01-08-2011, 08:28 PM | #1 |
Drives: 2010 CAMARO. 10.04@133mph, 1.4 60' Join Date: Jul 2009
MY NEW BMR SUSPENSION INSTALLED
Hi,
After adding a cam and accompanying mods to my camaro almost a year ago, I could'nt seem to run any faster in the 1/4 do to traction issues, so I decided to add some suspension mods to the car. I usually do mods on my own car first so local customers can see and checkout the mods before I install them on their car. The car had previously had the Barton tunnel brace and H&R drop springs on it. Here is the list of parts that were on this project: Hawk ceramic brake pads BMR toe rods BMR trailing arms and outer trailing arm bushings BMR differential bushing mounts BMR Street cradle bushing inserts Nitto 555R drag radials- 305-35-20 I also bought a Cincy Bushing tool(for removing diff bushings) if anyone is interested in renting it. I do work on other cars too so if you be interested in just renting it we could do it through pay pal. I was thinking I can take a deposit for $150, and when i get it back i can refund you $120. It would keep y'all from having to spend $170 on a tool you might just use once. I can even send a return self addressed box with it to send it back in. send me an email at: nchauffe@gmail.com if interested. here are the pics and vid dropped the rear cradle these are the stock bushings, big air gaps in them and the flimsy toe and trailing arms Nitto tires compared to stock rear tires Hawk pads no more gap in bushings all installed Last edited by BLACK10; 01-22-2011 at 10:43 AM. |
01-08-2011, 08:37 PM | #2 |
CamaroFans.com
Very nice Black... did you go with the spherical bushings?
01-08-2011, 08:55 PM | #3 |
Drives: BLACK 2SS/RS Join Date: Sep 2009
Nice!
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
01-08-2011, 09:09 PM | #4 |
01-08-2011, 09:12 PM | #5 |
Drives: 2010 2SS/RS ; 1970 Firebird Formula Join Date: Jan 2010
OK cool. So how are your 1/4 runs now?
01-08-2011, 09:14 PM | #6 |
01-08-2011, 09:14 PM | #7 |
CamaroFans.com
01-08-2011, 09:16 PM | #8 |
01-08-2011, 09:17 PM | #9 |
Nice!
01-08-2011, 09:20 PM | #10 |
CamaroFans.com
Cool... I have a set in my trunk that will be going on next weekend and they have the spherical bushings. I hear they can be a bit noisy...
01-08-2011, 09:26 PM | #11 |
yeah, i went with the non ajustable toe rods and regular trailing arms
01-08-2011, 10:12 PM | #12 |
Drives: 2010 1LT/RS Join Date: Nov 2009
let me know when yall head to track, i'd like to take a ride out there too!
2010 1LT/RS Eibachs, Doug Thorleys, Flowmasters, Stillen, hmm a few other things...
01-10-2011, 09:42 PM | #13 |
01-17-2011, 09:41 AM | #14 |
Drives: '69 SS Convertible Join Date: May 2009
Any tips/tricks you can suggest with doing this?
I think the BMR cradle/diff bushing kit might be my next mod. I have access to a lift...not sure if that will make any difference or not. I might have to take you up on the tool rental as well. Don't you just have to cut a section into the bushing and then the tool helps pull it out? Any noticable difference in the ride and/or noise?
Build Journal |
Similar Threads | ||||
BMR Suspension End Links Available At APEX Motorsports: Camaro5's #1 Source For BMR!! | Apex Motorsports | Suspension / Chassis / Brakes | 17 | 02-07-2011 07:53 PM |
Finally..bmr springs installed | revron | Suspension / Brakes / Chassis | 24 | 07-26-2010 11:23 AM |
BMR or SPOHN Can users post feedback on the suspension parts | 55Designs | Suspension / Brakes / Chassis | 5 | 04-21-2010 01:55 PM |
SLP, Brembo, BMR Fabrication, DBA- Suspension and Brake SALE!!! FREE $50 Gift Certs! | bijanmaleki | Suspension / Chassis / Brakes | 4 | 01-09-2010 05:02 PM |
BMR Launches New Product - G8 Front Suspension Bushing Kit (BK012) | BMR Suspension | Suspension / Chassis / Brakes | 3 | 01-04-2010 08:00 PM |
