Old 01-12-2011, 06:43 PM   #1
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
The truth behind the birth of the LS motor....
Learned this from a friend... found it funny... and lame....
You can use a small block Ford Torque plate to hone an LS bore.
You can bolt LS heads to a small block ford. The bore centers are only about .020 different.
Firing order on the LS is Ford
Symetricial ports just like Ford
You can actually install a different timing chain cover and install a conventional dist in the front...just like a ford.
SO basically GM just put 15 deg heads on a small block ford V8 and made power with them...
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 01-12-2011, 06:55 PM   #2
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
No that part is like a Buick.
Front mounted Dizzy and easy access external oil pumps were their thing.
2ndgenz28 is offline   Reply With Quote
Old 01-12-2011, 07:11 PM   #3
danhr
BAMF SS
danhr's Avatar
correct me if i'm wrong but a small block buick's distributer is front mounted but still goes through the intake
a small block ford's distributer is front mounted but goes through the timing cover.... just like a distributer converted ls motor
Stock Longblock
Old 01-12-2011, 07:55 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
No Buick its the timing cover, same place the oil pump is.
That desing has lasted a long time, it went from the V8 into the 3.8 V6 and even used by Rover, which were used in allot of Jeeps.
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Anyone DD'ing a LS here? nascarnate326 5th Gen Camaro SS LS LT General Discussions 54 06-20-2010 11:08 PM
Got Pulled over... TRSS2 Cosmetics and Lighting Modification Discussions 39 03-08-2010 12:57 PM
Holley LS Fest, September 10-12, 2010 Pro Stock John USA - Great Lakes 1 01-28-2010 09:18 AM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
