Old 01-13-2011, 08:46 PM   #1
CamaroC-17
Formerly Camaroc5
CamaroC-17's Avatar
Drives: 2010 Camaro LT/RS M6
Should I drain some? Maybe a little too much oil
I didnt realize I was on the last quart of oil and put the entire 6th bottle in without checking the level. After letting the engine run the level is around A and B on the picture below. Should I drain some? I'm thinking a half a quart too much.
CamaroC-17 is offline   Reply With Quote
Old 01-13-2011, 09:07 PM   #2
CyberDan
CyberDan's Avatar
Drives: 1SS Camaro
Yea, I would... I think there's a risk of busting some seals. Just unscrew it enough for the oil to drain around the plug... If you take the plug out, all the weight will push all that oil out and you might make a huge mess.
CAI Cold Air Intake, VMax CNC TB, Borla Sport Catback Exhaust, EE Oil Catch Can, Eibach Sway Bars and Drop Springs, AAC concept side markers, stealth signal bulbs, Heritage grille, Sparks Restorations front and rear modern SS emblems
CyberDan is offline   Reply With Quote
Old 01-14-2011, 01:22 PM   #3
Jayson9
Drives: 2SS
I've heard testimony both ways.... some say that draining the excess (overfill) is the way to go, others say that the engineers included some extra space just for that reason. Mostly because of the quick lube places and such that people use.
I have seen this topic get alot of attention on other sites, and then some engineer comes on and says wait a minute, they are designed for the occasional 1/2 qt overfill.
Jayson9 is offline   Reply With Quote
Old 01-14-2011, 01:33 PM   #4
Russell James
Russell James's Avatar
1/2 qt over is fine, don't mess with it.
Old 01-14-2011, 01:46 PM   #5
ffrcobra_65
the engine should be ok but I am sure this is bugging you so, get under the car, unscrew the oil filter, empty it, put it back on. 5 minutes and be done. Less messy and easy to do as opposed to unscrewing the drain plug and the oil just gushes out and you hurry and try to get the frigging plug back on and sometimes end up having to add oil again because you drained too much! I know!
Old 01-14-2011, 01:48 PM   #6
outlaw2
outlaw2's Avatar
Drives: 12 SS/RS Conv, 66 Impala SS Conv
I know nothing on the RS..But the SS/RS says 8 quarts, so is his RS only a V-6? and thats why camaroc5 only uses 6 quarts as per question. I filled mine with 7 qts,ran the motor,pulled dipstick and marked with a dremal tool then Added the last (8)qt and did the same. This way I can monitior oil consumtion at each fill up between marks
outlaw2 is offline   Reply With Quote
Old 01-14-2011, 01:53 PM   #7
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
sooooo you get a new dipstick for each oil change?
how do you tell the difference between the markings from 2 oil changes ago and the current one?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
danhr is offline   Reply With Quote
Old 01-14-2011, 01:58 PM   #8
ffrcobra_65
yeah, that is over kill IMHO but everyone is different. The dipstick already has marks and so what if there is a little consumption, it is normal. As long as the oil level reads between the 2 marks, it is good! No need for special marks.
Old 01-14-2011, 02:07 PM   #9
outlaw2
outlaw2's Avatar
I marked the back side of the dipstick at 7 and 8 qts...8 quarts will Always Be 8 Quarts, doesn't matter if it change 1 or change 30.Its an aircraft mechanic thing that was Ingrained into me. Consumtion is normal but to much can lead to other issues and I'd rather be safe then be going "Oh Shit" where did it go?
Old 01-14-2011, 02:30 PM   #10
RAYSRT8
RAYSRT8's Avatar
Drives: 2011 Challenger SRT8 6.4L 392 Hemi
FYI - Our SS's are screw in underneath, but the V-6 is on top and oil will not drain from it when you remove it.
I had the V6 version last year and traded it in for an SS May of 2010.
2011 Stock 6.4L 392 Hemi Challenger
Flowmaster American Thunder Series Cat Back
Camaro parts for sale: http://www.camaro5.com/forums/showthread.php?t=152474
RAYSRT8 is offline   Reply With Quote
Old 01-14-2011, 02:33 PM   #11
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
I'd say that level 'B' on your diagram is fine. If its all the way up to 'A', I would remove a bit to be on the safe side.
The risk you run with too much oil is the crankshaft touching the surface of the oil in the pan... this will whip it into foam rendering it useless - and before long you'll be needing a new engine.
Old 01-14-2011, 03:28 PM   #12
zen
Drives: 2011 CTS CPE & 2010 2LT/RS CGM
If he has a V6 then there is nothing wrong with using 6 qt. Perhaps he is confused between quarts and liters.
zen is offline   Reply With Quote
Old 01-14-2011, 03:35 PM   #13
RAYSRT8
RAYSRT8's Avatar
I could have sworn the V6 I had last year took 6 quarts, but maybe I am wrong...
Old 01-14-2011, 04:12 PM   #14
y2k king
y2k king's Avatar
Drives: 2011 ss camaro
i think it's a great idea...i did it on my harley cause the level was really hard to see on the chrome dipstick.
10/28/2010 got it
y2k king is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 07:11 PM
Roto-fab CAI, dry filter vs. oil filter Roto-fab 1 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 0 11-12-2010 09:07 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
