![]() Drives: 2010 Camaro SS (LS3, 150-Shot N2O) Join Date: Jan 2011
Trinity and LS3. Problems and Questions
I hooked up my trinity to the Camaro finally (just traded my SRT4 for it) I'm used to using the trinity with my SRT4 but with the camaro things seem diff.
First off. Is there no 93octane tune for the Camaro? I'm seeing a Diablo Tune, which ive never seen before, and a 91octane tune... Second. I set speed limiter to "off" but tonight it kicked in and the middle screen showed "speed limited to 155" Third. What is the COT and DoD? I'm not framiliar with this... what do they do? Fourth. The HUD displayed "Engine Power Reduced" while writing the Diablo Tune. Is this normal? Finally. Since I'm running Ethanol Free 93Octane (yeah the good stuff) do I need to make any adjustments to the fuel or timing? Wow never thought tuning N/A would be more complicated than getting the WOT Fuel to 11.5afr across the board on a 21psi stock turbo SRT4.. >.< Side Note: The CAGS disable is working GREAT! no more "1-4 Shift" and a far less termpermental me while driving... |
K so I learned that DoD is the active fuel management.. everyone seems to say that when you turn that off you get a very noticeable power increase..
RIP JoePa
Drives: 2010 2SS/RS & 2001 Audi S4 Join Date: Apr 2010
DOD is only on l99's
You could always PM somebody like Ted at Jannetty and talk about a custom tune that he could send you but I think he may only use the SCT tuner... Sent from my DROIDX using Tapatalk
![]() Drives: where to begin... Join Date: May 2010
1 The Diablo Tune is the 93 octane tune
2 Did you reprogram the car after you set the speed limiter off? If so I know they used to limit how much you could raise the speed limiter, I always turn it off in the CMR software so I'm not sure... 3 COT = Catalyst Over Temp DoD = Displacement on Demand which isn't used on the LS3 4 Normal 5 No, the computer compensates automatically for the percentage of ethanol sensed. |
#5 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Thanks.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
| First Tuning - some starter questions... | Michael_Js | Tuning / Diagnostics -- engine and transmission | 4 | 05-07-2010 12:57 PM |
