NOW CAMMED & SUPERCHARGED
Drives: 2010 Camaro 2SS/RS Black w/ IOM Join Date: Oct 2008
what stall for supercharged/cam auto
About to cam my maggie auto looking for stall idea. livernois says precision 2400. comments please. i want it very streetable
Livernois Motorsports: Maggie 2300 7psi, Livernois 2C cam/L99 to LS3 Conversion, Ported TB, Rotofab w/adm race scoop, adm trans cooler,Kooks headers no cats, Kooks 3" exhaust. METCO breather. Precision 2400 Vigilante TC. Eibach Lowering Springs & Swaybars. BMR Trailing arms, BMR Rear Cradle Bushings, BMR Toe Rods, BMR Differential bushings. Vossen CV3 20's w/ 305 Mickey Thompson @25psi. Zl1 front bumper. OE Zl1 Hood and matte black insert. 556RWHP/500RWTQ L99
![]() ![]() ![]() Drives: aqua 2ss l99 Join Date: Jun 2009
i have similar setup to you.
i went with the converter from jannetty. i believe they say its 2600, but is more like 2400. street tires cant hook enuf to see what the flash stall is. brake stall is 1900-2000. you cant tell its a stall converter, except at the track. its also wife approved. hope that helps. ps. it allows me to take off from a light (1/4 to 1/2 throttle) without spinning the tires accidentally.
May your exhaust note, sing in harmony with your blower.
Drives: 2010 Camaro Join Date: Feb 2010
If you are going to keep the stock gears I would say 28-3000. Anymore and I'm afraid you blow up the drag radials. If you were on slicks maybe 32-3400. I know I want a higher stall but I still need to see what happens with the extra 100 rwhp I just got and the 4.10's. Ted still says it's spot on and he hasn't been wrong with me yet.
Mine drives gentler than stock even with the gears and hp. I can brake stall mine to about 24-2500 if I remember correctly. And with teds converter you don't need an aftermarket cooler and the temps remain the same as stick.
CamaroFans.com
I have a 3200 stall and it's very streetable... but tires are def a must to make it hook.
#6 |
whats tires to get it to stall that high, i have the same tc as you.
#7 |
#8 |
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yank SS3600 here and it drives like stock
#9 |
remember the more stall you have the less efficient it gets. what you get on one end, comes off the other.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 99 Camaro; 2010 Camaro 2SS/RS Join Date: Nov 2009
i have the JRE stall also.
#11 |
Drives: 1987 Buick Regal Turbo-T Join Date: Sep 2009
Just to let everyone know, this converter with the magnacharger should stall in the 3000-3400 range with the magnacharger and other upgrades to come. its rated at a 2400, but due to the drastic increase in torque will stall a good bit higher.
#12 |
And still remain very streetable correct andy?
#13 |
#14 |
Cool. I am looking to send off in FEB for DOD delete cam and the stall. Trying to get my trailing arms and toe rods in this week and then guages and trans cooler before shipping off.
| 2006 TRAVERSE CITY AUTO CONFERENCE | KILLER74Z28 | Off-topic Discussions | 2 | 09-18-2010 10:45 AM |
| CHICAGO AUTO SHOW - February 12-21 - WHO'S GOING? | CamaroScotty | USA - Great Lakes | 43 | 02-26-2010 07:05 AM |
