Old 01-15-2011, 10:02 AM   #1
stratman2SSRS
stratman2SSRS's Avatar
Drives: Lingenfelter Camaro
Question about keyed power
I have a question about keyed power.
In the fuse panel on the drivers side dash I need to find a keyed 12v.
Question being.. Can I get the keyed power from the fuse side of the panel with a tap fuse, or do I need to TAP into tha actual wire on the other side of the fuse panel?
I'm installing a boost guage in the pillar.
Also what fuse/wire would you tap into?
Thanks, Stratman
stratman2SSRS is offline   Reply With Quote
Old 01-15-2011, 01:05 PM   #2
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '26 Corvette Stingray
Lets assume you have a 2010 model. Go to page 9-45. you will see a pic of the fuse block that is inside the car, just take off the cover on the left side of the dash.
FUSES 17 & 18 are both KEYED, so that the only time they get power in when the car is on. I did this for power for my radar detector as did a lot of folks.
get a FUSE TAP from Radio Shack
connect the power wire to your gauge using a connector like this
Name:  wire connector.jpg
I connected mine on Fuse 17....but either will do....
and don't forget the GROUND, there is a screw right above the fuse box that works like a champ for that.
Old 01-15-2011, 01:21 PM   #3
BlownSS
BlownSS's Avatar
Drives: 2010 Camaro SS/RS
Look here: apparently you not only need switched power, you need it during crank.
http://www.facebook.com/album.php?ai...d=282128680586
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
BlownSS is offline   Reply With Quote
Old 01-15-2011, 05:02 PM   #4
stratman2SSRS
Thanks guys, that is exactly what I was looking for.
Old 01-15-2011, 05:38 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
Do not use those style fuse taps,, all they do is wreck you fuse block,, they spread the teminals too far in the fuse block and damage the terminals
use the fuse adders that have their own pig-tail on them,, i get them from our local bumper to bumper store,, they plug into your fuse block and have an added fuse and pigtail for your accessory and they dont wreck the terminals because they are the same dimension as a stock fuse(terminal wise)
Old 01-16-2011, 09:38 AM   #6
stratman2SSRS
That's exactly what I bought.
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 273 08-15-2023 05:44 PM
Modifying for " Dummies" Dr Jkel Tuning / Diagnostics -- engine and transmission 209 06-18-2012 12:24 AM
Power mirror question? FIRECAM Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 3 05-16-2010 04:11 PM
GM recalls 1.3 million vehicles rudack General Automotive + Other Cars Discussion 38 03-09-2010 11:43 AM
JD Power survey: Younger Buyers Avoiding Domestics Scotsman General Automotive + Other Cars Discussion 6 12-04-2007 02:31 AM
