Old 01-08-2011, 06:49 PM   #1
FirstCamaro23
FirstCamaro23's Avatar
Drives: 2010 1977 1LT Camaro
Need Help with my Battery! Please advise
I need some advice.
I live in Wisconsin, so at the beginning of Decemeber, I got my camaro ready for winter storage. I washed and waxed it, put stabil in the gas tank, put foam under the tires, and put my cover on it. My garage is attached to my house, insulated, but unheated.
Today i opened the door to get something out of it, and i noticed the dome lights did not go on. I put the key in the ignition and the battery was as dead as a door nail!!!!! I can't believe that after only 1 month of storage, the battery would drain completely. I verified i did not leave my dome light on in the cab also.
So, my question is Has anyone else run into this problem with their winter storage?
I tried to charge the battery though the positive terminal and grounding bar that is under the hood, and it kept tripping the charger. Do i need to charge the battery directly when this happens?
To prevent this happening, should i invest in a battery tender for the winter too?
I appreciate any comments on this issue
2010 1LT Cyber Gray Metallic - Automatic, Convenience and Connectivity, Boston Acoustic Sound
Order Placed - 2/27/10
1100 = Preliminary Order Accepted - 2/27/10
2000 = Accepted By GM - 5/5 FINALLY!!!!
2500 = Order Preferenced - 5/5
3300 = Order scheduled for production - 5/11 TPW = 5/17
3400 = Order Broadcast - 5/15
3800 = Order Produced - 5/21
4000 = Bayed for Shipment - 5/26
4200 = Shipped - 6/1
5000 = Delievered to Dealer 6/8
6000 = Picked Up by Customer 6/8 101 DAYS!!!
FirstCamaro23 is offline   Reply With Quote
Old 01-08-2011, 06:59 PM   #2
Camaro_Custom_Painted
Choke on that causality!
Camaro_Custom_Painted's Avatar
Drives: 2010 2SS/RS
I can't speak to the amount of draw on the battery while not running, so I don't know how long it will last before going dead. But you most certainly should have a tender on it, for no other reason than a dead battery will freeze whereas a charged one will not.
Edelbrock EForce - Stainless Works Headers - BMR Sways & Arms & Toe Links & Control Arm Bushings & End Links - Rotofab CAI - Assorted Interior, Exterior, Underhood Bling - Red Jewel Stripes & Full Body Clear - Lexani LX15 Wheels - JRE Fuel Rail Upgrade - Kenne Bell BAP - Heartthrob XPipe - Elite Catch Can - Pedders Cradle & Front Arm Bushings - Hotchkis Strut Brace - MSD Wires - Carbotech Brakes - DSS 1000HP Axles & Driveshaft - Mickey Thompson Tires - Halo Harness - AutoMeter A/F, Boost, Fuel Pressure Gauges - Whats Next?
Camaro_Custom_Painted is offline   Reply With Quote
Old 01-08-2011, 10:05 PM   #3
C586
Drives: 2011 Camaro LS
Yes. Get a tender. Charging a battery and letting it die and repeating that cycle is about the worst thing you can do for a battery. If my car is going to sit any longer than a week my tender goes on. Get a deltran one and it installs and you just plug it in when needed.
C586 is offline   Reply With Quote
Old 01-08-2011, 10:13 PM   #4
Rogey89
ZL 1 3 7
Rogey89's Avatar
Drives: '23 ZL1
I did everything you've done, with the addition of the battery tender. I highly recommend it.
'11 2SS / '23 ZL1 / '23 Silverado ZR2 Daily
Rogey89 is offline   Reply With Quote
Old 01-08-2011, 10:32 PM   #5
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
Yes. The battery tender is a must.
Tori
Old 01-09-2011, 08:23 PM   #6
FirstCamaro23
One clarification is that I only had the camaro stored for 3 weeks!
I am a little worried if my battery is completely drained after only 3 weeks. Something else is going on here that is drawing a lot of amps from the battery.
Old 01-10-2011, 03:25 AM   #7
bono83
bono83's Avatar
Drives: 1969 Chevelle, 2010 1LT
Tender is a must for storage, but your battery should't be dead after only 3 weeks.
