in your gas during the winter, then that may explain why you saw a bigger drop (we have it year around here). Also, I don't discount that you may be driving a little more aggresively because these cars love the cold weather.
New Ride -- 2015 Z06 2LZ (stock) -- Journal
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread
GretchenGotGrowl is offline   Reply With Quote
Old 12-26-2010, 02:18 AM   #11
a red maro
Drives: Victory Red 2lt RS V6 auto
i have a 2lt and haven't changed the tire size or anything and the computer on my car tells me that I'm doing about 24 mpg mostly in town some highway miles. that's with exhaust and CAI. never looked at the mpg before the mods, but in know that both of the mods that i have are supposed to improve mpg am i correct?
a red maro is offline   Reply With Quote
Old 12-26-2010, 06:08 AM   #12
JFR1
JFR1's Avatar
Yes - performance exhaust and CAI are supposed to increase MPG. Thats one of the reasons my case is so perplexing. However, it appears that 19-20 is not unusual.
Old 12-26-2010, 11:02 AM   #13
ljones
ljones's Avatar
Drives: 2011 2LT RS
I have the polished 20s, and I'm at 18.4. The number has been creeping up slowly, and I haven't changed my driving habits. Only difference, I switched from premium to regular at Costco. I'd love to see 24, given I'm on the interstate about 70% of the time.
MRT V2.0
ljones is offline   Reply With Quote
Old 12-26-2010, 11:08 AM   #14
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
Not about the Camaro but when Dennis put the skinny snow tires on his pickup and took his fatties off he commented on that he was surprised to find he was getting WAY better gas mileage.
Tori
Problems with Savini - beware Darth_Emma Vendor and Seller review / feedback / experiences 115 12-22-2010 10:51 AM
Ok, I now have my wheels :D PQ Wheels and Tires Talk Sponsored by The Tire Rack 722 12-19-2010 12:13 AM
My Experience with Iconz Wheels. EDISKRAD EHT Vendor and Seller review / feedback / experiences 40 05-13-2010 10:18 AM
NEW CHROME WHEELS 18"--fits tires on ugly steel wheels on LS 2010 klondike Wheels / Tires 2 04-13-2010 04:26 PM
