Old 12-31-2010, 07:10 PM   #1
motomediafx
motomediafx's Avatar
Drives: 2011 Camaro
Painted Door Panels / Dash Inserts
I have been looking to buy the factory painted door panels with dash pieces, the four piece kit that GM sells. My question is can I take the stock panels that are already installed and remove the fabric cover, and then have them painted? My car is going to the body shop for some paint repair and they mentioned they would shoot some small interior pieces if I had any I wanted done, since they will have the paint mixed already. Any idea?
motomediafx is offline   Reply With Quote
Old 01-01-2011, 10:14 AM   #2
Darth Martel
Darth Martel
Darth Martel's Avatar
Drives: Black 1SS with 20% tinted windows
Yes, you can remove the fabric from the door panels and the dash trim. It's much easier to remove it from the dash trim since they use minimal amounts of adhesive and staples. The door panels are a pain in the ass to remove the cloth from but, it's doable. What really sucks is it's not only cloth but, a foam backing and it likes to stay on the panel when you pull off the fabric.
The secret to painting is good prep work so, the panels need to be completely free of the foam and glue before it's painted. Perhaps, somebody could chime in on the best way to remove the cloth and other stuff. I used isopropyl, a razor, and in the end used sand paper. I didn't end up painting it though. I used a black pleathor fabric and some spray adhesive and it did the trick. If I change my mind, down the road and want a different color or a graphic on the panels, it's as easy as removing the fabric and putting on a vinyl wrap or whatever. I have DIY thread somewhere in the DIY forum if you'd like to check it out. There's also threads in the DIY area on painting the panels.
Darth Martel is offline   Reply With Quote
Old 01-01-2011, 10:53 AM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Yes you can paint them, But there not the same and need to panted on the out side, and dos not have the ABL prevision in them, There not clear, More a milky white.
Old 01-01-2011, 01:00 PM   #4
Alain
Alain's Avatar
Drives: 2016 Challenger Hellcat, 2018 ZL1LE
i'm looking to do this myself. looking to save the money it would cost to buy the GM ones
Alain is offline   Reply With Quote
Old 01-01-2011, 09:45 PM   #5
ssummit camaro
ssummit camaro's Avatar
Drives: 2013 1LE on order TPW 12/31
anyone got any good links on how to remove them step by step
ssummit camaro is offline   Reply With Quote
Old 01-02-2011, 05:29 PM   #6
motomediafx
Drives: 2011 Camaro
Thanks. Yes I hear they are a pain to remove, but the results will be worth it.
New from RPI Designs! Pre-Painted Interior Door Panel Inserts! All Colors Available! RPI Designs Interior Parts & Accessories 108 07-29-2020 08:27 AM
Painted dash gages Blue Demon Cosmetics and Lighting Modification Discussions 3 11-20-2010 09:09 PM
New from RPI! 2010 Camaro Pre-Painted Body Color Rear Spoiler! $399.00, painted! RPI Designs Exterior Parts & Accessories 10 03-25-2010 02:42 PM
SLP Black Painted Wheels With Machined Face 20" x 8" / 20" x 9" tbyrne Wheels / Tires 9 01-18-2010 11:41 AM
Do the IOM with IOM interior have IOM door panel inserts, and dash trim? dragonZ28 5th Gen Camaro SS LS LT General Discussions 14 11-12-2009 09:22 PM