Order: 5/23/09 - Deposit given with order at dealer.
1100: 6/26/09 - Order placed by dealer - no allocation
2000: 8/15/09 - Accepted by GM.
2500: 8/18/09 - Preferenced.
3000: 8/18/09 - Accepted by Production Control.
3100: 9/9/09 - Available to Sequence.
3300: 9/9/09 - Scheduled for Production.
3400: 9/19/09 - Broadcast.
3800: 9/29/09 - Produced.
4000: 9/29/09 - Available to Ship.
4150: 9/29/09 - Original Invoice.
4200: 10/6/09 - Shipped.
5000: 10/13/09 - Delivered to Dealer.
6000: 10/13/09 - Delivered to Customer.
bono83 is offline   Reply With Quote
Old 01-10-2011, 05:29 AM   #8
djsnoflake
Faith Keeper
djsnoflake's Avatar
Seems kinda weird to me that it would trip your charger, combine that with it going dead in only 3 weeks, and it seems even more suspicious.
Old 01-10-2011, 06:23 AM   #9
Tazdevil
Drives: 2010 Camaro 2SS
Heres the bigger question, if cars are sittting in a dealership all winter with no battery tender on them, what do they not die? Mine has been closed up in the garage for well over 2 months now, went out and started it no issues. Purrred like a pusssy cat, another 3 months to wait before all the salt sand and slushy snow is gone....... sheesh.
Tazdevil is offline   Reply With Quote
Old 01-10-2011, 06:23 AM   #10
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
Thanks for the thread, I will have to get a battery tender as well.
What is the foam under the tires?? and where do you get them?? I know this is for flat spots but I thought about just taking the tires off..
Thanks!!!!!!
ToolFan66 is offline   Reply With Quote
Old 01-10-2011, 06:39 AM   #11
Bungo
Tampa Gulf Coast Family
Drives: 2010 ABM Camaro SS
Send a message via AIM to Bungo
Dealerships are required to do 30 (or 45) day inspections on all new cars on the lot. That means some poor brand new tech has to go outside with a pocket full of keys and start up each car and run it for an allotted time. Some manufacturers even require a road test to keep the tires from resting too long on one spot.
excited every morning to see the ABM 2SS/RS LS3 in the garage
and the wife says I have to be patient while she gets dressed
Bungo is offline   Reply With Quote
Old 01-10-2011, 06:39 AM   #12
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
On a newer vehicle it is not uncommon for the battery to drain if it is stored and not started for more thtn 30 days. The best way to resolve this issue is to buy a batter tender or make sure you start it at least once a month.
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 01-10-2011, 07:13 AM   #13
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Originally Posted by FirstCamaro23 View Post
I need some advice.
All great winter storage advice, and YES, you should get a battery tender.
Few other tips, tape off the exhaust tips on your mufflers, or you can place steel wool in the tips, just remember in the spring (before starting) that you did this to the tips. The reason is it will help prevent the critters (mice) from making a home out of your system. Trust me on this one, as a snowmobiler we have seen all too often that mice will make their way into your air box thru the exhaust and make a home out of it.
Thanks!!!!!!
Helps prevent flat spotting of the tires. Try Home Depot or Lowes. Do not take the wheels and tires off and hang the suspension. Bad for the springs to hang.
Old 01-10-2011, 09:37 AM   #14
Russell James
Russell James's Avatar
It shouldn't be tripping the charger. I'd try charging it at the battery to see what happens. But most likely something will need to be fixed. Possibly the battery is internally shorted. I'd call the dealer and ask if you can just bring in the battery for them to check out.
Smartest Battery Charger in the World!!! southerncarparts Miscellaneous Items 10 02-15-2010 07:08 PM
Battery Tender for winter storeage phantom Camaro DIY & HOW-TO instructions & discussions 3 01-01-2010 03:41 PM
Smartest Battery Charger in the World!!! southerncarparts Audio / Visual / Electronics/ Gauges / Nav 0 12-04-2009 08:35 AM
Positive Battery Cable issue (not near starter) shiftz33 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-12-2009 05:20 PM
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 02:03 PM
