Old 01-03-2011, 03:50 PM   #1
toothfangandclaw
toothfangandclaw's Avatar
Drives: 2010 Camaro 2SS/RS SIM
Question Storage question: Flat spot stoppers?
I searched and read most of the winterizing threads. I've noticed some recommend jacks to prevent flat spotting of tires. I've seen some products generally called "flat spot stoppers" that look to be plastic or rubber that fit under each tire. Has anyone used these, do they work, and if so is there a brand you recommend?
I found these 2 through searches:
http://www.griotsgarage.com/product/...o?code=FROOGLE
http://www.kmjent.com/cart/product.php?productid=5099
Thanks in advance,
-Toothfangandclaw
1000 Dealer Ordered (3.1.10)
1100 Preliminary order accepted (3.2.10)
2500 Order preferenced (3.2.10)
3000 Order accepted by production control (3.3.10) TPW = 3.15.10
3300 Order scheduled for production (3.6.10)
3400 Order Broadcast (3.11.10)
3800 Order produced (3.19.10) 2G1FT1EW3A9205722
4200, Shipped (3.23.10)
5000, Delivered to the dealer (4.5.10)
Picked up at Reedman-Toll (4.5.10)
toothfangandclaw is offline   Reply With Quote
Old 01-03-2011, 04:47 PM   #2
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
Buy some 2 inch thick styrofoam (closed cell). cut into 1 foot squares and drive up on them or jack up onto. They will compress into the proper radius of the tire.
zen is offline   Reply With Quote
Old 01-03-2011, 07:05 PM   #3
first one
first one's Avatar
Drives: SSRS - black, GFX, SSX wheels
Once you drive up on the styrofoam, won't it just flatten out and not support the radius of the tire? Seems like it needs to be made of a material that is supportive and when compressed, it will need to return to it's original shape to support your tire. Please tell me if I'm wrong.
Edit: Wow, $259.00 for 4 pieces of plastic. Seems excessively high to me, or maybe they were high when they set the price.
first one is offline   Reply With Quote
Old 01-03-2011, 07:21 PM   #4
mickss
mickss's Avatar
Drives: 2010 Camaro LS-M6 67 Chevelle Wgn
Or you could do what I do, go out to the garage every 2 weeks and roll the car back about 12" and 2 weeks later roll it forward 12", never had a flat spot issue with any car I have done this with. It also helps if you over inflate to 50 lbs.
mickss is offline   Reply With Quote
Old 01-03-2011, 07:44 PM   #5
Tantalizer43
Tantalizer43's Avatar
Drives: 2010 Camaro SS/RS
I am using the Race Ramps Flatstoppers. This will be my first winter using them, because I did experience flat spots after storage last year.
It's a little too early to tell if they're working, but the design and construction of the ramps are nice.
I did not compare prices from the websites you posted, however you can buy direct from Race Ramps.
www.raceramps.com
Tantalizer43 is offline   Reply With Quote
Old 01-03-2011, 11:44 PM   #6
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
5 yrs of storing the Corvette and all I've ever done is put in 40 PSI and never had a flat spot.....
Cyber/Orange10 is offline   Reply With Quote
Old 01-04-2011, 12:49 AM   #7
98nosz28
Drives: 1998 Camaro Z28
from what i could find it was a big problem with the bias ply but not the radials any more. I stored my old camaro with nitto drag radials and never had a problem.
07 Escalade, CAI, Corsa exhaust, predator tuner.
2011 SS/RS synergy green, sunroof, M6. Street scene ground effects, hood spear and shark fin decals from ridergraphix.
98nosz28 is offline   Reply With Quote
Old 01-04-2011, 10:01 AM   #8
Big Brunsy
Drives: 2010 supercharged LS3
I noticed very minor flat spots after storage last year but they were gone after only a few miles of driving.
Big Brunsy is offline   Reply With Quote
Old 01-04-2011, 10:04 AM   #9
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Over inflate the tires to 45-50lbs of pressure. You will never have a problem with radial tires that way. I've been doing it for years with all of my cars.
stratman2SSRS is offline   Reply With Quote
Old 01-04-2011, 12:47 PM   #10
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
+1
Old 01-04-2011, 01:05 PM   #11
ssmike
BL1ZZRD
ssmike's Avatar
2x2 thick pile carpet remnants under each wheel.
Old 01-04-2011, 01:19 PM   #12
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
+2
INTIMIDAT3R is offline   Reply With Quote
Old 01-04-2011, 03:31 PM   #13
Ivas
el Ruco
Drives: 2010 Camaro SS (now runnin' TENS )
Raise the car up off its wheels. If you're lazy, two floor jacks, one under the left rear and the other under the right front (or vice versa) will do the trick in a couple of minutes.
Ivas is offline   Reply With Quote
Old 01-04-2011, 03:35 PM   #14
Shurenuff
Shurenuff's Avatar
Drives: 2002 Nissan Altima
I've heard that's not good to do for long periods of time since the suspension is designed to have the load of the car.
Shurenuff is offline   Reply With Quote
flat spot, storage, tires, winterize
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 01:27 PM
Storage flat spots? khalsa013 Camaro DIY & HOW-TO instructions & discussions 8 01-27-2011 11:18 PM
Prep for Winter Storage Question INTIMIDAT3R Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 5 11-13-2010 12:45 PM
Avoiding Flat spots on your tires during winter storage?? Camaro Freak Wheels and Tires Talk Sponsored by The Tire Rack 20 10-24-2010 02:05 PM
